Woes rebuilding & booting Angstrom on my beaglebone
I've started tinkering with my (A3) beaglebone, which works just fine using
either the supplied SD card, or alternative SD cards using the 'official' images:
* Angstrom-Cloud9-IDE-GNOME-eglibc-ipk-v2012.05-beaglebone-2012.05.09.img.xz
* Angstrom-Cloud9-IDE-eglibc-ipk-v2012.04-core-beaglebone-2012.04.09.img.xz
(only the second has anything in /sys/class/pwm/ ...)
But now I want to build my own image, to enable all 6 pwm outputs. So I
bitbake 'cloud9-image' for the beaglebone (as per
<http://beaglebone.cameon.net/home/building-the-demo-image-files>)
The problems so far:
1) Had a problem with libpam (same as
<https://groups.google.com/d/topic/beagleboard/5AWfEH9nT4Y/discussion> I
think), but it solved itself I don't know how;
2) Some files don't download automatically (same as
<https://groups.google.com/d/topic/beagleboard/aMrS06suLOs/discussion>), so I
had to download them into sources/downloads and add the '%.done' file in there
as well;
3) genext2fs fails with a ftruncate() error. I backed out a commit on the
recipe for the SD card, it apparently solved the problem (details posted in
this thread
<https://groups.google.com/d/topic/beagleboard/KHnzw2GR2eo/discussion>).
Now the bitbake creates an image just fine, that I can dump on a SD card.
Except... the beaglebone doesn't seem to boot. I don't get anything on the USB
port (no gadgets are visible), and the ethernet port doesn't get active.
I'm must be doing something wrong, but I can't figure out why... any help
appreciated.
Cordially,
