watchdog timer boot status always returns zero
I need to check if the reboot was because of a watchdog timeout but it seems that the beaglebone watchdog timer does not have support of boot status.
Is that true?
I’m running a simple program to test this feature and, independent of what reason (power failure, watchdog timeout, normal reboot), the IOCLT always return zero.
the code bellow forces a watchdog timeout:
int ret = 0;
int fd = open("/dev/watchdog", O_WRONLY);
if (fd == -1) {
exit(EXIT_FAILURE);
ret = ioctl(fd, WDIOC_GETBOOTSTATUS);
printf(“boot status: %d\n”, ret);
while (1) {
ret = write(fd, “\0”, 1);
if (ret != 1) {
ret = -1;
break;
sleep(100000);
close(fd);
