Where is asoundlib.h?
I am trying to compile an ALSA application on my BeagleBone Black running Angstrom. There is no alsa/asoundlib.h file under /usr/include. Package manager shows that alsa-dev, libasound2 and alsa-lib-dev are all installed. I did not find any Angstrom packages containing the ALSA headers. Has anybody else came across this problem?
I believe libasound2 provides alsa-lib.
I think what you need is libasound2-dev
John
I could be wrong, but when I was trying to do this awhile ago on Angstrom, I did not find it. I ended up downloading and building the stuff on the BBBk. Now with Debian, I can now do like I did on the Raspberry Pi and and do the apt-get install libasound2-dev
More details on what I do is up on my Readme file of my github Raspberry Pi project(Bad name, but was first linux box): https://github.com/KurtE/Raspberry_Pi
From that readme:
I did not find any valid packages to install the ALSA, so I did it manually:
wget ftp://ftp.alsa-project.org/pub/lib/a...1.0.25.tar.bz2
tar jxf alsa-lib-1.0.25.tar.bz2
cd alsa-lib-1.0.25
./configure
make install
This did not set the USB device to be default sound device, I used the command: aplay -L to list the nodes. From which I created the configuration file: /etc/asound.conf pcm.!default sysdefault:Device
Again there may be easier ways, but that is what I did. Note: I am using a USB sound adapter…
From that readme:
cd alsa-lib-1.0.25
./configure
make install
Try this instead,
apt-get source libasound2
cd alsa-lib-1.0.25
// if you want debug symbols
export DEB_BUILD_OPTION=nostrip noopt debug
dpkg-buildpackage -rfakeroot -uc -us -j8 -aarmhf
// The dpkg-buildpackage uses the settings a patches in the debian folder and builds the library as intended
// This commands creates Debian packages in the parent folder.
cd …
sudo dpkg -i libasound2* deb
John
Thanks, that does look cleaner. I hope this works for mbelg…
Personally I am happy that I moved my BBBk to Debian, but locally I have updated my readme with the information, in case I need to do this again (will update on my github soon). Also looks like good general purpose advice so again thanks.
John: The instructions you provided are for debian. It does not work on Angstrom.
I solved this issue by uninstalling and re-installing alsa-dev package:
opkg install alsa-dev
Then I got the alsa headers under /usr/include/alsa directory as expected.
Murat
