Hi..
1 week ago, because of some guy's help, I refreshed my nand..
and I installed angstrom in my SD.
But I can't run the X window.
After type the just X in console, just met the below message
Fatal server
error:
Server is already active for display
0
If this server is no longer running, remove /tmp/.X0-
lock
and start again.
Actually, I can see the doggy, in booting time..
but after boot, I can't see anything..
below is my xdpyinfo..
and resolution of my lcd is 1366x768.
root@beagleboard:/#
xdpyinfo
name of display: :
0.0
version number:
11.0
vendor string: The X.Org
Foundation
vendor release number:
10503000
X.Org version:
1.5.3
maximum request size: 16777212
bytes
motion buffer size:
256
bitmap unit, bit order, padding: 32, LSBFirst,
32
image byte order:
LSBFirst
number of supported pixmap formats:
7
supported pixmap
formats:
depth 1, bits_per_pixel 1, scanline_pad
32
depth 4, bits_per_pixel 8, scanline_pad
32
depth 8, bits_per_pixel 8, scanline_pad
32
depth 15, bits_per_pixel 16, scanline_pad
32
depth 16, bits_per_pixel 16, scanline_pad
32
depth 24, bits_per_pixel 32, scanline_pad
32
depth 32, bits_per_pixel 32, scanline_pad
32
keycode range: minimum 8, maximum
255
focus:
PointerRoot
number of extensions:
25
BIG-
REQUESTS
Composite
DAMAGE
DOUBLE-
BUFFER
DPMS
Extended-Visual-
Information
MIT-SCREEN-
SAVER
MIT-
SHM
MIT-SUNDRY-
NONSTANDARD
RANDR
RENDER
SHAPE
SYNC
TOG-
CUP
X-
Resource
XC-
MISC
XFIXES
XFree86-
DGA
XFree86-
Misc
XFree86-
VidModeExtension
XINERAMA
XInputExtension
XKEYBOARD
XTEST
XVideo
default screen number:
0
number of screens:
1
screen
#0:
print screen:
no
dimensions: 1366x768 pixels (361x203
millimeters)
resolution: 96x96 dots per
inch
depths (7): 16, 1, 4, 8, 15, 24,
32
root window id:
0x3d
depth of root window: 16
planes
number of colormaps: minimum 1, maximum
1
default colormap:
0x20
default number of colormap cells:
64
preallocated pixels: black 0, white
65535
options: backing-store NO, save-unders
NO
largest cursor:
1366x768
current input event mask:
0x400003
KeyPressMask KeyReleaseMask
PropertyChangeMask
number of visuals:
2
default visual id:
0x21
visual:
visual id:
0x21
class:
TrueColor
depth: 16
planes
available colormap entries: 64 per
subfield
red, green, blue masks: 0xf800, 0x7e0,
0x1f
significant bits in color specification: 6
bits
visual:
visual id:
0x3b
class:
TrueColor
depth: 32
planes
available colormap entries: 256 per
subfield
red, green, blue masks: 0xff0000, 0xff00,
0xff
significant bits in color specification: 8 bits
