A quick question.
I read am335xPruReferenceGuide.pdf but there is no detailed description of MII_RT module.
Where can I get the details of MII_RT ?
Best Regards,
Naoki Kawada
A quick question.
Best Regards,
Naoki Kawada
From http://e2e.ti.com/support/arm/sitara_arm/f/791/p/206939/733857.aspx
2. MII_RT is the real-time MII interface module inside PRU-ICSS. This is used for industrial communications such as EtherCAT. This is part of PRU-ICSS but has no relation to the Ethernet subsystem that is used for 10/100/1000 Mbps switching.PRU-ICSS is an independent module and MII_RT is a part of that. TI has chosen to not open it up for customer uses beyond what is supported by the SYS/BIOS based industrial SDK.
