I was running the 10-29-15 version of Ubuntu. So, I decided to update to the 01-06-15 version of the flasher Ubuntu. I flashed the device, rebooted it, and everything appeared to run fine.
So, I then went to plug in the USB cable to my Windows 8 PC. I do not see the BBB as a network device. I do however see it listed as device ELMO GMAS (COM5).
When I previously flashed the device, it definitely showed up as a network device and I was able to SSH to it. So, I don’t know what I did differently in this case or if the new version of Ubuntu is even a factor at all.
I am sort of stuck.
I also tried to connect Putty to the BBB over serial, but I could not get that working either.
