where to get latest stable angstrom kernel with dvsdk with omapdmaifbsink
I want to work on gstreamer based work using ARM+DSP in beagleboard.
I went through the,
http://processors.wiki.ti.com/index.php/Example_GStreamer_Pipelines#Loopback:_Video_6, where its given like, if you are using Angstrom distribution on beagleboard then you can use “omapdmaifbsink” instead of “TIDmaiVideoSink” to display the video inside the X windowing system.
I want to use X windowing sytem.
Now, i am struck with where to begin,
  1. where to get the latest stable angstrom distribution with kernel and fs.
  2. where to get dvsdk with omapdmaifbsink for angstorm distribution.
  3. how to build it manually and test it.
Any pointers/suggestions would be helpful.
Thanks and Regards,
HarishKumar.V
I went through the,
http://processors.wiki.ti.com/index.php/Example_GStreamer_Pipelines#Loopback:_Video_6, where its given like, if you are using Angstrom distribution on beagleboard then you can use "omapdmaifbsink" instead of "TIDmaiVideoSink" to display the video inside the X windowing system.
1) where to get the latest stable angstrom distribution with kernel and fs.
www.angstrom-distribution.org/narcissus
2) where to get dvsdk with omapdmaifbsink for angstorm distribution.
www.angstrom-distribution.org/narcissus or www.angstrom-distribution.org/repo
3) how to build it manually and test it.
www.angstrom-distribution.org/building-angstrom
Could you next time search this mailinglist and/or use google before posting or just look at the angstrom frontpage?!?!?
