I configure my BBB for my system. I disable the USB connect to Windows and other stuffs.
Now I want to copy this one to another for backup.
But when I copy the eMMC to my Linux machine with:
dd if=/dev/mmcblk0 bs=1M | ssh martin@192.168.1.67 'dd of=/home/martin/Documents/path/to/backup/origBBB.img bs=1M'
It work and generate the img
I flash this on a new sd card and try to flash the eMMC with holding S2 Button before power up.
But it seems not working ... the heartbeat LED is running and the CPu is flashing always a little bit.
Did I miss some files on the sd card for flashing the image on the eMMC?
Thank you!
You are not alone buddy!
I just booted up the BBB rev C with a blank 8gb sd card, ran /opt/scripts/tools/eMMC/beaglebone-black-make-microSD-flasher-from-eMMC.sh on one BBB.
Then I moved the sd card to another BBB and used /opt/scripts/tools/beaglebone-black-eMMC-flasher.sh to put the image back on to the eMMC but first I had to fix an error in the script.
unset root_uuid
root_uuid=$(/sbin/blkid -s UUID -o value ${destination}p2)
if [ “${root_uuid}” ] ; then
I do not have that directory on any of my BBB rev C.
So I modified it by just deleting the “Normal” part.
Now both cp line look like this, cp -v /boot/uboot/MLO
The scripts works but I still seem to have some issues as it boots in to Emergency mode.
I really can’t believe this BBB is so resistant to re-flashing! Pain in my butt!
And I am not the only one. Just do a Google and look at all the people having trouble doing a simple flash!
on one BBB.
