Warning - bad CRC or NAND, using default environment , please help
Mighty Blocksman wrote:
Thats what I get heres my full boot output. Anyone know where I should
start?
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
OMAP3 Beagle Board + LPDDR/NAND
DRAM: 128 MB
NAND: 256 MiB
*** Warning - bad CRC or NAND, using default environment
This is no problem. It's just the info that you never saved your
environment (U-Boot configuration settings) yet and that the default
environment is used. Your U-Boot will work as expected with (or
without) this warning.
Saving your environment to NAND using
saveenv
command makes this warning go away.
Dirk
Note that the newer uboots save the env to a different location, so
don't be surprised to see that warning again when you replace your u-
boot with a newer one.
regards,
Koen
