Why is there no successor for the BeagleBone Black/Green?
Is there an update to this idea of a BBB/G successor? At least in form factor?
I’m now so desperate for an AM6254-based BBB/BBG drop-in upgrade that I’m considering doing it myself. Although I appreciate the difficult problem of precise P8/P9 header compatibility from beagleboard.org’s viewpoint I don’t need this for my application. Hence why for me this is an “upgrade”, not a “BBB/G replacement”.
To illustrate my problem: Here is a spreadsheet of all modern Beagles (plus Octavo). Yellow indicates limitations and why none of the recent Beagles can be considered an upgrade from my perspective. The blue entry is my ideal BBB/G upgrade. Comments & corrections welcome.
(Yes, Beagle-to-cape adapter boards are being considered, e.g. Y-AI, but this has obvious problems)
it’s being worked on… There’s at least 4 designs in process on discord right now as we try to come up with the best universal “BBB Compatible” io…
Thank you very much Robert. I had no idea there was an active Discord discussing such things. I’m late to the party. As usual…
Edit: And for anyone else interested I found this within a few minutes
Do you have any ETA for this?
Its already arrived. Just look for Pocket Beagle2 or Pocket Beagle 2 Industrial. Both on sale
But I’ve asked about BBB-form factor board.
this summer..
Yes I can understand that, the beauty of the original beagle format of dual headers on left and right (taken from Ti Launchpad) led to many capes, and these were mechanically stable unlike the RPi capes. For what its worth the pocket beagle format is set up for click board, so also has the concept of widely available plug in boards.
Guess its a question of does that mechanical form factor of twin headers ever evolve. E.g. are there more pocket beagle format click boards than old beagle capes - has the world moved on. The only advantage I saw in the beagle format, is it enabled slight more pin out that the pocket interface has.
