WiFi not working
Hello, I just bought a BBBW and I managed to connect to it through USB but when I try to connect to WiFi it throws the following error
enable wifi
Enabled wifi
scan wifi
Error /net/connman/technology/wifi: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Please run:
and copy the output to this thread..
if that doesn't exist, just run:
cat /etc/dogtag
and copy that output to this thread.
version.sh was not found
cat /etc/dogtag BeagleBoard.org Debian Image 2016-11-06
cat /etc/dogtag
So what's happening, in that old version "connman" is providing
"tether" services over wifi. So wlan0 is tied up. We changed this
later after the november release, you can use "tether wifi off" to
shut down down...
sudo connmanctl
tether wifi off
enable wif
scan wifi
services
agent on
connect wifi_*_managed_psk
quit
Or you can just reflash a new image from this week:
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Jessie_Snapshot_lxqt
which has SoftAp0 controlled by another application and connman is
able to scan without blocking from the tether interface.
It works!
Thanks a lot mate
