Hi
I am using the latest Debian image from here Debian (BeagleBone, BeagleBone Black - 4GB SD) 2015-03-01
root@beaglebone:~# uname -a
Linux beaglebone 3.8.13-bone70 #1 SMP Fri Jan 23 02:15:42 UTC 2015 armv7l GNU/Linux
I am following the instructions from here http://lanceme.blogspot.com.au/2013/06/windows-7-internet-sharing-for.html
however unable to ping ping www.google.com
root@beaglebone:~# ifconfig
eth0 Link encap:Ethernet HWaddr 7c:66:9d:58:87:70
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:40
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:0
usb0 Link encap:Ethernet HWaddr ea:a2:3b:46:5d:59
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
inet6 addr: fe80::e8a2:3bff:fe46:5d59/64 Scope:Link
RX packets:483 errors:0 dropped:0 overruns:0 frame:0
TX packets:45 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:179805 (175.5 KiB) TX bytes:11212 (10.9 KiB)
root@beaglebone:~# route add default gw 192.168.7.1
root@beaglebone:~# echo “nameserver 8.8.8.8” >> /etc/resolv.conf
root@beaglebone:~# ping www.google.com
ping: unknown host www.google.com
root@beaglebone:~#
btw, is the connman running there. When I did
root@beaglebone:~# systemctl disable connman.service
Failed to issue method call: No such file or directory
root@beaglebone:~#
Jan
