Here is the Bootlog
Texas Instruments X-Loader 1.41
Starting OS Bootloader...
U-Boot 1.3.3 (Jul 10 2008 - 16:33:09)
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
OMAP3 Beagle Board + LPDDR/NAND
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Audio Tone on Speakers ... complete
Hit any key to stop autoboot: 3 0
OMAP3 beagleboard.org # printenv
bootfile=192.168.10.11:/works/omap3430_evm/boot_file/uImage
ipaddr=192.168.34.21
serverip=192.168.34.12
filesize=33CBAD
dieid#=619e00020000000004013ebf0a004012
bootargs=console=ttyS2,115200n8 noinitrd root=/dev/mmcblk0p2
video=omapfb.mode=d
vi:1280x720MR-24@50 init=/init rootfstype=ext3 rw rootdelay=1 nohz=off
androidbo
ot.console=ttyS2
bootcmd=mmc init;fatload mmc 0 80300000 uImage;bootm 80300000
stdin=serial
stdout=serial
stderr=serial
Environment size: 440/131068 bytes
OMAP3 beagleboard.org # boot
Usage:
mmcinit - init mmc card
** Unable to use mmc 0:1 for fatload **
Wrong Image Format for bootm command
ERROR: can't get kernel image!
OMAP3 beagleboard.org # 40T
Starting on with MMC
Reading boot sector
180776 Bytes Read from MMC
Starting OS Bootloader from MMC...
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
OMAP3 beagleboard.org # boot printf env
filesize=33CBAD
video=omapfb.mode=d
androidbo
ot.console=ttyS2
stdin=serial
stdout=serial
stderr=serial
OMAP3 beagleboard.org # setenv bootcmd 'mmcinit;fatload mmc 0 80300000
uImage;bo
otm 80300000'
OMAP3 beagleboard.org # saveenv
Saving Environment to NAND...
Erasing Nand...Writing to Nand... done
reading uImage
2075384 bytes read
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Linux-2.6.29-omap1-07193-g3f4964
Data Size: 2075320 Bytes = 2 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux.............................................................
done,
booting the kernel.
Linux version 2.6.29-omap1-07193-g3f49649 (root@ittiam-desktop) ( For
any Querie
s, information and bug reports please mail to osd@embinux.com ) #1 Fri
Jul 17 12
:39:15 IST 2009
CPU: ARMv7 Processor [411fc082] revision 2 (ARMv7), cr=10c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP3 Beagle Board
Memory policy: ECC disabled, Data cache writeback
OMAP3430 ES2.1
SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
Reserving 12582912 bytes SDRAM for VRAM
Built 1 zonelists in Zone order, mobility grouping on. Total pages:
32512
Kernel command line: console=ttyS2,115200n8 noinitrd root=/dev/
mmcblk0p2 video=o
mapfb.mode=dvi:1280x720MR-24@50 init=/init rootfstype=ext3 rw
rootdelay=1 nohz=o
ff androidboot.console=ttyS2
Unknown boot option `androidboot.console=ttyS2': ignoring
Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
GPMC revision 5.0
IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP34xx GPIO hardware version 2.5
PID hash table entries: 512 (order: 9, 2048 bytes)
OMAP clockevent source: GPTIMER12 at 32768 Hz
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 112768KB available (3824K code, 718K data, 144K init)
Calibrating delay loop... 501.02 BogoMIPS (lpj=1957888)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 520 bytes
regulator: core version 0.5
NET: Registered protocol family 16
Found NAND on CS0
Registering NAND on CS0
OMAP DMA hardware revision 4.0
bio: create slab <bio-0> at 0
OMAP DSS rev 2.0
OMAP DISPC rev 3.0
OMAP VENC rev 2
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
regulator: VMMC1: 1850 <--> 3150 mV normal standby
regulator: VDAC: 1800 mV normal standby
regulator: VUSB1V5: 1500 <--> 0 mV normal standby
regulator: VUSB1V8: 1800 <--> 0 mV normal standby
regulator: VUSB3V1: 3100 <--> 0 mV normal standby
regulator: VPLL2: 1800 mV normal standby
regulator: VSIM: 1800 <--> 3000 mV normal standby
i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
SCSI subsystem initialized
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
musb_hdrc: USB OTG mode controller at d80ab000 using DMA, IRQ 92
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
ashmem: initialized
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 220
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
i2c /dev entries driver
Driver 'sd' needs updating - please use bus_type methods
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB
1,8V 16-bi
t)
cmdlinepart partition parsing not available
Creating 5 MTD partitions on "omap2-nand":
0x000000000000-0x000000080000 : "X-Loader"
0x000000080000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000680000 : "Kernel"
0x000000680000-0x000010000000 : "File System"
usbmon: debugfs is not available
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: OMAP-EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.29-omap1-07193-g3f49649 ehci_hcd
usb usb1: SerialNumber: ehci-omap.0
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
android init
android_bind
mass_storage_function_add
android_usb gadget: Number of LUNs=1
adb_function_add
android_usb gadget: android_usb ready
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.29-omap1-07193-g3f49649 musb-hcd
usb usb2: SerialNumber: musb_hdrc
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
twl4030_rtc twl4030_rtc: Power up reset detected.
twl4030_rtc twl4030_rtc: Enabling TWL4030-RTC.
mmci-omap-hs mmci-omap-hs.0: Failed to get debounce clock
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
logger: created 64K log 'log_main'
logger: created 256K log 'log_events'
logger: created 64K log 'log_radio'
Advanced Linux Sound Architecture Driver Version 1.0.18a.
No device for DAI AD73311
No device for DAI AK4535
No device for DAI CS4270
No device for DAI PCM3008 HiFi
No device for DAI SSM2602
No device for DAI tlv320aic23
No device for DAI tlv320aic3x
No device for DAI twl4030
No device for DAI UDA134X
No device for DAI UDA1380
No device for DAI WM8510 HiFi
No device for DAI WM8580 PAIFRX
No device for DAI WM8580 PAIFTX
No device for DAI WM8728
No device for DAI WM8731
No device for DAI WM8750
No device for DAI WM8753 DAI 0
No device for DAI WM8753 DAI 1
No device for DAI WM8971
No device for DAI WM8990 ADC/DAC Primary
No device for DAI omap-mcbsp-dai-0
No device for DAI omap-mcbsp-dai-1
No device for DAI omap-mcbsp-dai-2
No device for DAI omap-mcbsp-dai-3
No device for DAI omap-mcbsp-dai-4
OMAP3 Beagle SoC init
TWL4030 Audio Codec init
asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
ALSA device list:
#0: omap3beagle (twl4030)
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
Power Management for TI OMAP3.
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev
1
Console: switching to colour frame buffer device 80x30
clock: clksel_round_rate_div: dpll4_m4_ck target_rate 36000000
clock: new_div = 12, new_rate = 36000000
omapdss: Could not find exact pixel clock. Requested 23500 kHz, got
24000 kHz
twl4030_rtc twl4030_rtc: setting system clock to 2000-01-01 00:00:00
UTC (946684
800)
Waiting 1sec before mounting root device...
mmc0: new high speed SD card at address aaaa
mmcblk0: mmc0:aaaa SD02G 1.84 GiB
mmcblk0: p1 p2
kjournald starting. Commit interval 5 seconds
EXT3 FS on mmcblk0p2, internal journal
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
VFS: Mounted root (ext3 filesystem) on device 179:2.
Freeing init memory: 144K
Warning: unable to open an initial console.
init: cannot open '/initlogo.rle'
init: cannot find '/system/bin/playmp3', disabling 'bootsound'
# warning: `rild' uses 32-bit capabilities (legacy support in use)
usb 2-1: new high speed USB device using musb_hdrc and address 2
usb 2-1: New USB device found, idVendor=0409, idProduct=005a
usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
usb 2-1: configuration #1 chosen from 1 choice
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
usb 2-1.1: new low speed USB device using musb_hdrc and address 3
usb 2-1.1: device v0461 p4d15 is not supported
usb 2-1.1: New USB device found, idVendor=0461, idProduct=4d15
usb 2-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
usb 2-1.1: Product: USB Optical Mouse
usb 2-1.1: configuration #1 chosen from 1 choice
input: USB Optical Mouse as /class/input/input0
generic-usb 0003:0461:4D15.0001: input: USB HID v1.11 Mouse [USB
Optical Mouse]
on usb-musb_hdrc-1.1/input0
# logcat
I/DEBUG ( 678): debuggerd: Jul 17 2009 14:10:18
I/vold ( 677): Android Volume Daemon version 2.0
E/vold ( 677): Unable to chdir to /sys/class/mmc_host/mmc0/
slot_name (m)
E/vold ( 677): Error bootstrapping card '/sys/class/mmc_host/mmc0/
slot_name'
(m)
I/vold ( 677): New MMC card 'SD02G' (serial 2745723) added @ /
class/mmc_host
/mmc0/mmc0:aaaa
D/vold ( 677): Bootstrapping complete
D/AndroidRuntime( 680):
D/AndroidRuntime( 680): >>>>>>>>>>>>>> AndroidRuntime START
D/AndroidRuntime( 680): CheckJNI is ON
D/AndroidRuntime( 680): --- registering native functions ---
I/ ( 681): ServiceManager: 0xac38
D/AudioHardwareALSA( 681): Mixer: element name: 'Carkit'
D/AudioHardwareALSA( 681): Mixer: element name: 'DAC1 Analog'
D/AudioHardwareALSA( 681): Mixer: element name: 'DAC1 Digital Coarse'
D/AudioHardwareALSA( 681): Mixer: element name: 'DAC1 Digital Fine'
D/AudioHardwareALSA( 681): Mixer: element name: 'DAC2 Analog'
D/AudioHardwareALSA( 681): Mixer: element name: 'DAC2 Digital Coarse'
D/AudioHardwareALSA( 681): Mixer: element name: 'DAC2 Digital Fine'
D/AudioHardwareALSA( 681): Mixer: element name: 'Earpiece'
D/AudioHardwareALSA( 681): Mixer: element name: 'Headset'
D/AudioHardwareALSA( 681): Mixer: element name: 'PreDriv'
D/AudioHardwareALSA( 681): Mixer: master 'PCM' not found.
D/AudioHardwareALSA( 681): Mixer: route 'Earpiece' found.
D/AudioHardwareALSA( 681): Mixer: route 'Speaker' not found.
D/AudioHardwareALSA( 681): Mixer: route 'Bluetooth' not found.
D/AudioHardwareALSA( 681): Mixer: route 'Headphone' not found.
D/AudioHardwareALSA( 681): Mixer: route 'Bluetooth A2DP' not found.
D/AudioHardwareALSA( 681): Mixer: element name: 'Analog'
D/AudioHardwareALSA( 681): Mixer: element name: 'TX1 Digital'
D/AudioHardwareALSA( 681): Mixer: element name: 'TX2 Digital'
D/AudioHardwareALSA( 681): Mixer: master 'Capture' not found.
D/AudioHardwareALSA( 681): Mixer: route 'Capture' not found.
D/AudioHardwareALSA( 681): Mixer: route '' not found.
D/AudioHardwareALSA( 681): Mixer: route 'Bluetooth Capture' not
found.
D/AudioHardwareALSA( 681): Mixer: route 'Bluetooth A2DP Capture' not
found.
D/AudioHardwareALSA( 681): mixer initialized.
E/ALSALib ( 681): external/alsa-lib/src/control/setup.c:334:
(snd_config_get_ctl
_elem_value) bad value type
I/AudioHardwareALSA( 681): Initialized ALSA PLAYBACK device hw:00,0
D/AudioHardwareALSA( 681): Set PLAYBACK PCM format to S16_LE (Signed
16 bit Lit
tle Endian)
D/AudioHardwareALSA( 681): Using 2 channels for PLAYBACK.
D/AudioHardwareALSA( 681): Set PLAYBACK sample rate to 44100 HZ
D/AudioHardwareALSA( 681): Buffer size: 16384
D/AudioHardwareALSA( 681): Latency: 371519
I/AudioFlinger( 681): AudioFlinger's thread ready to run for output 0
(snd_config_get_ctl
(snd_config_get_ctl
(snd_config_get_ctl
16 bit Lit
tle Endian)
I/CameraService( 681): CameraService started: pid=681
I/Zygote ( 680): Preloading classes...
D/dalvikvm( 680): GC freed 763 objects / 42128 bytes in 3ms
D/dalvikvm( 680): GC freed 278 objects / 17200 bytes in 3ms
D/dalvikvm( 680): GC freed 204 objects / 12424 bytes in 3ms
D/dalvikvm( 680): GC freed 441 objects / 28216 bytes in 4ms
D/dalvikvm( 680): GC freed 3595 objects / 174328 bytes in 11ms
D/dalvikvm( 680): GC freed 11589 objects / 408968 bytes in 17ms
D/dalvikvm( 680): GC freed 10633 objects / 446152 bytes in 19ms
D/dalvikvm( 680): GC freed 10529 objects / 440176 bytes in 21ms
D/dalvikvm( 680): GC freed 14636 objects / 516376 bytes in 25ms
D/dalvikvm( 680): GC freed 11453 objects / 487776 bytes in 24ms
D/dalvikvm( 680): GC freed 5527 objects / 232912 bytes in 21ms
D/dalvikvm( 680): GC freed 348 objects / 37104 bytes in 19ms
D/dalvikvm( 680): GC freed 778 objects / 48416 bytes in 26ms
D/dalvikvm( 680): GC freed 323 objects / 37232 bytes in 26ms
D/dalvikvm( 680): GC freed 476 objects / 29544 bytes in 27ms
D/dalvikvm( 680): Trying to load lib /system/lib/libwebcore.so 0x0
D/dalvikvm( 680): Added shared lib /system/lib/libwebcore.so 0x0
D/dalvikvm( 680): GC freed 443 objects / 26360 bytes in 27ms
D/dalvikvm( 680): GC freed 505 objects / 41488 bytes in 28ms
D/dalvikvm( 680): GC freed 540 objects / 38816 bytes in 28ms
D/dalvikvm( 680): GC freed 340 objects / 22304 bytes in 29ms
D/dalvikvm( 680): GC freed 339 objects / 18864 bytes in 29ms
D/dalvikvm( 680): GC freed 629 objects / 32160 bytes in 30ms
D/dalvikvm( 680): GC freed 14444 objects / 504472 bytes in 41ms
D/dalvikvm( 680): GC freed 11367 objects / 480056 bytes in 41ms
D/dalvikvm( 680): GC freed 6740 objects / 293144 bytes in 39ms
D/dalvikvm( 680): GC freed 753 objects / 43768 bytes in 35ms
D/dalvikvm( 680): GC freed 599 objects / 31720 bytes in 35ms
D/dalvikvm( 680): GC freed 416 objects / 26640 bytes in 36ms
I/Zygote ( 680): ...preloaded 1163 classes in 4311ms.
D/dalvikvm( 680): GC freed 313 objects / 19976 bytes in 37ms
I/Zygote ( 680): Preloading resources...
D/dalvikvm( 680): GC freed 54 objects / 11248 bytes in 37ms
D/dalvikvm( 680): GC freed 337 objects / 15032 bytes in 37ms
D/dalvikvm( 680): GC freed 264 objects / 11352 bytes in 38ms
I/Zygote ( 680): ...preloaded 48 resources in 446ms.
I/Zygote ( 680): ...preloaded 15 resources in 9ms.
D/dalvikvm( 680): GC freed 113 objects / 8296 bytes in 38ms
D/dalvikvm( 680): GC freed 195 objects / 7704 bytes in 38ms
D/dalvikvm( 680): GC freed 36 objects / 1392 bytes in 37ms
I/dalvikvm( 680): Splitting out new zygote heap
I/dalvikvm( 680): System server process 692 has been created
I/Zygote ( 680): Accepting command socket connections
D/dalvikvm( 692): Trying to load lib /system/lib/
libandroid_servers.so 0x0
D/dalvikvm( 692): Added shared lib /system/lib/libandroid_servers.so
0x0
I/sysproc ( 692): Entered system_init()
I/sysproc ( 692): ServiceManager: 0x158470
I/SurfaceFlinger( 692): SurfaceFlinger is starting
I/SurfaceFlinger( 692): SurfaceFlinger's main thread ready to run.
Initializing
graphics H/W...
E/MemoryHeapBase( 692): error opening /dev/pmem: No such file or
directory
E/GLLogger( 692): couldn't load <libhgl.so> library (Cannot find
library)
I/SurfaceFlinger( 692): EGL informations:
I/SurfaceFlinger( 692): # of configs : 6
I/SurfaceFlinger( 692): vendor : Android
I/SurfaceFlinger( 692): version : 1.31 Android META-EGL
I/SurfaceFlinger( 692): extensions:
I/SurfaceFlinger( 692): Client API: OpenGL ES
I/EGLDisplaySurface( 692): using (fd=22)
I/EGLDisplaySurface( 692): id = omapfb
I/EGLDisplaySurface( 692): xres = 640 px
I/EGLDisplaySurface( 692): yres = 480 px
I/EGLDisplaySurface( 692): xres_virtual = 640 px
I/EGLDisplaySurface( 692): yres_virtual = 960 px
I/EGLDisplaySurface( 692): bpp = 16
I/EGLDisplaySurface( 692): r = 11:5
I/EGLDisplaySurface( 692): g = 5:6
I/EGLDisplaySurface( 692): b = 0:5
I/EGLDisplaySurface( 692): width = 102 mm (159.372543 dpi)
I/EGLDisplaySurface( 692): height = 76 mm (160.421051 dpi)
I/EGLDisplaySurface( 692): refresh rate = 63.78 Hz
W/HAL ( 692): load: module=/system/lib/hw/copybit.omap3.so
error=Cannot fin
d library
W/HAL ( 692): load: module=/system/lib/hw/copybit.default.so
error=Cannot f
ind library
W/SurfaceFlinger( 692): ro.sf.lcd_density not defined, using 160 dpi
by default
I/SurfaceFlinger( 692): OpenGL informations:
I/SurfaceFlinger( 692): renderer : Android PixelFlinger 1.0
I/SurfaceFlinger( 692): version : OpenGL ES-CM 1.0
I/SurfaceFlinger( 692): extensions: GL_OES_byte_coordinates
GL_OES_fixed_point
GL_OES_single_precision GL_OES_read_format
GL_OES_compressed_paletted_texture GL
_OES_draw_texture GL_OES_matrix_get GL_OES_query_matrix
GL_ARB_texture_compressi
on GL_ARB_texture_non_power_of_two GL_ANDROID_direct_texture
GL_ANDROID_user_cli
p_plane GL_ANDROID_vertex_buffer_object GL_ANDROID_generate_mipmap
error=Cannot fin
d library
error=Cannot f
ind library
W/HAL ( 692): load: module=/system/lib/hw/overlay.omap3.so
error=Cannot fin
d library
W/HAL ( 692): load: module=/system/lib/hw/overlay.default.so
error=Cannot f
ind library
I/sysproc ( 692): System server: starting Android runtime.
I/sysproc ( 692): System server: starting Android services.
I/SystemServer( 692): Entered the Android system server!
I/sysproc ( 692): System server: entering thread pool.
I/SystemServer( 692): Starting Power Manager.
library)
I/SystemServer( 692): Starting Activity Manager.
I/ARMAssembler( 692): generated
scanline__00000077:03545404_00000A01_00000000 [
30 ipp] (51 ins) at [0x195590:0x19565c] in 274658 ns
I/SystemServer( 692): Starting telephony registry
I/SystemServer( 692): Starting Package Manager.
I/Installer( 692): connecting...
I/installd( 685): new connection
I/PackageManager( 692): Got library android.awt in /system/framework/
android.aw
t.jar
I/PackageManager( 692): Got library android.test.runner in /system/
framework/an
droid.test.runner.jar
I/PackageManager( 692): Got library com.android.im.plugin in /system/
framework/
com.android.im.plugin.jar
D/PackageManager( 692): Scanning app dir /system/framework
D/PackageManager( 692): Scanning app dir /system/app
D/dalvikvm( 692): GC freed 6099 objects / 252440 bytes in 63ms
I/PackageManager( 692): /system/app/SubscribedFeedsProvider.apk
changed; collec
ting certs
E/PackageManager( 692): Package com.android.providers.subscribedfeeds
requires
unavailable shared library com.google.android.gtalkservice; ignoring!
I/PackageManager( 692): /system/app/Development.apk changed;
collecting certs
D/dalvikvm( 692): GC freed 4600 objects / 308912 bytes in 59ms
E/PackageManager( 692): Package com.android.development requires
unavailable sh
ared library com.google.android.maps; ignoring!
D/PackageManager( 692): Scanning app dir /data/app
D/PackageManager( 692): Scanning app dir /data/app-private
I/PackageManager( 692): Time to scan packages: 1.252 seconds
W/PackageManager( 692): Unknown permission
com.google.android.googleapps.permis
sion.GOOGLE_AUTH in package com.android.providers.contacts
sion.GOOGLE_AUTH.cp in package com.android.providers.contacts
com.google.android.providers.gmail.p
ermission.WRITE_GMAIL in package com.android.settings
ermission.READ_GMAIL in package com.android.settings
sion.GOOGLE_AUTH in package com.android.settings
sion.GOOGLE_AUTH.mail in package com.android.calendar
sion.GOOGLE_AUTH in package com.android.providers.calendar
sion.GOOGLE_AUTH.cl in package com.android.providers.calendar
sion.GOOGLE_AUTH in package com.android.browser
sion.GOOGLE_AUTH.mail in package com.android.contacts
D/dalvikvm( 692): GC freed 4530 objects / 279496 bytes in 59ms
I/SystemServer( 692): Starting Content Manager.
W/ActivityManager( 692): Unable to start service Intent
{ action=android.accoun
ts.IAccountsService comp={com.google.android.googleapps/
eapps.GoogleLoginService} }: not found
W/AccountMonitor( 692): Couldn't connect to Intent
{ action=android.accounts.IA
.GoogleLoginService} } (Missing service?)
I/SystemServer( 692): Starting System Content Providers.
I/ActivityThread( 692): Publishing provider settings:
com.android.providers.set
tings.SettingsProvider
I/ActivityThread( 692): Publishing provider sync:
android.content.SyncProvider
I/SystemServer( 692): Starting Battery Service.
E/BatteryService( 692): Could not open '/sys/class/power_supply/ac/
online'
E/BatteryService( 692): Could not open '/sys/class/power_supply/usb/
online'
battery/present
battery/capacit
y'
battery/batt_vo
l'
battery/batt_te
mp'
battery/status'
battery/health'
battery/technol
ogy'
I/SystemServer( 692): Starting Hardware Service.
W/HAL ( 692): load: module=/system/lib/hw/lights.omap3.so
error=Cannot find
library
W/HAL ( 692): load: module=/system/lib/hw/lights.default.so
error=Cannot fi
nd library
E/power ( 692): Failed setting last user activity: g_error=0
I/SystemServer( 692): Starting Alarm Manager.
I/SystemServer( 692): Starting Sensor Service.
W/HAL ( 692): load: module=/system/lib/hw/sensors.omap3.so
error=Cannot fin
d library
W/HAL ( 692): load: module=/system/lib/hw/sensors.default.so
error=Cannot f
ind library
I/SystemServer( 692): Starting Window Manager.
E/EventHub( 692): could not add watch for /dev/input, No such file or
directory
E/EventHub( 692): scan dir failed for /dev/input
error=Cannot fin
d library
error=Cannot f
ind library
D/SensorManager( 692): found sensor: null, handle=0
I/SystemServer( 692): Starting Bluetooth Service.
I/SystemServer( 692): Starting Status Bar Service.
I/SystemServer( 692): Starting Clipboard Service.
I/SystemServer( 692): Starting Input Method Service.
W/ResourceType( 692): No package identifier when getting value for
resource num
ber 0x7f060000
I/InputManagerService( 692): Enabled input methods:
com.android.inputmethod.lat
in/.LatinIME
I/SystemServer( 692): Starting NetStat Service.
I/SystemServer( 692): Starting Connectivity Service.
I/WifiService( 692): WifiService starting up with Wi-Fi disabled
I/SystemServer( 692): Starting Notification Manager.
I/SystemServer( 692): Starting Mount Service.
I/SystemServer( 692): Starting DeviceStorageMonitor service
I/SystemServer( 692): Starting Location Manager.
D/libhardware_legacy( 692): no GPS hardware on this device
I/SystemServer( 692): Starting Search Service.
I/SystemServer( 692): Starting Checkin Service.
W/ActivityManager( 692): Unable to start service Intent { comp=
{com.google.andr
oid.server.checkin/
com.google.android.server.checkin.CheckinService} }: not foun
d
W/SystemServer( 692): Using fallback Checkin Service.
I/SystemServer( 692): Starting Wallpaper Service
D/WallpaperService( 692): WallpaperService startup
I/SystemServer( 692): Starting Audio Service
D/dalvikvm( 692): Trying to load lib /system/lib/libsoundpool.so 0x0
D/dalvikvm( 692): Added shared lib /system/lib/libsoundpool.so 0x0
W/AudioService( 692): Soundpool could not load file: /system/media/
audio/ui/Eff
ect_Tick.ogg
audio/ui/Key
pressStandard.ogg
audio/ui/Key
pressSpacebar.ogg
audio/ui/Key
pressDelete.ogg
audio/ui/Key
pressReturn.ogg
I/SystemServer( 692): Starting HeadsetObserver
W/HeadsetObserver( 692): This kernel does not have wired headset
support
I/SystemServer( 692): Starting AppWidget Service
I/WindowManager( 692): Menu key state: -1 safeMode=false
I/WindowManager( 692): Config changed: { scale=1.0 imsi=0/0
locale=en_US touch=
1 key=1/1/2 nav=1 orien=2 }
D/PowerManagerService( 692): system ready!
E/LockPatternKeyguardView( 692): Failed to bind to GLS while checking
for accou
nt
D/dalvikvm( 692): GC freed 4977 objects / 286760 bytes in 70ms
resource num
ber 0x7f030003
resource num
ber 0x7f030000
resource num
ber 0x7f030000
resource num
ber 0x7f03000c
D/ActivityManager( 692): Start running!
I/ActivityManager( 692): Starting activity: Intent
{ action=android.intent.acti
on.MAIN categories={android.intent.category.HOME} flags=0x10000000
comp={com.and
roid.launcher/com.android.launcher.Launcher} }
I/Zygote ( 692): Process: zygote socket opened
I/ActivityManager( 692): Start proc android.process.acore for
activity com.andr
oid.launcher/.Launcher: pid=729 uid=10000 gids={3003}
I/ActivityManager( 692): Start proc com.android.phone for added
application com
.android.phone: pid=740 uid=1001 gids={3002, 3001, 3003}
resource num
ber 0x00000000
W/StatusBar( 692): Icon not found in <system>: 0
I/ActivityThread( 729): Publishing provider user_dictionary:
com.android.provid
ers.userdictionary.UserDictionaryProvider
com.android.googlesearch.Suggestion
Provider: com.android.googlesearch.SuggestionProvider
I/ActivityThread( 729): Publishing provider contacts;call_log:
com.android.prov
iders.contacts.ContactsProvider
I/ActivityThread( 740): Publishing provider mms-sms:
com.android.providers.tele
phony.MmsSmsProvider
I/ActivityThread( 740): Publishing provider mms:
com.android.providers.telephon
y.MmsProvider
I/ActivityThread( 740): Publishing provider telephony:
lephony.TelephonyProvider
I/ActivityThread( 740): Publishing provider sms:
y.SmsProvider
W/AccountMonitor( 729): Couldn't connect to Intent
com.android.launcher.settings: com.
android.launcher.LauncherProvider
I/ActivityThread( 740): Publishing provider sim:
com.android.phone.SimProvider
{ action=com.android.us
sd.IExtendedNetworkService }: not found
D/PhoneApp( 740): Resetting audio state/mode: IDLE
D/BT HSHFP( 740): Starting BluetoothHeadsetService
D/CallNotifier( 740): onBatteryLow()...
D/StatusBar( 692): updateResources
D/dalvikvm( 729): GC freed 2802 objects / 191288 bytes in 126ms
I/ActivityManager( 692): Start proc com.android.mms for broadcast
com.android.m
ms/.transaction.MmsSystemEventReceiver: pid=767 uid=10011 gids={3003}
D/HomeLoaders( 729): load applications
D/HomeLoaders( 729): loading user items
D/HomeLoaders( 729): --> starting workspace loader
I/SurfaceFlinger( 692): Boot is finished (4660 ms)
locale=en_US touch=
scanline__00000077:03515104_00000000_00000000 [
27 ipp] (41 ins) at [0x18f880:0x18f924] in 213623 ns
D/dalvikvm( 692): GC freed 5265 objects / 252840 bytes in 120ms
I/ActivityManager( 692): Displayed activity
com.android.launcher/.Launcher: 165
6 ms
D/HomeLoaders( 729): --> starting applications loader
D/vold ( 677): Accepted connection from framework
D/vold ( 677): dispatch_cmd(send_ums_status):
D/MountListener( 692): handleEvent volume_nomedia:/sdcard
D/dalvikvm( 692): Trying to load lib /system/lib/libmedia_jni.so 0x0
D/MountListener( 692): handleEvent ums_disabled
D/MountListener( 692): handleEvent ums_disconnected
I/ActivityManager( 692): Start proc com.android.alarmclock for
broadcast com.an
droid.alarmclock/.AlarmInitReceiver: pid=781 uid=10001 gids={}
I/ActivityManager( 692): processNextBroadcast: waiting for
ProcessRecord{4368eb
78 781:com.android.alarmclock/10001}
I/ActivityThread( 781): Publishing provider com.android.alarmclock:
com.android
.alarmclock.AlarmProvider
D/dalvikvm( 692): Added shared lib /system/lib/libmedia_jni.so 0x0
D/dalvikvm( 692): Shared lib '/system/lib/libmedia_jni.so' already
loaded in sa
me CL 0x0
loaded in sa
me CL 0x0
loaded in sa
me CL 0x0
I/ActivityManager( 692): Start proc android.process.media for content
provider
com.android.providers.media/.MediaProvider: pid=799 uid=10004 gids=
{1006, 2001,
3003}
I/ActivityThread( 799): Publishing provider downloads:
com.android.providers.do
wnloads.DownloadProvider
I/ActivityThread( 799): Publishing provider drm:
com.android.providers.drm.DrmP
rovider
I/ActivityThread( 799): Publishing provider media:
com.android.providers.media.
MediaProvider
V/MediaProvider( 799): Attached volume: internal
I/ActivityManager( 692): Start proc com.android.calendar for
broadcast com.andr
oid.providers.calendar/.CalendarReceiver: pid=822 uid=10010 gids=
{3003}
D/MediaScannerService( 799): start scanning volume internal
I/ActivityThread( 822): Publishing provider calendar:
endar.CalendarProvider
D/ActivityManager( 692): checkComponentPermission() adjusting
{pid,uid} to {681
,1013}
D/dalvikvm( 799): Trying to load lib /system/lib/libmedia_jni.so 0x0
D/dalvikvm( 692): GREF has increased to 201
{pid,uid} to {681
,1013}
W/AccountMonitor( 822): Couldn't connect to Intent
{pid,uid} to {681
,1013}
{pid,uid} to {681
,1013}
E/MediaPlayerService( 681): Couldn't open fd for content://settings/system/noti
fication_sound
E/MediaPlayer( 692): Unable to to create media player
W/NotificationService( 692): error loading sound for content://settings/system/
notification_sound
W/NotificationService( 692): java.io.IOException: setDataSource
failed.: status
=0x80000000
W/NotificationService( 692): at
android.media.MediaPlayer.setDataSource(Nativ
e Method)
android.media.MediaPlayer.setDataSource(Media
Player.java:610)
W/NotificationService( 692): at android.media.AsyncPlayer$Thread.run
(AsyncPla
yer.java:76)
D/dalvikvm( 692): GC freed 7932 objects / 625736 bytes in 157ms
D/dalvikvm( 799): Added shared lib /system/lib/libmedia_jni.so 0x0
D/dalvikvm( 799): Shared lib '/system/lib/libmedia_jni.so' already
loaded in sa
me CL 0x0
loaded in sa
me CL 0x0
loaded in sa
me CL 0x0
D/MediaScanner( 799): opendir /system/media/ failed, errno: 2
D/MediaScanner( 799): prescan time: 124ms
D/MediaScanner( 799): scan time: 11ms
D/MediaScanner( 799): postscan time: 0ms
D/MediaScanner( 799): total time: 135ms
D/MediaScannerService( 799): done scanning volume internal
I/ActivityManager( 692): Stopping service:
com.android.calendar/.AlertService
com.android.providers.media/.MediaSc
annerService
com.android.mms/.transaction.SmsRece
iverService
com.android.providers.downloads/.Dow
nloadService
Sanjeev Kumar Verma
