What event urges me to use build_kernel.sh instead of ./tools/rebuild.sh
currently I am in the "Middle Of The Road" of
migrating from 3.8.x to 3.14.x.
Currently the kernel is building natively
on my bbb. This take time...
The first start, the call to build_kernel.sh freezes
my bbb deadly while git cloning the base kernel sources.
I had to cut power, put the sdcard in to my PC, fsck the
whole thing and then rebuild.sh there until the point,
the kernel configuration tool came up.
I Ctrl-C that, put back the sdcard into the bbb and
do a ./tools/rebuild.sh there, which does the trick.
Now I have a dilemma:
I have no clue which events/circumstances will urge me
to use build_kernel.sh instead of ./tools/rebuild.sh.
For updateing I am using this script in the "bb-kernel"
directory:
    #! /bin/zsh
    git checkout master -f
    git branch -D tmp
    git pull
    git checkout origin/am33x-v3.14 -b tmp
trigger a recompilation of the file by make and this
is true for all files of the build process as far as
I know.
On the other hand... :wink:
For what events/circumstances is it highly recommended
to use build_kernel.sh and are there tricks or workflows
how I can minimize these?
Is it possible to update the base kernel sources in a way,
which makes it "tools/rebuild.sh"-friendly?
Thank you very much in advance for any help!
Best regards,
mcc
currently I am in the “Middle Of The Road” of
on my bbb. This take time…
For updateing I am using this script in the “bb-kernel”
directory:
#! /bin/zsh
git branch -D tmp
git pull
That ‘3.14’ branch is eol…
From my understanding each change to a file has to
I know.
On the other hand… :wink:
which makes it “tools/rebuild.sh”-friendly?
Sure after you run build_kernel.sh ‘first’ after every git checkout
Robert Nelson <robertcnelson@gmail.com> [14-10-04 14:12]:
> Hi,
> directory:
> #! /bin/zsh
> git branch -D tmp
> git pull
That '3.14' branch is eol...
> I know.
Sure after you run build_kernel.sh 'first' after every git checkout
> Best regards,
> mcc
> For more options, visit http://beagleboard.org/discuss
> You received this message because you are subscribed to the Google Groups
"BeagleBoard" group.
> To unsubscribe from this group and stop receiving emails from it, send an
email to beagleboard+unsubscribe@googlegroups.com.
> For more options, visit https://groups.google.com/d/optout.
You received this message because you are subscribed to the Google Groups "BeagleBoard" group.
To unsubscribe from this group and stop receiving emails from it, send an email to beagleboard+unsubscribe@googlegroups.com.
Hi Robert,
thanks fpr your explanation ... but my lack of knowledge about
english ...
...what does that mean? "EOL" is part of the ASCII characterset and
means "End of line"...at least for my limited understanding...
Please help me :slight_smile:
directory:
#! /bin/zsh
git branch -D tmp
git pull
I know.
Best regards,
mcc
“BeagleBoard” group.
You received this message because you are subscribed to the Google Groups “BeagleBoard” group.
Hi Robert,
thanks fpr your explanation … but my lack of knowledge about
english …
…what does that mean? “EOL” is part of the ASCII characterset and
means “End of line”…at least for my limited understanding…
End of life…
Use this 3.14…
https://github.com/RobertCNelson/ti-linux-kernel-dev
Or
https://github.com/beagleboard/linux
Robert Nelson <robertcnelson@gmail.com> [14-10-04 14:32]:
> > > Hi,
> > > directory:
> > > #! /bin/zsh
> > > git branch -D tmp
> > > git pull
> > > I know.
> > > Best regards,
> > > mcc
Groups
send an
> Hi Robert,
> english ...
End of life..
Use this 3.14...
GitHub - RobertCNelson/ti-linux-kernel-dev: vendor bsp...
Or
GitHub - beagleboard/linux: The official Read Only BeagleBoard and BeagleBone kernel repository https://git.beagleboard.org/beagleboard/linux
After compiling an already near dead kernel on my bbb now I get
totally lost/confused about how to ride this horse...
Here:
https://eewiki.net/display/linuxonarm/BeagleBone+Black
I found (shortened to the command sequence):
git clone GitHub - RobertCNelson/bb-kernel
cd bb-kernel/
git checkout origin/am33x-v3.15 -b tmp
./build_kernel.sh
...but I want the 3.14.x kernel
When I change the above sequence to
git clone GitHub - beagleboard/linux: The official Read Only BeagleBoard and BeagleBone kernel repository https://git.beagleboard.org/beagleboard/linux
cd bb-kernel/
./build_kernel.sh
...will I get what I want and need to compile an alive kernel
3.14.x...
...or which sequence is correct...?
Best regards,
mcc
