I'm trying to find the default web server directory on my BeagleBone with Angstrom Linux. That is, where are the files served when I go to:
http://beaglebone.local:80
Another way would be to answer this question: How do I find out what directory a port number points to on my BeagleBone with Angstrom Linux?
Steve
2
That would depend on the webserver you are using. If you are using lighttpd or apache2 then the config files are under /etc/
If you are talking about the one that ships with the distribution it is actually a socket server that runs as a service. Easy to implement in bonescript
http://isolasoftware.it/2012/04/23/beaglebone-and-websockets-a-full-example-that-turn-onoff-a-led/
Thanks for this link. I was using the default bone server, but today I switched to lighttpd.
look for the index.html file in /usr/share/bone101/
