What is special about SPI0 ?
I was working a DT Overlay for my touchscreen and ran to issues trying to load it.
It can successfully load it via cape_enable=bone_capemgr.enable_partno=BB-ADS7846 (so I know the overlays works) but I don’t get the same results (not working) via the command line. Investigating this further I noticed similar points with the SPI0 (BB-SPIDEV0-00A0.dts) and discovered it not setting the pin mux via the command line as I would expect. (SPIDEV0 also works via capemgr in uEnv.txt)
I’m using the bog-standard BB-SPIDEV0-00A0.dts overlay from bb.org-overlays/src/arm. Everything else looks like it is working properly in dmesg.
I can move forward using bone_capemgr.enable in uEnv.txt so this is not a critical issue but more a point of understanding what is going on (or not, as the case may be) and efficiency. I’ve googled around but could not find anything related to the newer 4.x kernels.
Thanks in advance for any clues or assistance.
Environment:
root@beaglebone:~# uname -r; cat /etc/dogtag; dtc --version; cat /proc/cmdline
4.4.1-bone5
BeagleBoard.org Debian Image 2016-01-31
Version: DTC 1.4.1-g1e75ebc9
console=tty0 console=ttyO0,115200n8 root=/dev/mmcblk0p1 rootfstype=ext4 rootwait coherent_pool=1M quiet
…/boot/uEnv.txt
##BeagleBone Black: HDMI (Audio/Video)/eMMC disabled:
dtb=am335x-boneblack-overlay.dtb
results do not vary if I use cape_universal=enable or not … I also tried the 4.1.16-ti-rt-r44 kernel
……noob-ish
Test
Following the instructions on William’s website for loading an overlay UART1 (working as expected)
http://www.embeddedhobbyist.com/2015/09/beaglebone-black-updating-device-tree-files/
before
root@beaglebone:~# cat /sys/kernel/debug/pinctrl/44e10800.pinmux/pinmux-pins | grep ‘pin 96|pin 97’
pin 96 (44e10980.0): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 97 (44e10984.0): (MUX UNCLAIMED) (GPIO UNCLAIMED)
root@beaglebone:~# cat /sys/kernel/debug/pinctrl/44e10800.pinmux/pins | grep ‘pin 96|pin 97’
pin 96 (44e10980.0) 00000037 pinctrl-single
pin 97 (44e10984.0) 00000037 pinctrl-single
load overlay
root@beaglebone:~# sudo sh -c “echo ‘BB-UART1’ > /sys/devices/platform/bone_capemgr/slots”
(ignore the sudo part with root – just a copy & paste point !!!)
after
pin 96 (44e10980.0): 48022000.serial (GPIO UNCLAIMED) function pinmux_bb_uart1_pins group pinmux_bb_uart1_pins
pin 97 (44e10984.0): 48022000.serial (GPIO UNCLAIMED) function pinmux_bb_uart1_pins group pinmux_bb_uart1_pins
root@beaglebone:~# cat /sys/kernel/debug/pinctrl/44e10800.pinmux/pins | grep 'pin 96|pin
pin 96 (44e10980.0) 00000028 pinctrl-single
pin 97 (44e10984.0) 00000008 pinctrl-single
root@beaglebone:~# cat /sys/devices/platform/bone_capemgr/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
4: P-O-L- 0 Override Board Name,00A0,Override Manuf,BB-UART1 97’
unload
sudo sh -c “echo ‘-4’ > /sys/devices/platform/bone_capemgr/slots”
same procedure for SPI0
before
root@beaglebone:~# cat /sys/kernel/debug/pinctrl/44e10800.pinmux/pinmux-pins | grep ‘pin 84|pin 85|pin 86|pin 87’
pin 84 (44e10950.0): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 85 (44e10954.0): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 86 (44e10958.0): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 87 (44e1095c.0): (MUX UNCLAIMED) (GPIO UNCLAIMED)
root@beaglebone:~# cat /sys/kernel/debug/pinctrl/44e10800.pinmux/pins | grep ‘pin 84|pin 85|pin 86|pin 87’
pin 84 (44e10950.0) 00000037 pinctrl-single
pin 85 (44e10954.0) 00000037 pinctrl-single
pin 86 (44e10958.0) 00000037 pinctrl-single
pin 87 (44e1095c.0) 00000037 pinctrl-single
load overlay
sudo sh -c “echo ‘BB-SPIDEV0’ > /sys/devices/platform/bone_capemgr/slots”
after
root@beaglebone:~# dmesg
[ 3283.995279] bone_capemgr bone_capemgr: part_number ‘BB-SPIDEV0’, version ‘N/A’
[ 3283.995309] bone_capemgr bone_capemgr: slot #5: override
[ 3283.995324] bone_capemgr bone_capemgr: Using override eeprom data at slot 5
[ 3283.995339] bone_capemgr bone_capemgr: slot #5: ‘Override Board Name,00A0,Override Manuf,BB-SPIDEV0’
[ 3284.006848] bone_capemgr bone_capemgr: slot #5: dtbo ‘BB-SPIDEV0-00A0.dtbo’ loaded; overlay id #0
root@beaglebone:~# ls /dev/spi*
/dev/spidev1.0 /dev/spidev1.1
Note above: no change to pin mux => I think the should be 30; 30; 10; 10
Relevant part of BB-SPIDEV0-00A0.dts
bb_spi0_pins: pinmux_bb_spi0_pins {
pinctrl-single,pins = <
0x150 0x30 /* spi0_sclk.spi0_sclk, INPUT_PULLUP | MODE0 */
0x154 0x30 /* spi0_d0.spi0_d0, INPUT_PULLUP | MODE0 */
0x158 0x10 /* spi0_d1.spi0_d1, OUTPUT_PULLUP | MODE0 */
0x15c 0x10 /* spi0_cs0.spi0_cs0, OUTPUT_PULLUP | MODE0 */
/eof
