This is the Week 5 Progress Report of the Cape Compatibility project.
Accomplishments:
Completed the CAN bus testing of comms cape using mcp2515.
Load cape and Relay cape are working with same DT overlay now…
Relay Cape: https://github.com/beagleboard/bb.org-overlays/pull/186
Load Cape: https://github.com/beagleboard/bb.org-overlays/pull/185- Updated compatibility layer code https://github.com/beagleboard/BeagleBoard-DeviceTrees/pull/17
Resolutions to blockers:
N/A
On-going blockers*:*
None
Plans for this week:
The compatibility layer needs some updates to write overlay easily, I have started working on this and the initial work will be completed this week. The 4-20mA of comms cape is remained to be tested and the servo cape overlay requires some updated in the compatibility layer. I didn’t get much time to work on libgpiod, I will surely do some work this week.
Completing comms cape testing on BBBWL.
Making Servo Cape to work on BBAI and BBB using same DT overlay.
Testing libgpiod on BBAI and if everything works out in time, creating at least 5 examples.
Further working on code refactoring in beagle-tester repository.
