In the following page:-
http://elinux.org/BeagleBoardUbuntu#eMMC:_BeagleBone_Black
It says:-
Flasher
eMMC: BeagleBone Black
This image can be written to a 2GB (or larger) microSD card, via 'dd'
on linux or the win32 image program linked to on CircuitCo's wiki
page. First press and hold the boot select button (next to the microSD
card), then apply power (same procedure as the official CircuitCo
images). The board should boot into Ubuntu and begin flashing the
eMMC, once completed all 4 LED's should be full ON. Simply remove
power, remove the microSD card and Ubuntu will now boot directly from
eMMC.
I don't really follow this. Using the instructions elsewhere on the
same web page I have written Ubuntu 13.10 for the BBB onto a micro SD
card and it boots successfully from this. So does this mean I have
*already* done (using the script) what's described in the first
sentence above using dd?
If so should I just be able now to do what is described in the
subsequent sentences?
Finally, if this works, can I just plug in a micro SD card that
*doesn't* have an image file on it and use the space on it? I realise
that I have to format it and mount it of course.
BeagleBoardUbuntu - eLinux.org
It says:-
Flasher
eMMC.
The "instructions" are generic and the same for both images. On first
bootup the "flasher" image is setup to automatically flash the "eMMC".
Whereas the raw "bone" image just runs from the microSD.
BTW, if you've already flashed the "bone" image to a microSD and have
booted it up, you can easily transfer that image to the eMMC via:
cd /opt/scripts/
./tools/beaglebone-black-eMMC-flasher.sh
(this is the same script the "flasher" image runs on bootup..)
*doesn't* have an image file on it and use the space on it? I realize
Yes you can use it as secondary storage, just don't have a file named
"uEnv.txt" on the microSD with a variable called "uenvcmd" in it.
> It says:-
> Flasher
> eMMC.
OK, I hadn't realised that there are two images, one that
automatically tranfers itself to eMMC and the other that just works
from the microSD card.
cd /opt/scripts/
OK, I did actually work this out for myself in the end and now have
Ubuntu running from the eMMC
OK, thanks, I think I'm all set now!
