this is a week #0 status update for the GSoC 2019 project Xen on Beagleboard-x15:
- Accomplishments:
- I made an introductory youtube video
- Purchased hardware (power adapters and a debugger)
- Downloaded and structured documentation on ARM and Beagleboard- Resolutions to blockers:
- No blockers- On-going blockers:
- Lack of the hardware- Plans for the next week:
- To run Xen on qemu-arm and document the process
- To set up the development environment (define a workflow and choose a toolchain and software versions).
This thread will be used for weekly progress updates of the project.
- Accomplishments:
There’s a lack of hardware?
I have a hardware order of Arrow WEB-SO17644708.
- Accomplishments:
I am talking about power adapters and a debugger. I purchased them and they should come soon (don’t know when exactly).
This is a week #1 status update for the GSoC 2019 project Xen on Beagleboard-x15:
Accomplishments:
I am in the process of making xen run on qemu-arm.
Currently, there is xen output, it hangs on starting Credit2 scheduler (perhaps during bad interrupt controller)
Not Resolved - hardware haven’t arrived yet
On-going blockers:
Lack of the hardware (adapters and debuggers haven’t arrived yet)
Non-starting xen scheduler
To buy hardware in a local store if it doesn’t arrive in two or three days.
To start implementing interrupt controller support for Xen.
This thread is used for weekly progress updates of the project.
This is a week #2 status update for the GSoC 2019 project Xen on Beagleboard-x15:
Accomplishments:
I was able to run xen dom0 and domU simultaneously on qemu-arm64.
Currently, I need to figure out how to deal with their consoles
The description of the process of installing xen on qemu is almost ready
I bought a power supply
I asked a secretary of my lab to repurchase the debugger from another place (from mouser.de)
On-going blockers:
Lack of the hardware (the debugger hasn’t arrived yet)
Not-known how to deal with consoles
To check the board with u-boot+Linux+busybox
To buy also a usb-ttl adapter and electrostatic bracelet
Try to understand how interrupt controller works
If hardware arrives to start implementing interrupt controller
Accomplishments:
On-going blockers:
Lack of the hardware (the debugger hasn't arrived yet)
I guess this is related to the post on xen-users today?
By hardware, do you mean the debugger? If so, I don't think it is
required for starting to implement the interrupt controller.
Cheers,
> Accomplishments:
> On-going blockers:
Yes, it was.
Oh, great, then I will start to do it without it. I also thought about
this today.
Another accomplishment:
The description of how to install Xen on Qemu for arm64 platform is ready:
https://medium.com/@denisobrezkov/xen-on-arm-and-qemu-1654f24dea75?postPublishedType=repub
Xen On Arm64 and Qemu. In this post I want to show you how to… | by Denis Obrezkov | Medium
Thank you for the post. May I ask if you can update the wiki page with
your fixes?
For the rootfs part, we may want to provide different alternatives so
the user can decide what is the most suitable way for him.
Cheers,
your fixes?
Do you mean this wiki-page:
https://wiki.xenproject.org/wiki/Xen_ARM_with_Virtualization_Extensions#Building_Xen_on_ARM
The main question is what to update?
Because the wiki pages shows another example where uefi and a
ready-to-use image are used along with xl.
(+ Stefano)
> your fixes?
Xen ARM with Virtualization Extensions - Xen
I think anything "board" specific (e.g U-boot configuration) should go
in QEMU page.
For the rest, it depends on your suggestion. For the rootfs, we may
want to create a new page.
Stefano any opinion?
Cheers,
This is a week #3 status update for the GSoC 2019 project Xen on Beagleboard-x15:
Accomplishments:
I was able to run u-boot+Linux+busybox on bb-x15
I’ve tried to boot Xen and got to the booting problem
I found usb-ttl, sd card and ethernet cable last week
The debugger should arrive approx. in 10 days
On-going blockers:
I wait for the debugger
I don’t really understand how to debug the hardware via a serial port
I don’t have clear understanding on where the problem with booting is located
To try to understand what is a booting order and how configuration should be done
To try to understand how an interrupt controller works
To test the previous Iain’s work
To try to boot further
To start implementing interrupt controller support.
Hi Denis,
Thank you for the update.
Accomplishments:
On-going blockers:
Hmm, in which way? With GDB?
In general, when I only have the serial port in hand, I will just print characters in key place to see how far it goes.
We can have an IRC chat about this tomorrow.
Could you expand about the booting order?
From the thread today, I am not sure this is going to be useful. We already know that lain didn’t face the SMP issue because he removed the secondary CPU from the DT. It would be more interesting to understand whether Linux is able to bring-up the secondary CPU in Hyp mode.
Have you tried removing the CPU from the DT?
Cheers,
A small update:
When we tried to cancel our order digi-key started to work:
https://wwwapps.ups.com/tracking/tracking.cgi?tracknum=1ZWA47976618658824
This is a week #4 status update for the GSoC 2019 project Xen on Beagleboard-x15:
Accomplishments:
I was able to send the first patch for a review
I wrote a small function that switches the secondary core to HYP mode
The debugger and power supplies have arrived
I use print functions to debug code
On-going blockers:
I don’t understand how Linux sets up the master clock on OMAP5
I have an error when I trying to boot, I need to investigate its nature
(https://pastebin.com/MskyW7ym)
To start working with the arrived debugger
To initialize all the required clocks
To understand how interrupt controller functions on BB-x15.
Accomplishments:
On-going blockers:
The only clock issue I had was solved by adding clock-frequency element to armv7-timer entry in the device tree. See patches/kernel/0008-set-armv7-time-to-6-14-MHz-rate-in-DT.patch
The kernel takes almost all its configurations/settings from the device tree file.
This is a week #5 status update for the GSoC 2019 project Xen on Beagleboard-x15:
Accomplishments:
I fixed clock frequency and add memory mapping (more in resolution to blockers)
I started to work with the debugger
I was able to fix clock frequency via setting up a constant value in a device tree
An additional memory-mapping was adding as it was done in Iain’s patch
On-going blockers:
I stuck when xen is trying to deal with the secondary IRQ controller called crossbar (https://pastebin.com/U0gch9us)
To work with the debugger
To understand how interrupt controllers function on BB-x15
To try to integrate the “crossbar” IRQ controller into Xen.
This is a week #6 status update for the GSoC 2019 project Xen on Beagleboard-x15:
Accomplishments:
I understood how the crossbar works and started to implement its support in xen
I’m implementing the crossbar support
On-going blockers:
I still need to implement the crossbar support and understand how xen deals with interrupts and a console
To implement the crossbar support (make_crossbar_node)
To allow xen to receive uart interrupts.
This is a week #7 status update for the GSoC 2019 project Xen on Beagleboard-x15:
Accomplishments:
I added the crossbar node and started to work on routing interrupts to GIC
The crossbar node is added
The naive implementation of the irq number translation function is added
(https://github.com/embeddedden/xen/commit/5a4f3d488a38f70bc9f63886f33ce7a00c03c5e6)
On-going blockers:
I’m trying to add the irq number translation function for the crossbar (it is not working correctly for now)
To implement the crossbar support (route interrupts to GIC)
Hello dear mentors,
Just three days ago my ssd has died. I notified Julien about this
unlucky incident. Fortunately, all my GSoC-related data was either on
Github or in other places. So, right now everything is working - I
purchased a new SSD and installed an operating system and tools.
And now I am on the same point as before the ssd - crossbar is working
to some extent, uart interrupts are going to xen, Linux feils with:
[ 0.000000] random: get_random_bytes called from
start_kernel+0x2fc/0x4b4 with c0
[ 0.000000] irq: no irq domain found for crossbar !
[ 0.000000] Internal error: Oops - undefined instruction: 0 [#1] SMP
ARM
[ 0.000000] Modules linked in:
[ 0.000000] CPU: 0 PID: 0 Comm: swapper/0 Not tainted
5.2.0-07109-gd7d170a8e357 4
[ 0.000000] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.000000] PC is at __omap_sync32k_timer_init+0x1f0/0x34c
[ 0.000000] LR is at irq_create_fwspec_mapping+0x1d8/0x330
[ 0.000000] pc : [<c0c0c570>] lr : [<c01a00c0>] psr: a
