I was trying to re-program my board with x-loader and latest u-boot image. At this moment, the only interface that I can use is the serial communication and I cannot configure the board to boot on sd card because I erased the u-boot.
I tried this command for x-loader and it works:
./pserial -p /dev/ttyUSB0 -f x-load.bin
But, when I tried the ukermit, I am getting error (see error below)
./ukermit -p /dev/ttyUSB0 -f u-boot.bin
Failed after 4 retries in sequence 0 - success send = 0 bytes
Data transmit failed
What if I messed up the x-loader too?. Does the board is still capable of
booting on SD card?
Yes it does In case you hold the USER-button during power on. The OMAP ROM
code will then try to read the MLO file from the MMC card in this case. More
info to be found in chapter 25.4.7.6 of the OMAP3 TRM (spruf98g.pdf)
Hi Guys,
erased the u-boot.
How do you know loading x-load.bin works? Do you see some messages
back over the serial port? Where did you get the x-load.bin? Are you
sure you meant to use x-load.bin and not x-load.bin.ift?
