Having installed the Edimax USB WiFi dongle, I am getting sttrange behaviour:
If my ethernet cable is plugged in, WiFi works. But if I unplug the cable, WiFi stops working and does not get alive after reboot.
I connect through USB and can find the following:
iwconfig
wlan0 IEEE 802.11bgn ESSID:“KangYatze”
Mode:Managed Frequency:2.432 GHz Access Point: 00:0C:F6:D6:6A:F0
Bit Rate=150 Mb/s Tx-Power=20 dBm
Retry long limit:7 RTS thr=2347 B Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=31/70 Signal level=-79 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:1 Missed beacon:0
lo no wireless extensions.
eth0 no wireless extensions.
usb0 no wireless extensions.
ifconfig
eth0 Link encap:Ethernet HWaddr 90:59:af:4e:19:7f
inet addr:192.168.0.132 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:56
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:100 errors:0 dropped:0 overruns:0 frame:0
TX packets:100 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:9128 (9.1 KB) TX bytes:9128 (9.1 KB)
usb0 Link encap:Ethernet HWaddr a2:75:01:e1:d0:93
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
inet6 addr: fe80::a075:1ff:fee1:d093/64 Scope:Link
RX packets:5212 errors:0 dropped:0 overruns:0 frame:0
TX packets:127 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:431464 (431.4 KB) TX bytes:24602 (24.6 KB)
wlan0 Link encap:Ethernet HWaddr 80:1f:02:ae:ee:ce
inet addr:192.168.0.133 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::821f:2ff:feae:eece/64 Scope:Link
RX packets:191 errors:0 dropped:0 overruns:0 frame:0
TX packets:9 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:15359 (15.3 KB) TX bytes:1054 (1.0 KB)
lsusb
Bus 001 Device 002: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lsmod | grep rtl8192cu
rtl8192cu 88700 0
rtlwifi 78422 1 rtl8192cu
rtl8192c_common 60882 1 rtl8192cu
mac80211 500877 3 rtlwifi,rtl8192c_common,rtl8192cu
cat interfaces
The loopback network interface
auto lo
iface lo inet loopback
WiFi
auto wlan0
iface wlan0 inet static
address 192.168.0.133
netmask 255.255.255.0
gateway 192.168.0.1
dns-nameservers 213.46.228.196 62.179.104.196
wpa-ssid “"
wpa-psk "”
(ssid and key made unreadable for this pub, however they can not be doubted as the
connection works if eth0 activated)
wired ethernet
auto eth0
iface eth0 inet static
address 192.168.0.132
gateway 192.168.0.1
Ethernet/RNDIS gadget (g_ether)
… or on host side, usbnet and random hwaddr
iface usb0 inet static
address 192.168.7.2
network 192.168.7.0
gateway 192.168.7.1
I can see nothing missing, and the blue led in the dongle is on.
Any help is highly appreciated!
