X server problem
After booting when I start the xserver via command line Iam getting
follwing error.
[ 265.591] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 265.594] (II) Module fb: vendor="X.Org Foundation"
[ 265.594] compiled for 1.9.0, module version = 1.0.0
[ 265.595] ABI class: X.Org ANSI C Emulation, version 0.4
[ 265.595] (--) Depth 24 pixmap format is 32 bpp
[ 265.595] (EE) FBDEV(0): FBIOPUT_VSCREENINFO succeeded but modified
mode
[ 265.596] (EE) FBDEV(0): mode initialization failed
[ 265.596]
Fatal server error:
[ 265.596] AddScreen/ScreenInit failed for driver 0
Following is the boot log and Xorg log
Boot Log
Texas Instruments X-Loader 1.4.4ss (Jan 5 2011 - 10:23:55)
Beagle xM Rev A
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.03-dirty (Dec 27 2010 - 10:24:02)
OMAP3630/3730-GP ES2.0, CPU-OPP2, L3-165MHz,
I2C: ready
DRAM: 512 MB
NAND: 0 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Probing for expansion boards, if none are connected you'll see a
harmless I2C error.
No EEPROM on expansion board
Beagle xM Rev A
Die ID #6c0400011ff00000015739eb0802f028
mmc1 is available
The user button is currently NOT pressed.
reading boot.scr
634 bytes read
Running bootscript from mmc ...
## Executing script at 80200000
Booting MeeGo Community Image
mmc1 is available
reading uImage
4045596 bytes read
## Booting kernel from Legacy Image at 80300000 ...
   Image Name: Linux-2.6.37
   Data Size: 4045532 Bytes = 3.9 MB
   Load Address: 80008000
   Entry Point: 80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.37 (ic001252@blrkaptHPNB) (gcc
version 4.5.1 (Ubuntu/Linaro 4.5.1-7ubuntu1) ) #18 PREEMPT Tue Feb 15
10:20:06 IST 2011
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing
instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Reserving 6291456 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630 ES1.1 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x10000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 126976
[ 0.000000] Kernel command line: console=ttyO2,115200n8
console=tty0 root=/dev/sda1 rootwait ro omapfb.vram=${vram}
omapfb.mode=dvi:${dvimode} fixrtc mpu}
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6,
262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072
bytes)
[ 0.000000] allocated 2621440 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't
want memory cgroups
[ 0.000000] Memory: 500MB = 500MB total
[ 0.000000] Memory: 496348k/496348k available, 27940k reserved, 0K
highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xe0800000 - 0xf8000000 ( 376 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0040000 ( 224 kB)
[ 0.000000] .text : 0xc0040000 - 0xc079f63c (7550 kB)
[ 0.000000] .data : 0xc07a0000 - 0xc07e87a0 ( 290 kB)
[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0,
CPUs=1, Nodes=1
[ 0.000000] Preemptable hierarchical RCU implementation.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] Verbose stalled-CPUs detection is disabled.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.000000] Calibrating delay loop... 493.67 BogoMIPS (lpj=1929216)
[ 0.000000] pid_max: default: 32768 minimum: 301
[ 0.000000] Security Framework initialized
[ 0.000000] SELinux: Disabled at boot.
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] Initializing cgroup subsys ns
[ 0.000000] ns_cgroup deprecated: consider using the
'clone_children' flag without the ns_cgroup.
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Initializing cgroup subsys memory
[ 0.000000] Initializing cgroup subsys devices
[ 0.000000] Initializing cgroup subsys freezer
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] regulator: core version 0.5
[ 0.000000] regulator: dummy:
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] OMAP3 Beagle Rev: xM
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.000000] OMAP DMA hardware revision 5.0
[ 0.004608] bio: create slab <bio-0> at 0
[ 0.005615] SCSI subsystem initialized
[ 0.006927] usbcore: registered new interface driver usbfs
[ 0.007049] usbcore: registered new interface driver hub
[ 0.007263] usbcore: registered new device driver usb
[ 0.007659] i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600 kHz
[ 0.016235] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.016296] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.016784] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.027282] regulator: VUSB1V5: 1500 mV normal standby
[ 0.027740] regulator: VUSB1V8: 1800 mV normal standby
[ 0.028137] regulator: VUSB3V1: 3100 mV normal standby
[ 0.041595] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 0.053314] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal
standby
[ 0.053771] regulator: VDAC: 1800 mV normal standby
[ 0.054199] regulator: VDVI: 1800 mV normal standby
[ 0.054718] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal
standby
[ 0.065521] i2c_omap i2c_omap.3: bus 3 rev4.0 at 100 kHz
[ 0.066528] Advanced Linux Sound Architecture Driver Version
1.0.23.
[ 0.067077] NetLabel: Initializing
[ 0.067108] NetLabel: domain hash size = 128
[ 0.067138] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.067230] NetLabel: unlabeled traffic allowed by default
[ 0.067260] Switching to clocksource 32k_counter
[ 0.085693] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 0.090667] musb_hdrc musb_hdrc: USB OTG mode controller at
fa0ab000 using DMA, IRQ 92
[ 0.091094] NET: Registered protocol family 2
[ 0.091369] IP route cache hash table entries: 4096 (order: 2,
16384 bytes)
[ 0.092224] TCP established hash table entries: 16384 (order: 5,
131072 bytes)
[ 0.092590] TCP bind hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.092834] TCP: Hash tables configured (established 16384 bind
16384)
[ 0.092864] TCP reno registered
[ 0.092895] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.092926] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.093200] NET: Registered protocol family 1
[ 0.093750] RPC: Registered udp transport module.
[ 0.093780] RPC: Registered tcp transport module.
[ 0.093811] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 0.094757] omap_dsp_init: 600000 bytes @ 9f400000
[ 0.095275] audit: initializing netlink socket (disabled)
[ 0.095367] type=2000 audit(0.335:1): initialized
[ 0.246520] VFS: Disk quotas dquot_6.5.2
[ 0.246887] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 0.251586] fuse init (API version 7.15)
[ 0.253173] Btrfs loaded
[ 0.253234] msgmni has been set to 969
[ 0.255035] Block layer SCSI generic (bsg) driver version 0.4
loaded (major 254)
[ 0.255096] io scheduler noop registered
[ 0.255126] io scheduler deadline registered
[ 0.255371] io scheduler cfq registered (default)
[ 0.317504] OMAP DSS rev 2.0
[ 0.317596] OMAP DISPC rev 3.0
[ 0.317657] OMAP VENC rev 2
[ 0.646118] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.762878] omap-hsuart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a
OMAP UART0
[ 0.793975] omap-hsuart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a
OMAP UART1
[ 0.825225] omap-hsuart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a
OMAP UART2
[ 1.496337] console [ttyO2] enabled
[ 1.520538] omap-hsuart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a
OMAP UART3
[ 1.559112] brd: module loaded
[ 1.565948] loop: module loaded
[ 1.570861] OneNAND driver initializing
[ 1.575317] usbcore: registered new interface driver cdc_ether
[ 1.581481] usbcore: registered new interface driver rndis_host
[ 1.588195] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 3.606445] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.612640] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 1
[ 3.622222] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 3.637756] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.644500] hub 1-0:1.0: USB hub found
[ 3.648498] hub 1-0:1.0: 3 ports detected
[ 3.676940] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.683593] usbcore: registered new interface driver uas
[ 3.689178] Initializing USB Mass Storage driver...
[ 3.694427] usbcore: registered new interface driver usb-storage
[ 3.700744] USB Mass Storage support registered.
[ 3.705902] mice: PS/2 mouse device common for all mice
[ 3.712463] input: twl4030_pwrbutton as /devices/platform/i2c_omap.
1/i2c-1/1-0049/twl4030_pwrbutton/input/input0
[ 3.723724] i2c /dev entries driver
[ 3.727783] Linux media interface: v0.10
[ 3.732055] lirc_dev: IR Remote Control driver registered, major
250
[ 3.738800] IR RC5 (streamzap) protocol handler initialized
[ 3.744659] IR LIRC bridge handler initialized
[ 3.749511] omap_device: omap_wdt.-1: new worst case activate
latency 0: 30517
[ 3.757537] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 3.764526] device-mapper: uevent: version 1.0.3
[ 3.769927] device-mapper: ioctl: 4.18.0-ioctl (2010-06-29)
initialised: dm-devel@redhat.com
[ 3.779113] device-mapper: multipath: version 1.1.1 loaded
[ 3.784881] device-mapper: multipath round-robin: version 1.0.0
loaded
[ 3.792419] cpuidle: using governor ladder
[ 3.796813] cpuidle: using governor menu
[ 3.800994] sdhci: Secure Digital Host Controller Interface driver
[ 3.807495] sdhci: Copyright(c) Pierre Ossman
[ 3.816925] OMAP3 Beagle/Devkit8000 SoC init
[ 3.908081] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 3.915069] ALSA device list:
[ 3.918212] #0: omap3beagle
[ 3.922637] TCP cubic registered
[ 3.927124] NET: Registered protocol family 10
[ 3.933227] lo: Disabled Privacy Extensions
[ 3.938598] NET: Registered protocol family 17
[ 3.943786] Registering the dns_resolver key type
[ 3.948760] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 3
[ 3.956909] ThumbEE CPU extension supported.
[ 3.962646] Power Management for TI OMAP3.
[ 3.973785] usb 1-2: new high speed USB device using ehci-omap and
address 2
[ 3.982971] clock: disabling unused clocks to save power
[ 3.992279] registered taskstats version 1
[ 3.996795] omapfb omapfb: failed to parse vram parameter
[ 4.015563] Console: switching to colour frame buffer device 80x25
[ 4.032592] regulator_init_complete: incomplete constraints,
leaving VDAC on
[ 4.043182] md: Waiting for all devices to be available before
autodetect
[ 4.053344] md: If you don't use raid, use raid=noautodetect
[ 4.063079] md: Autodetecting RAID arrays.
[ 4.070220] md: Scanned 0 and added 0 devices.
[ 4.077728] md: autorun ...
[ 4.083496] md: ... autorun DONE.
[ 4.089996] Waiting for root device /dev/sda1...
[ 4.146270] mmc0: host does not support reading read-only switch.
assuming write-enable.
[ 4.161682] hub 1-2:1.0: USB hub found
[ 4.168914] hub 1-2:1.0: 5 ports detected
[ 4.176849] mmc0: new high speed SDHC card at address 1234
[ 4.186309] mmcblk0: mmc0:1234 SA04G 3.67 GiB
[ 4.196380] mmcblk0: p1 p2
[ 4.473937] usb 1-2.1: new high speed USB device using ehci-omap
and address 3
[ 4.684875] usb 1-2.2: new high speed USB device using ehci-omap
and address 4
[ 4.813903] usb 1-2.2: selecting invalid altsetting 1
[ 4.822540] scsi0 : usb-storage 1-2.2:1.0
[ 4.911376] usb 1-2.4: new low speed USB device using ehci-omap and
address 5
[ 5.826995] scsi 0:0:0:0: Direct-Access JetFlash Transcend
4GB 8.07 PQ: 0 ANSI: 2
[ 5.844177] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 5.853729] sd 0:0:0:0: [sda] 7843840 512-byte logical blocks:
(4.01 GB/3.74 GiB)
[ 5.868835] sd 0:0:0:0: [sda] Write Protect is off
[ 5.877075] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 5.890747] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 6.118164] sda: sda1
[ 6.126770] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 6.136352] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 6.150360] EXT3-fs: barriers not enabled
[ 6.159027] EXT3-fs (sda1):
[ 6.162048] kjournald starting. Commit interval 5 seconds
[ 6.173858] mounted filesystem with ordered data mode
[ 6.182128] VFS: Mounted root (ext3 filesystem) readonly on device
8:1.
Xorg log
[ 265.508] _XSERVTransmkdir: Owner of /tmp/.X11-unix should be set
to root
[ 265.513]
X.Org X Server 1.9.0
Release Date: 2010-08-20
[ 265.514] X Protocol Version 11, Revision 0
[ 265.514] Build Operating System: Linux 2.6.31.12-0.2-desktop
armv7l
[ 265.515] Current Operating System: Linux localhost.localdomain
2.6.37 #18 PREEMPT Tue Feb 15 10:20:06 IST 2011 armv7l
[ 265.515] Kernel command line: console=ttyO2,115200n8 console=tty0
root=/dev/sda1 rootwait ro omapfb.vram=${vram} omapfb.mode=dvi:$
{dvimode} fixrtc mpurate=${mpurate}
[ 265.516] Build Date: 20 November 2010 02:46:56PM
[ 265.517] Build ID: xorg-x11-server 1.9.0-4.36
[ 265.517] Current version of pixman: 0.20.0
[ 265.517] Before reporting problems, check http://wiki.x.org
  to make sure that you have the latest version.
[ 265.521] Markers: (--) probed, (**) from config file, (==) default
setting,
  (++) from command line, (!!) notice, (II) informational,
  (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 265.533] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jan 1
01:16:25 2000
[ 265.538] (II) Loader magic: 0x19b908
[ 265.538] (II) Module ABI versions:
[ 265.538] X.Org ANSI C Emulation: 0.4
[ 265.538] X.Org Video Driver: 8.0
[ 265.538] X.Org XInput driver : 11.0
[ 265.538] X.Org Server Extension : 4.0
[ 265.539] Primary device is not PCI
[ 265.543] (==) Using default built-in configuration (12 lines)
[ 265.547] (==) --- Start of built-in configuration ---
[ 265.547] Section "Device"
[ 265.547] Identifier "Builtin Default fbdev Device 0"
[ 265.547] Driver "fbdev"
[ 265.547] EndSection
[ 265.547] Section "Screen"
[ 265.547] Identifier "Builtin Default fbdev Screen 0"
[ 265.547] Device "Builtin Default fbdev Device 0"
[ 265.548] Section "ServerLayout"
[ 265.548] Identifier "Builtin Default Layout"
[ 265.548] Screen "Builtin Default fbdev Screen 0"
[ 265.548] EndSection
[ 265.548] (==) --- End of built-in configuration ---
[ 265.548] (==) ServerLayout "Builtin Default Layout"
[ 265.548] (**) |-->Screen "Builtin Default fbdev Screen 0" (0)
[ 265.548] (**) | |-->Monitor "<default monitor>"
[ 265.549] (**) | |-->Device "Builtin Default fbdev Device 0"
[ 265.550] (==) No monitor specified for screen "Builtin Default
fbdev Screen 0".
  Using a default monitor configuration.
[ 265.550] (==) Automatically adding devices
[ 265.550] (==) Automatically enabling devices
[ 265.550] (==) FontPath set to:
  catalogue:/etc/X11/fontpath.d,
  built-ins
[ 265.550] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 265.550] (II) The server relies on udev to provide the list of
input devices.
  If no devices become available, reconfigure udev or disable
AutoAddDevices.
[ 265.550] (II) LoadModule: "extmod"
[ 265.552] (II) Loading /usr/lib/xorg/modules/extensions/
libextmod.so
[ 265.554] (II) Module extmod: vendor="X.Org Foundation"
[ 265.554] compiled for 1.9.0, module version = 1.0.0
[ 265.554] Module class: X.Org Server Extension
[ 265.554] ABI class: X.Org Server Extension, version 4.0
[ 265.554] (II) Loading extension MIT-SCREEN-SAVER
[ 265.554] (II) Loading extension XFree86-VidModeExtension
[ 265.554] (II) Loading extension XFree86-DGA
[ 265.554] (II) Loading extension DPMS
[ 265.555] (II) Loading extension XVideo
[ 265.555] (II) Loading extension XVideo-MotionCompensation
[ 265.555] (II) Loading extension X-Resource
[ 265.555] (II) LoadModule: "dbe"
[ 265.555] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 265.556] (II) Module dbe: vendor="X.Org Foundation"
[ 265.556] compiled for 1.9.0, module version = 1.0.0
[ 265.556] Module class: X.Org Server Extension
[ 265.556] ABI class: X.Org Server Extension, version 4.0
[ 265.556] (II) Loading extension DOUBLE-BUFFER
[ 265.557] (II) LoadModule: "glx"
[ 265.557] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 265.558] (II) Module glx: vendor="X.Org Foundation"
[ 265.558] compiled for 1.9.0, module version = 1.0.0
[ 265.558] ABI class: X.Org Server Extension, version 4.0
[ 265.559] (==) AIGLX enabled
[ 265.559] (II) Loading extension GLX
[ 265.559] (II) LoadModule: "record"
[ 265.560] (II) Loading /usr/lib/xorg/modules/extensions/
librecord.so
[ 265.560] (II) Module record: vendor="X.Org Foundation"
[ 265.560] compiled for 1.9.0, module version = 1.13.0
[ 265.561] Module class: X.Org Server Extension
[ 265.561] ABI class: X.Org Server Extension, version 4.0
[ 265.561] (II) Loading extension RECORD
[ 265.561] (II) LoadModule: "dri"
[ 265.561] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 265.563] (II) Module dri: vendor="X.Org Foundation"
[ 265.564] compiled for 1.9.0, module version = 1.0.0
[ 265.564] ABI class: X.Org Server Extension, version 4.0
[ 265.564] (II) Loading extension XFree86-DRI
[ 265.564] (II) LoadModule: "dri2"
[ 265.565] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 265.566] (II) Module dri2: vendor="X.Org Foundation"
[ 265.566] compiled for 1.9.0, module version = 1.2.0
[ 265.566] ABI class: X.Org Server Extension, version 4.0
[ 265.566] (II) Loading extension DRI2
[ 265.566] (II) LoadModule: "fbdev"
[ 265.567] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 265.569] (II) Module fbdev: vendor="X.Org Foundation"
[ 265.569] compiled for 1.9.0, module version = 0.4.0
[ 265.569] ABI class: X.Org Video Driver, version 8.0
[ 265.569] (II) FBDEV: driver for framebuffer: fbdev
[ 265.570] (--) using VT number 7
[ 265.576] (WW) Falling back to old probe method for fbdev
[ 265.576] (II) Loading sub module "fbdevhw"
[ 265.576] (II) LoadModule: "fbdevhw"
[ 265.577] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 265.579] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 265.579] compiled for 1.9.0, module version = 0.0.2
[ 265.579] ABI class: X.Org Video Driver, version 8.0
[ 265.579] (II) FBDEV(0): using default device
[ 265.580] (WW) VGA arbiter: cannot open kernel arbiter, no multi-
card support
[ 265.580] (II) FBDEV(0): Creating default Display subsection in
Screen section
  "Builtin Default fbdev Screen 0" for depth/fbbpp 24/32
[ 265.580] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 265.580] (==) FBDEV(0): RGB weight 888
[ 265.580] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 265.580] (==) FBDEV(0): Default visual is TrueColor
[ 265.581] (II) FBDEV(0): hardware: omapfb (video memory: 1000kB)
[ 265.581] (II) FBDEV(0): Output LCD has no monitor section
[ 265.582] (II) FBDEV(0): Not using default mode "640x350" (vrefresh
out of range)
"320x175" (doublescan mode not supported)
[ 265.582] (II) FBDEV(0): Not using default mode "640x400" (vrefresh
out of range)
"320x200" (doublescan mode not supported)
[ 265.582] (II) FBDEV(0): Not using default mode "720x400" (width
too large for virtual size)
"360x200" (doublescan mode not supported)
[ 265.583] (II) FBDEV(0): Not using default mode "640x480" (all
modes must have the same resolution)
"320x240" (doublescan mode not supported)
[ 265.583] (II) FBDEV(0): Not using default mode "640x480" (vrefresh
out of range)
out of range)
out of range)
[ 265.583] (II) FBDEV(0): Not using default mode "800x600" (width
"400x300" (doublescan mode not supported)
[ 265.584] (II) FBDEV(0): Not using default mode
[ 265.584] (II) FBDEV(0): Not using default mode "800x600" (width
"1024x768i" (interlace mode not supported)
"512x384i" (doublescan mode not supported)
[ 265.584] (II) FBDEV(0): Not using default mode "1024x768" (height
"512x384" (doublescan mode not supported)
[ 265.585] (II) FBDEV(0): Not using default mode
[ 265.585] (II) FBDEV(0): Not using default mode "1024x768" (height
[ 265.585] (II) FBDEV(0): Not using default mode "1152x864" (height
"576x432" (doublescan mode not supported)
[ 265.585] (II) FBDEV(0): Not using default mode "1280x960" (height
"640x480" (doublescan mode not supported)
[ 265.585] (II) FBDEV(0): Not using default mode "1280x1024" (height
[ 265.586] (II) FBDEV(0): Not using default mode
"640x512" (doublescan mode not supported)
[ 265.586] (II) FBDEV(0): Not using default mode "1280x1024" (height
[ 265.586] (II) FBDEV(0): Not using default mode "1600x1200" (height
"800x600" (doublescan mode not supported)
[ 265.587] (II) FBDEV(0): Not using default mode "1600x1200" (height
[ 265.587] (II) FBDEV(0): Not using default mode "1792x1344" (height
"896x672" (doublescan mode not supported)
[ 265.587] (II) FBDEV(0): Not using default mode "1856x1392" (height
"928x696" (doublescan mode not supported)
[ 265.588] (II) FBDEV(0): Not using default mode
[ 265.588] (II) FBDEV(0): Not using default mode "1920x1440" (height
"960x720" (doublescan mode not supported)
[ 265.588] (II) FBDEV(0): Not using default mode "832x624" (width
"416x312" (doublescan mode not supported)
[ 265.588] (II) FBDEV(0): Not using default mode "1400x1050" (height
"700x525" (doublescan mode not supported)
[ 265.589] (II) FBDEV(0): Not using default mode "2048x1536" (height
"1024x768" (doublescan mode not supported)
[ 265.589] (II) FBDEV(0): Printing probed modes for output LCD
[ 265.589] (II) FBDEV(0): Modeline "640x400"x70.6 25.41 640 664
760 800 400 409 411 450 -hsync -vsync -csync (31.8 kHz)
[ 265.589] (II) FBDEV(0): Output LCD connected
[ 265.589] (II) FBDEV(0): Using exact sizes for initial modes
[ 265.590] (II) FBDEV(0): Output LCD using initial mode 640x400
[ 265.590] (II) FBDEV(0): Using default gamma of (1.0, 1.0, 1.0)
unless otherwise stated.
[ 265.590] (II) Loading sub module "fb"
[ 265.590] (II) LoadModule: "fb"
mode
[ 265.596]
Fatal server error:
[ 265.596]
[ 265.596]
Your bootargs did not substitute properly:
That caused the frame buffer driver to not create any frame buffers:
Steve K.
Boot.cmd is
echo "Booting MeeGo Community Image"
if test "\${beaglerev}" = "xMA"; then
echo "Kernel is not ready for 1Ghz limiting to 800Mhz"
setenv mpurate 800
fi
if test "\${beaglerev}" = "xMB"; then
setenv mpurate 800
fi
setenv dvimode 800x480-16@60
setenv vram 0:2M,1:2M,2:2M
setenv bootcmd 'mmc init; fatload mmc 0:1 0x80300000 uImage; bootm
0x80300000'
setenv bootargs console=ttyO2,115200n8 console=tty0 root=/dev/sda1
rootwait ro omapfb.debug=y omapfb.vram=\${vram} omapfb.mode=dvi:\$
{dvimode} fixrtc mpurate=\${mpurate}
boot
Where Iam going wrong?
If that's your boot.cmd
Drop the 5 "\"'s, before every $....
"\" is only useful if your cat'ing the script from another self
contained script.. It's very bad if your final boot.cmd has them..
After changing Iam not getting that particular error
