XBMC on Beagleboard
Hello BB friends,
I try to use XBMC on Beagleboard xM, and I want to use for that the
Narcissus Angstrom Distribution at the following page:
http://narcissus.angstrom-distribution.org/
I'm not really sure about the settings and the needed packages for the
best using of
XBMC on Beagleboard, so I ask you for help.
I’m not the pro around here but, I find it easier to install the base angstrom and opkg any packages from a terminal. That way it will pull in whatever depends it requires
Hi Mark,
dank dir für die Antwort.
In my opinion that’s not a good idea, because XBMC for BB needs a lot
of resources to run stabil.
