I can setup my Asus N10 Wifi dongle to connect to my local network using wpa_supplicant.
I am trying to setup my BeagleBone so I can connect to it directly using Wifi. I think ad-hoc is the way to go?
However, I am a bit confused with wpa_supplicant since it is a “client” I think. It has some sample code for “ad-hoc” which I used. But when I run it, it seems to be trying to connect to an ad-hoc network as suppose to make one available for others to connect to.
Is wpa_supplicant the right tool for my purpose?
here is my config file for wpa_supplicant:
ap_scan=2 network={ ssid="my adhoc" mode=1 key_mgmt=NONE }
thx
