Does anyone know that if the watchdog timer is enabled, will a kernel panic still allow the watchdog to reset? Since it’s not an external watchdog, I wasn’t sure what would happen.
I’ve seen some cases where the kernel will panic and completely “brick” my device until it is manually rebooted. I haven’t had a chance to debug why the kernel panics at what seems like random times, so I need to do some investigation. However, my band-aid to the problem would be to enable the watchdog timer so that it will automatically reboot. I would just try it, but I’m having a hard time reproducing a kernel panic.
Also, on a side note, how do you change the default duration of 60 seconds? It seems like this info would be all over the internet, but I haven’t found anywhere that talks about this.
However, my first question regarding the kernel panic still remains. Also, if I do get a kernel panic, how do I record the error message/code so that I can debug it later?
Regarding rebooting on a panic, take a look at sysctl(8) and
kernel.panic. You may also be interested in kernel.panic_on_oops:
I don’t know of an easy way to record the information dumped from the panic.
Best way would be to use the Serial Debug interface. Either that, or some complex remote debug / logging system. Just a quick thought though. Perhaps moving all log files to an NFS share ?
