Hi Folks,
perhaps someone can help. If have a WLAN USB device with the RT8192CU chipset. And I have problems to connect my beaglebone to my local dsl router.
I use the kernel v3.2.9+. The firmware exists.
Here are some results of the following steps:
- Plug in the wlan stick: The following appears in /var/log/messages
Mar 31 15:45:41 beaglebone user.info kernel: [ 358.750369] usb 1-1.1: new high-speed USB device number 4 using musb-hdrc
Mar 31 15:45:41 beaglebone user.info kernel: [ 358.851520] usb 1-1.1: New USB device found, idVendor=0bda, idProduct=8176
Mar 31 15:45:41 beaglebone user.info kernel: [ 358.851541] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 31 15:45:41 beaglebone user.info kernel: [ 358.851556] usb 1-1.1: Product: 802.11n WLAN Adapter
Mar 31 15:45:42 beaglebone user.info kernel: [ 358.851568] usb 1-1.1: Manufacturer: 802.11n WLPN Adapter
Mar 31 15:45:42 beaglebone user.info kernel: [ 358.851579] usb 1-1.1: SerialNumber: 00e04c000001
Mar 31 15:45:42 beaglebone user.info kernel: [ 358.902903] rtl8192cu: MAC address: 00:9c:95:98:b4:bc
Mar 31 15:45:42 beaglebone user.info kernel: [ 358.902936] rtl8192cu: Board Type 0
- I tried ifconfig -a and the following appears
wlan0 Link encap:Ethernet HWaddr 00:9C:95:98:B4:BC
BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
- I run iwconfig and this is the result
root@beaglebone:~# iwconfig
lo no wireless extensions.
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry long limit:7 RTS thr=2347 B Fragment thr:off
Encryption key:off
Power Management:on
eth0 no wireless extensions.
- I use the following configuration
4.1. /etc/network/interfaces
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant.conf
wpa-driver wext
4.2. wpa_supplicant.conf:
ctrl_interface=/var/run/wpa_supplicant
eapol_version=1
ap_scan=1
fast_reauth=1
network={
ssid=“MYSSID”
scan_ssid=1
proto=WPA RSN
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
psk=“MYWPAPSK”
- After I invoke ifup wlan0 the following apperas
5.0. After a while an before invoking the command the following apperas in /var/log/messages
Mar 31 15:46:12 beaglebone daemon.err udevd[57]: worker [181] terminated by signal 9 (Killed)
5.1. Direct after the command
root@beaglebone:~# ifup wlan0
udhcpc (v1.19.3) started
Sending discover…
Sending discover…
Sending discover…
No lease, failing
5.2. Observed in /var/log/messages
Mar 31 15:53:48 beaglebone user.info kernel: [ 844.930405] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Mar 31 15:53:48 beaglebone user.notice root: Checking for WLAN association…
Mar 31 15:53:48 beaglebone user.notice root: No association yet, 15 retries until timeout
Mar 31 15:54:02 beaglebone user.notice root: No association yet, 1 retries until timeout
Mar 31 15:54:03 beaglebone user.notice root: Timeout waiting for association, continuing anyway…
5.3. The red status led on the usb device is switched on
- Running iwconfig again shows this
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Encryption key:off
Power Management:off
7. rfkill delivers the following result
root@beaglebone:~# rfkill list
1: phy1: Wireless LAN
Soft blocked: no
Hard blocked: no
So after all, there was not a chance to make a connect from beaglebone to my local DSL router.
Has somebody a solution for this?
Thanks in advance and kind regards,
Gerrit
