VoIP Application on BeagleBoard [Linphone]
I forgot something important...
mediastream prints out a lot of messages. This can slow down the
application and generate a bad sound output. You have to remove them
(by redirecting them to /dev/nulll).
Another important issue. ALSA site says that ALSA version 1.0.20
guarantees complete support for BeagleBoard. Actually I found 1.0.18
release only. Perhaps moving to 1.0.20 could help.
Again, HIH
Ciao,
Ska
Hi Andrea Scaggiante,
There been a little confusion, we have to remove alsa.conf or asound.conf.
Thanks and Regards,
HarishKumar.V
where to get the uImage from Koen’s Narcisuss site, i tried to download, only root filesystem its getting, can u send me the uImage.
Thanks and Regards,
HarishKumar.V
asound.conf
ciao,
Ska
Hi Harishkumar V
We do actually use the root filesystem booting form an SD Card.
You can find an HOWTO to generate the uImage here:
http://elinux.org/BeagleBoard#Linux_kernel
or here
http://www.crashcourse.ca/wiki/index.php/BeagleBoard_Development_Environment
Never tried, hope it works.
Ciao,
Ska
Still no success.
For me, its not working. Can u send the uImage you have been using to test the mediastreamer in which both end works.
Thanks and Regards,
HarishKumar.V
I tried to use Ekiga on my beagleboard with building the Ekiga from
openembedded and installing the necessary dependencies manually. I
am
I have following observations.
1. I am unable to initialize the chat from the board. But if someone
else initialises chat to the board through ekiga, I am able to reply
to the messages and able to chat in duples mode.
2. When call is tried on the Beagleboard using ekiga, it is showing
segmentation fault.
3. I am unable to display the video using the webcam _ creative one.
Can someone confirm and let me know with leads how to go about it?
I need help on
1. Call processing if someone has tried making calls using ekiga
2. use ekiga to display video or capture video to be sent to other
applications.
3. initiating chat on duples mode.
Prem
