Vsync and double buffering
Has anyone implemented vsync and video buffering switching on the beagleboard, ideally for a DSS2 fb? If so, any pointers?
Cheers
Rob
Just yesterday I pushed changes to my DSS2 repository adding OMAPFB_WAITFORVSYNC ioctl. Double buffering can be implemented with panning.
  Tomi
Thanks Tomi, that's great timing :slight_smile:
Rob
panning.
I'm have difficulty working out how to setup omapfb for panning. I did the following:
Built a 2.6.27 kernel from Tomi's tree with 1 framebuffer enabled
Passed bootargs: video=omapfb:vram:8M omapfb.mode=dvi:1024x768MR-24@60 omapfb.vram=0:6M
fbset -fb /dev/fb0 -g 1024 768 1024 1536 32
# cat framebuffers
0 p:804b5000 v:c9000000 s:6291456 t:gfx
# cat overlays
gfx t:lcd x:0 y:0 iw:1024 ih:768 w:1024 h:768 e:1
vid1 t:lcd x:0 y:0 iw:0 ih:0 w:0 h:0 e:0
vid2 t:lcd x:0 y:0 iw:0 ih:0 w:0 h:0 e:0
l4-ovl t:l4 x:0 y:0 iw:0 ih:0 w:0 h:0 e:0
# cat managers
lcd t:dvi
tv t:tv
l4 t:none
# cat displays
dvi e:1 u:1 t:0 h:1024/80/48/32 v:768/3/15/4 p:57600 r:0 i:0
tv e:0 u:-1 t:0 h:720/0/0/0 v:574/0/0/0 p:0 r:0 i:0
# echo gfx y:768 > overlays
omapfb omapfb: setup overlay failed
I don't seem to have succeeded in mapping a double height framebuffer to the physical display. What am I missing?
Rob
Tomi Valkeinen <tomba@iki.fi> writes:
You are changing the position of the overlay on the screen there. That is not what you want. You want panning:
http://www.mail-archive.com/linux-fbdev@vuser.vu.union.edu/msg04109.html
It's been some time since I tested panning on omapfb, but it _did_ work at least =). Some new changes may have broken something, so keep me posted if you can't get it to work.
  Tomi
It still works. Very well. :slight_smile:
Robert
[from a private mail conversation, copy to the list]
Here are some snippets from private email:
