"# warning: `zygote' uses 32-bit capabilities (legacy support in use)", error during porting Android GingerBread
I am trying to port Android GingerBread on BeagleBoardxM. I
downloaded the source from ‘gitorious/rowboat’ and using the
following link i built the Android File system,Android Linux Kernel,
u-boot boot loader (in u-boot-omap3 directory, x-loader, Toolchain (arm-eabi-4.3.1/bin):
http://processors.wiki.ti.com/index.php/TI-Android-GingerBread-2.3-DevKit-1.0_DeveloperGuide
However, during the Board Bring up i get the following message
and the entire bootup hangs up:
init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj inste.
init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
enabling adb
adb_open
warning: `zygote’ uses 32-bit capabilities (legacy support in use)
binder: release 1196:1196 transaction 1271 out, still active
binder: 1047:1270 transaction failed 29189, size 14460-0
binder: send failed reply for transaction 1271, target dead
Wht is the cause for this issue ? Can anyone provide some help.?
Rajiv
