What is the maximum NAND flash size for beagleboard OMAP3530?
If you use a DM37xx processor with POP and you need a nand flash, you’ll have to buy a MCP (Multi Chip Package): LPDDR with Nand Flash. Here you are the alternatives with micron: “MCP_DM37xx.jpg”
Actually, the NAND bus is available on the processor so you can add NAND onboard. If you are talking about the Beagle specifically, then yes POP is the only solution.
