Where to get a replacement SD/MMC socket
Having inserted and removed SD cards huge numbers of times (I'm
working on code to read and write SD/SDHC/MMC), I have broken one of
the pins of the SD/MMC connector of my BB rev C4. Where can I get a
replacement, please?
I know that removing the existing one will be a challenge, but I
believe I can do it. Soldering a replacement on shouldn't present any
problem to me.
Dave
get a part number at search for it at digikey.com and mouser.com
2010/12/22 davehigton <davehigton@dsl.pipex.com>
I suggest you do an RMA. You can try and replace it yourself, but that will void the warranty. That of course is your call.
