Hello Gays,
what is the easiest way to eliminate all Software parts for the Display Driver if I have a backup SD Card?
Do I Need a Kernal Projekt to rebuild the Linux Kernal?
Exist the Option to disable functions in the start configuration files and to delete Files at the SD Card? Which files?
Can anyone help me?
Best regards
Edgar
Hi Edgar,
I would recommend that you buy this book as it will answer most of the question you have asked:
Mastering Embedded Linux Programming - Second Edition by Chris Simmonds
If you buy the Kindle edition, you can start reading immediately on you Tablet, Mac, PC or Kindle device. If you search on Amazon, you will see the table of contents and you will see that it covers most of the areas you are interested in.
John
