which file of X11 is used as kernel?
I have just built X11 kernel by command bitbake X11-image. I just don’t sure which file I should use to boot the kernel instead of uImage?
Best regards,
Thang Nguyen
But after build the X11-image, I want to know which files I should copy to SD card.
Is it right if I use these files:
Disk1:
+MLO
+u-boot.bin
+uImage
Disk2:
+unzip Angstrom-x11-image-glibc-ipk-2009.X-stable-beagleboard.rootfs.tar.bz2
I built X11-image after console-image, I didn’t see of an update version of uImage so I don’t know if I should use the uImage or should I force the compiler recompile the uImage?
Best regards,
Thang Nguyen
Hello Thang,
The X Window System is all userland. The kernel shouldn’t be any different.
The file system will be much larger than the one you get from ‘console-image’ with the addition of X Server, libs, fonts and demo apps.
best regards,
  • dan
Beside that, I think you need to untar the Angstrom-x11-image-glibc-ipk-2009.X-stable-beagleboard.rootfs.tar.bz2 to the ext partition of the SD card
Thanh
— On Wed, 8/19/09, Thang Nguyen airthang@gmail.com wrote:
> From: Thang Nguyen airthang@gmail.com
> Subject: [beagleboard] Re: which file of X11 is used as kernel?
> To: beagleboard@googlegroups.com
> Date: Wednesday, August 19, 2009, 10:17 PM
> Disk1:
> +MLO
> +u-boot.bin
> +uImage
> Disk2:
> Best regards,
> Thang Nguyen
