Have you considered using the AM3894 on a future Beagleboard?
http://focus.ti.com/docs/prod/folders/print/am3894.html
The AM3894 is available through distributors because it’s already
listed on digikey and farnell with prices but with zero stock at
present. TI classifies the AM3894 as suitable for single board
computing amongst others.
Here is my wish list.
Standard Memory Module Socket(s)
Having looked at building our own beagleboard variant, pop memory
complicates manufacturing and therefore increases production cost to
some extent. And it’s not possible to increase memory capacity post
production.
Rather than using pop memory it would be great to have a standard DDR2/
DDR3 memory socket so that we could decide how much memory we wanted
to fit ourselves. Fitting a socket must be cheaper than fitting pop
memory. Would DDR2/DDR3 memory modules be cheaper than pop memory?
Does anyone have an idea? The AM3894 has DDR2/DDR3 support.
SATA Interface
Current beagleboards can only use flash based file systems via SD/MMC
or USB Flash devices or use a USB to SATA bridge to connect a hard
disk or SSD. Flash based file systems tend to be slow and I don’t
think anyone has reported that they have got a USB to SATA bridge
working successfully. It’s not referred to in the reference manual.
Correct me if I’m wrong.
It would be fantastic to see a beagleboard with a true SATA
controller. We could then easily connect either a hard disk or an SSD.
The AM3894 has an SATA interface.
PCIe 2.0 Interface
Current beagleboards have the expansion connector(s) which is great
and it should be retained. If the beagleboard had a PCIe 2.0 interface
you could buy many PCIe 2.0 peripherals. The main one I’m thinking of
is a wireless interface but it could be additional SATA ports or a
USB3.0 port when they finally arrive. The AM3894 has a PCIe2.0
interface.
Ethernet Interface
The beagleboard xm has a USB ethernet bridge chip. However it would
not be needed if the processor had an embedded ethernet controller. If
more USB ports are needed you could buy a USB hub and plug it in as on
the original beagleboard. The AM3894 has embedded ethernet interface.
Disadvantages of using the AM3894
According to digikey, the AM3894 is likely to be more expensive than
the AM37x but the extra functionally would be worth the extra cost.
And it’s a shame the AM3894 is not a dual core device. Maybe there is
one on the drawing board??
