xM Ethernet Jack part number
tl;dr: What’s the manufacturer/part number of the Ethernet connector on the BeagleBoard-xM?
I’m doing a project with a BeagleBoard-xM, and I want to intercept the ethernet connector to add power over ethernet capability. The pin out on the ethernet connector (P15) is little different from other connectors I’ve worked with, and to make sure that I route everything correctly, I need to find the datasheet for that connector. I looked at the BOM for the xM, which lists the following:
CONN MAGJACK 1PRT 10/100B-TX Y/G | P15 | CONN_ETHER_MAG |
A search on Google for “CONN_ETHER_MAG” didn’t turn anything up. The ‘MagJack’ in the description makes me think that this is probably a MagJack line connector from Stewart Connector, but without the actual manufacturer part number, I can’t be sure. Does anyone know where I can find the datasheet for this thing, or have the correct part number so I can find it myself?
Stephen Bell
0817-1A1T-11-F
No need for datasheet. the ETHERNET can be activated by consider it an
usb device.
You should only activate USB_GADGET_ETH configs in kernel (smc91xx I
guess). I can download kernel using uboot even.
