will tincan "flyswatter" JTAG be upward compatible to A8?
i can read here:
http://elinux.org/BeagleBoardOpenOCD
that, at the moment, openocd has only "basic" support for OMAP3 but
not yet Cortex A8. i'm assuming this is true but can i assume that,
if i buy the flyswatter and beagleboard adapter kit from here:
http://tincantools.com/product.php?productid=16134&cat=0&page=1
that HW will still apply when A8 support is added to openocd? thanks.
rday
Robert,
Robert P. J. Day wrote:
  i can read here:
BeagleBoardOpenOCD - eLinux.org
Yes, it is :wink:
There's actually some discussion how to add Cortex A8 support to OpenOCD
but unfortunately not a lot progress (?).
I'm not sure I got your question right. You want to know if Flyswatter will still work with OpenOCD & Beagle when OpenOCD supports Cortex A8?
Note that Flyswatter is HW only, while OpenOCD is SW (and Cortex A8 support is SW, too). Having Cortex A8 support (i.e. OpenOCD knows how to deal with Cortex A8 JTAG/debug registers etc.) in OpenOCD is the *requirement* for (GDB) debugging via Flyswatter.
That is, Cortex A8 support in OpenOCD is *necessary* to use Flyswatter (for GDB debugging). Thus, the answer to your question (if I got it right) is: Yes.
Dirk
Btw.: If somebody likes/is able to help with adding Cortex A8 support to OpenOCD, this would be greatly appreciated!
i realized the difference between the SW and HW aspects of the
above, i just wanted to verify that adding the (eventual?) openocd SW
support for cortex A8 wouldn't require some sort of HW mod.
rday
Hi Dirk,
I might have a little time and find this topic very interesting. I would
therefore like to hear a little about what it takes to help OpenOCD forward.
I have basic knowledge of JTAG and the OMAP-emulation-system in general.
Furthermore I have access to a working CCS JTAG setup, which might show
useful as well :slight_smile:
I however have absolutely no knowledge about OpenOCD and very little about
GDB...
In case you can match this with what you need to get going in anyway, please
let me know, and let's see if we can find a way forward...
Best regards
  Søren
Søren,
Hi Dirk,
GDB...
Same here :wink:
General good starting point could be
As mentioned there, we already can access "ARM JTAG device" and now have to 'teach' OpenOCD how to deal with Cortex A8 JTAG (registers?).
OpenOCD already supports Cortex M3. It's my understanding that we need now something similar for Cortex A8 like
http://svn.berlios.de/svnroot/repos/openocd/trunk/src/target/cortex_m3.c
Next step would be to have look to
and try to understand it :wink:
Have a look to above and see if you can get an idea what's needed.
Many thanks!
Dirk
Dirk Behme wrote:
Søren,
Hi Dirk,
GDB...
Same here :wink:
https://lists.berlios.de/pipermail/openocd-development/2009-March/005097.html OpenOCD - Open On-Chip Debugger - berlios.de OpenOCD - Open On-Chip Debugger - berlios.de
Just fyi: At OpenOCD mailing list Rick Altherr wrote a nice intro how to help with Cortex A8 support for OpenOCD. I tried to summarize it in
http://elinux.org/BeagleBoardOpenOCD#Cortex_A8_support
Best regards
Dirk
FWIW, the documents that require you to be a "registered ARM customer" just mean you need to create an account usually. I don't believe you need to work for any specific company or have any real agreement with ARM.
