I have a Beaglebone Black with an rtl8169cu attached via usb. It apparently comes up in an invalid state during boot. This means I have to powercycle the USB bus to get it to start. I’ve reset the USB bus during boot with the following in /etc/rc.local as a workaround:
devmem2 0x47401c60 b 0x00
sleep 1
echo “usb1” > /sys/bus/usb/drivers/usb/unbind
sleep 20
echo “usb1” > /sys/bus/usb/drivers/usb/bind
sleep 1
devmem2 0x47401c60 b 0x01
systemctl restart connman-wait-online
By adding this wifi comes up at the end of the boot process, and connman-wait-online no longer shows as failed.
Unfortunately this mean that booting with wifi takes well over a minute. Both connman-wait-online, and a 22 second script need to run. dmesg output is below
Thanks in advance and let me know if there’s any further information I can provide!
[ 23.761353] rtl8192cu: Chip version 0x10
[ 23.867608] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 23.922520] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 24.749649] rtl8192cu: MAC address: 00:9e:95:9b:56:16
[ 24.749680] rtl8192cu: Board Type 0
[ 24.750696] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 24.750856] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[ 24.798308] ieee80211 phy0: Selected rate control algorithm ‘rtl_rc’
[ 24.810284] usbcore: registered new interface driver rtl8192cu
[ 24.812598] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 26.618448] asoc-simple-card sound: i2s-hifi <-> 48038000.mcasp mapping ok
[ 27.010110] cfg80211: World regulatory domain updated:
[ 27.010139] cfg80211: DFS Master region: unset
[ 27.010148] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 27.010161] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 27.010170] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 27.010179] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 27.010191] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 27.010201] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 27.010211] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 27.010219] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 27.010228] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 141.506192] usb 1-1: USB disconnect, device number 2
[ 141.506676] rtl_usb: reg 0x102, usbctrl_vendorreq TimeOut! status:0xffffffed value=0x80
[ 141.518118] rtl_usb: reg 0x422, usbctrl_vendorreq TimeOut! status:0xffffffed value=0x80208002
[ 141.526878] rtl_usb: reg 0x542, usbctrl_vendorreq TimeOut! status:0xffffffed value=0x80208002
[ 161.612842] hub 1-0:1.0: USB hub found
[ 161.618472] hub 1-0:1.0: 1 port detected
[ 162.061318] usb 1-1: new high-speed USB device number 3 using musb-hdrc
[ 162.193762] usb 1-1: New USB device found, idVendor=0bda, idProduct=8176
[ 162.193817] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 162.193848] usb 1-1: Product: 802.11n WLAN Adapter
[ 162.193877] usb 1-1: Manufacturer: 802.11n WLPN Adapter
[ 162.193906] usb 1-1: SerialNumber: 00e04c000001
[ 162.210429] rtl8192cu: Chip version 0x10
[ 162.322262] rtl8192cu: MAC address: 00:9e:95:9b:56:16
[ 162.322356] rtl8192cu: Board Type 0
[ 162.322593] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 162.322864] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[ 162.344819] ieee80211 phy1: Selected rate control algorithm ‘rtl_rc’
[ 162.391775] rtl8192cu: MAC auto ON okay!
[ 162.498403] rtl8192cu: Tx queue select: 0x05
[ 163.385799] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 164.175367] wlan0: authenticate with 00:25:9c:13:b0:84
[ 164.190122] wlan0: send auth to 00:25:9c:13:b0:84 (try 1/3)
[ 164.194594] wlan0: authenticated
[ 164.201239] wlan0: associate with 00:25:9c:13:b0:84 (try 1/3)
[ 164.207797] wlan0: RX AssocResp from 00:25:9c:13:b0:84 (capab=0x431 status=0 aid=10)
[ 164.312904] wlan0: associated
[ 164.330618] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 164.399682] cfg80211: Regulatory domain changed to country: US
[ 164.399717] cfg80211: DFS Master region: FCC
[ 164.399731] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 164.399751] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 164.399769] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 1700 mBm), (N/A)
[ 164.399786] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[ 164.399801] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 164.399815] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
