Hurdy
1
Thanks for taking the time to read this.
I was wondering what version of Angstrom I should use from the
archives on the angstrom website that would best support board
revision B5?
The latest March release doesn't work, I'm guessing it's now because
of the difference between RevB & C.
http://www.angstrom-distribution.org/demo/beagleboard/archive/
Would I still use the latest MLO and uImage? If not what would be
recommended?
Kind regards,
Rob
What doesn't work? It works fine on revs B6, CP and C1D.
regards
Koen
Hurdy
3
Hi Koen, thank you for your response.
I just get a blank screen when loading Angstrom for the first time.
The beagle image loads at start then my monitor turns off.
That most likely means that your screen doesn't like the default 640x480 mode, try changing it to something your screen supports.
regards,
Koen
Hurdy
5
Hi Koen thank you for your reply.
Changing the screen resolution?
regards,
Rob
