Wifi - troubleshooting assistance
Really need some help here. I have a project due at the end of the week for graduation and I cannot overcome the wifi issue. i’ve tried to wifi dongles and neither are working.
Any help is appreciated. At this point it seems to work except it will not connect or allow connections. I suspect something with the usb…but I don’t know where to go from this point
So far
  • Belkin n 150 surf micro.
  • Chipset is the realtek 8192cu
  • Kernel 3.2.18+
  • realtek source files from april 2012 compiled kernel module against source.
  • no rfkill blocks
http://pastebin.com/R6KnEaLb
wlan0 Link encap:Ethernet HWaddr 08:86:3B:1F:1F:76 UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 unassociated Nickname:“WIFI@REALTEK” Mode:Managed Frequency=2.412 GHz Access Point: Not-Associated Sensitivity:0/0 Retry:off RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality:0 Signal level:0 Noise level:0 Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0
if anyone cares…the answer seem to lie in connman.
My drivers and kernel were working perfectly, but connman seem to conflict with everything else.
i access my board over ethernet with ssh because I have a partner who is offsite and tests code on the board as well.
connman based on my interpretation of this document doesn’t allow multiple connections.
http://git.kernel.org/?p=network/connman/connman.git;a=blob_plain;f=doc/overview-api.txt;hb=HEAD
Check out this blog post:
http://www.gigamegablog.com/2012/02/06/beaglebone-linux-101-assigning-a-static-ip-address-with-connman/
connman is not easy to configure, its great for the initial plug and play setup but I had to removed it when I needed to make some use of the board.
btw, that blog has some other excellent posts you might be interested in.
