U-Boot SPL 2015.07-00129-g645e7d3 (Oct 08 2015 - 16:41:20)
DRA752 ES1.1
U-Boot 2015.07-00129-g645e7d3 (Oct 08 2015 - 16:41:20 -0500), Build: jenkins-github_Bootloader-Builder-245
CPU : DRA752 ES1.1
Board: BeagleBoard x15
I2C: ready
DRAM: 2 GiB
** Unable to use mmc 0:1 for loading the env **
Using default environment
SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
SCSI: SATA link 0 timeout.
scanning bus for devices…
Found 0 device(s).
cpsw
resetting USB…
USB0: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices… Device not responding to set address.
USB device not accepting new address (error=80000000)
2 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
USB device 0: unknown device
Reset SCSI
Target spinup took 0 ms.
Device 0: (0:0) Vendor: ATA Prod.: OCZ-AGILITY3 Rev: 2.25
Type: Hard Disk
Capacity: 228936.5 MB = 223.5 GB (468862128 x 512)
Found 1 device(s).
SCSI device 0:
Type: Hard Disk
… is now current device
Scanning scsi device 0
Checking for: /uEnv.txt …
Checking for: /boot/uEnv.txt …
bad MBR sector signature 0x0000
** Invalid partition 1 **
Info: input data size = 724274 = 0xB0D32
Checking if uname_r is set in /boot/uEnv.txt …
bad MBR sector signature 0xf5fe
** Invalid partition 2 **
** Invalid partition 3 **
** Invalid partition 4 **
switch to partitions #0, OK
mmc0 is current device
Scanning mmc device 0
260 bytes read in 21 ms (11.7 KiB/s)
debug: [uname_r=4.1.10-ti-r24] …
loading /boot/vmlinuz-4.1.10-ti-r24 …
8236568 bytes read in 433 ms (18.1 MiB/s)
loading /boot/dtbs/4.1.10-ti-r24/am57xx-beagle-x15.dtb …
156285 bytes read in 60 ms (2.5 MiB/s)
loading /boot/initrd.img-4.1.10-ti-r24 …
4417832 bytes read in 244 ms (17.3 MiB/s)
debug: [console=ttyO2,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M quiet] …
debug: [bootz 0x82000000 0x88080000:436928 0x88000000] …
Kernel image @ 0x82000000 [ 0x000000 - 0x7dae18 ]
Loading Ramdisk to 8fbc9000, end 8ffff928 … OK
Loading Device Tree to 8fb9f000, end 8fbc827c … OK
Starting kernel …
[ 3.469431] pci 0000:00:00.0: IOMMU is currently not supported for PCI
[ 4.590281] ata1: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen
[ 4.597722] ata1: irq_stat 0x00000040, connection status changed
[ 4.603766] ata1: SError: { CommWake DevExch }
Loading, please wait…
fsck from util-linux 2.25.2
rootfs: clean, 238677/1919232 files, 1797551/7791360 blocks
/init: 404: /init: touch: not found
[ 5.814671] systemd[1]: Job console-setup.service/start deleted to break ordering cycle starting with basic.target/start
[ 6.157302] systemd-fsck[196]: rootfs: clean, 238677/1919232 files, 1797551/7791360 blocks
[ 7.423756] remoteproc0: failed to load dra7-ipu1-fw.xem4
Debian GNU/Linux 8 BeagleBoard-X15 ttyS2
BeagleBoard.org Debian Image 2015-10-18
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
BeagleBoard-X15 login: root
Last login: Mon Dec 7 20:03:55 UTC 2015 on ttyS2
Linux BeagleBoard-X15 4.1.10-ti-r24 #3 SMP PREEMPT Sun Oct 25 10:13:57 PDT 2015 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@BeagleBoard-X15:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 10240 0 10240 0% /dev
tmpfs 379212 9912 369300 3% /run
/dev/mmcblk0p1 30618060 6643128 22679488 23% /
tmpfs 948028 4 948024 1% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 948028 0 948028 0% /sys/fs/cgroup
tmpfs 189608 0 189608 0% /run/user/1000
tmpfs 189608 0 189608 0% /run/user/0
John
