xM 3D support broken
I try to run 3D applications supplied with Koen’s demo and can see that they are absolutely broken! These applications work fine at BB-C3 and here I expected something more (may be faster?)
What is wrong?
regards,
Max
Is this the same exact card used with the C3?
What's the value of: "/etc/powervr-esrev" on your xM when running the
failed demos..
The C3 uses different sgx binaries (version 3) vs the xM which use
(version 5) of the binaries..
If it is 3, "rm /etc/powervr-esrev" and "/etc/init/rc.pvr start" (dir
might be a little off for angstrom)..
Hi Robert!
The card is the same, though I haven’t ever inserted it into the C3 :). I just got xM and reformated the card immidiately for use with Koen’s demo filesystem. I wanted to use the Narcissus image but the online builder is overloaded.
Answers to your questions:
the value of: “/etc/powervr-esrev” is 2 (even not 3!) - removed
removed /etc/init.d/pvr-init
the result is when I run any demo I see the following log:
beagle@beagleboard:~$ /usr/bin/SGX/demos/X11/
OGLESVase
Exit message has been set to: “PVRShell: Unable to initialise EGL”.
PVRShell: EGL Error (EGL_BAD_ALLOC)
InitAPI failed!
Well, since there is no idea how to enable 3D support at XM I tried to generate a rootfs at Narcissus Online builder, hoping that rootfs contains all necessary libraries… Unfortunately Online builder seems to be dead as I had waited about 1 hour and got nothing now. It just prints that preconfiguring is fine and nothing happens.
2010/11/10 Robert Nelson <robertcnelson@gmail.com>
Hi Maxim
Hi Robert!
The card is the same, though I haven't ever inserted it into the C3 :). I
just got xM and reformated the card immidiately for use with Koen's demo
overloaded.
the value of: "/etc/powervr-esrev" is 2 (even not 3!) - removed
This is why it didn't work, it was detecting the wrong version...
Actually you should have rerun that script, but...
I'd rerun the script found here:
http://elinux.org/BeagleBoardUbuntu#SGX_Video_Acceleration
Since I've made a bunch of improvements since your original email.
The sgx drivers work just fine on my xM A2 and xM B boards.. Tested
while running xfce on top of the two lucid/maverick demo images on
elinux...
