xserver-xorg-video-omap3 installation problem - Beagleboard Xm
I was trying to install the gui on minimal demo image. But couldn't
make it.
I got the following errors while installing xserver
Command:
sudo aptitude install xfce4 gdm xubuntu-gdm-theme xubuntu-artwork
Errors:
mmcblk0: error I/O transfering data sector xxx, nr 8, card status
0xc00
end request: I/O error, dev mmcblk0, sector xxx
Buffer I/O error on device mmcblk0p2 logical block xxx
end request: Aborting journal on device mmcblk0p2-8
JDB2: I/O error detected when updating journal superblock for
mmcblk0p2-8
EXT4-fs error (device mmcblk0p2): ext4_journal_start_sb: detected
aborting journal
EXT4-fs (mmcblk0p2): Remounting filesystem read-only.
So anybody knows what exactly the problem is? Is that any problem with
sd card like bad sector or what? So I need assistance to resolve this.
-Sandip
It looks like a bad sd card to me.. btw, is this an xM A or xM b?
xM a. Yes, you are right about the same. bad sd card.
Can you tell me how to start the xserver for beagleboard.
I have installed the xserver-xorg-video-omap3 and xfce4. And
connected the LCD to the hdmi cable.
After installation of the minimal image we have to install the xserver-
xorg and we should run by command "startx". But I couldn't find the
command. Does it have another command? Or any special settings. So
please let me know.
-Sandip
I had run the X and Xorg to load the xserver. But I think, it searches
for the PCI device and we are using the framebuffer. And did not get
the display on LCD.
Message while loading xserver
Primary device is not PCI
dmesg of fb:
fbcvt: 1200x720@60: CVT name - 921M9-R
Console: switching to colour frame buffer device 160x45
So can you help to resolve the same.
-Sandip
The framebuffer is actually loaded by the kernel.. The 'fake' driver
xserver-video-omap3 just writes to the fb... Is X not taking over the
screen?
Can you 'pastebin' your full boot log?
No X isn't taking over the LCD screen.
find below the boot messges
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.35.7-l6 (root@beagle-256mb-0) (gcc
version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #1 PREEMPT Tue Oct 19 18:18:41
UTC 2010
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Beagle expansionboard: none
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat c08597cc,
node_mem_map c091a000
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 130048 pages, LIFO batch:31
[ 0.000000] OMAP3630 ES1.0 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x100000
[ 0.000000] Reserving 12582912 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 130048
[ 0.000000] Kernel command line: console=ttyS2,115200n8
console=tty0 root=/dev/mmcblk0p2 rootwait ro vram=12MB omapfb.mode=dvi:
1280x720MR-16@60 fixrtc buddy=none mpurate=800
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6,
262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072
bytes)
[ 0.000000] allocated 2621440 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't
want memory cgroups
[ 0.000000] Memory: 256MB 256MB = 512MB total
[ 0.000000] Memory: 485376k/485376k available, 38912k reserved, 0K
highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xe0800000 - 0xf8000000 ( 376 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0049000 ( 260 kB)
[ 0.000000] .text : 0xc0049000 - 0xc078f000 (7448 kB)
[ 0.000000] .data : 0xc07fe000 - 0xc085d8c0 ( 383 kB)
[ 0.000000] SLUB: Genslabs=9, HWalign=64, Order=0-3, MinObjects=0,
CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] Verbose stalled-CPUs detection is disabled.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
[ 0.000000] (null): no physical address for uart#3, so skipping
early_init...
[ 0.000000] omap_hwmod: l3_hwmod: cannot be enabled (3)
[ 0.000000] omap_hwmod: l4_core_hwmod: cannot be enabled (3)
[ 0.000000] omap_hwmod: l4_per_hwmod: cannot be enabled (3)
[ 0.000000] omap_hwmod: l4_wkup_hwmod: cannot be enabled (3)
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.000000] Calibrating delay loop... 508.37 BogoMIPS (lpj=1986560)
[ 0.000000] pid_max: default: 32768 minimum: 301
[ 0.000000] Security Framework initialized
[ 0.000000] Smack: Initializing.
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] Initializing cgroup subsys ns
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Initializing cgroup subsys memory
[ 0.000000] Initializing cgroup subsys devices
[ 0.000000] Initializing cgroup subsys freezer
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] devtmpfs: initialized
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] mux: Setting signal mcspi1_clk.gpio171 0x011c -> 0x011c
[ 0.000000] mux: Setting signal mcspi1_simo.gpio172 0x011c ->
0x011c
[ 0.000000] mux: Setting signal mcspi1_somi.gpio173 0x011c ->
0x011c
[ 0.000000] OMAP3 Beagle Rev: xM
[ 0.000000] mux: Setting signal i2c2_scl.i2c2_scl 0x0118 -> 0x0100
[ 0.000000] mux: Setting signal i2c2_sda.i2c2_sda 0x0118 -> 0x0100
[ 0.000000] mux: Setting signal i2c3_scl.i2c3_scl 0x0118 -> 0x0100
[ 0.000000] mux: Setting signal i2c3_sda.i2c3_sda 0x0118 -> 0x0100
[ 0.000000] ------------[ cut here ]------------
[ 0.000000] WARNING: at arch/arm/mach-omap2/serial.c:727
omap_serial_init_port+0x78/0x348()
[ 0.000000] (null): can't init uart3, no clocks available
[ 0.000000] Modules linked in:
[ 0.000000] [<c004fb5c>] (unwind_backtrace+0x0/0x100) from
[<c05d21b0>] (dump_stack+0x18/0x1c)
[ 0.000000] [<c05d21b0>] (dump_stack+0x18/0x1c) from [<c0081778>]
(warn_slowpath_common+0x54/0x6c)
[ 0.000000] [<c0081778>] (warn_slowpath_common+0x54/0x6c) from
[<c0081834>] (warn_slowpath_fmt+0x38/0x40)
[ 0.000000] [<c0081834>] (warn_slowpath_fmt+0x38/0x40) from
[<c0010d40>] (omap_serial_init_port+0x78/0x348)
[ 0.000000] [<c0010d40>] (omap_serial_init_port+0x78/0x348) from
[<c0011040>] (omap_serial_init+0x30/0x3c)
[ 0.000000] [<c0011040>] (omap_serial_init+0x30/0x3c) from
[<c0012fd8>] (omap3_beagle_init+0x208/0x4a8)
[ 0.000000] [<c0012fd8>] (omap3_beagle_init+0x208/0x4a8) from
[<c000c660>] (customize_machine+0x20/0x2c)
[ 0.000000] [<c000c660>] (customize_machine+0x20/0x2c) from
[<c00493f0>] (do_one_initcall+0x38/0x1cc)
[ 0.000000] [<c00493f0>] (do_one_initcall+0x38/0x1cc) from
[<c0008648>] (kernel_init+0xf4/0x1b4)
[ 0.000000] [<c0008648>] (kernel_init+0xf4/0x1b4) from [<c004a4a8>]
(kernel_thread_exit+0x0/0x8)
[ 0.000000] ---[ end trace 1b75b31a2719ed1c ]---
[ 0.000000] mux: Setting signal etk_clk.hsusb1_stp 0x001b -> 0x0003
[ 0.000000] mux: Setting signal etk_ctl.hsusb1_clk 0x0013 -> 0x0003
[ 0.000000] mux: Setting signal etk_d8.hsusb1_dir 0x0113 -> 0x010b
[ 0.000000] mux: Setting signal etk_d9.hsusb1_nxt 0x0113 -> 0x010b
[ 0.000000] mux: Setting signal etk_d0.hsusb1_data0 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal etk_d1.hsusb1_data1 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal etk_d2.hsusb1_data2 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal etk_d7.hsusb1_data3 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal etk_d4.hsusb1_data4 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal etk_d5.hsusb1_data5 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal etk_d6.hsusb1_data6 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal etk_d3.hsusb1_data7 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal etk_d11.hsusb2_stp 0x0013 -> 0x0003
[ 0.000000] mux: Setting signal etk_d10.hsusb2_clk 0x0013 -> 0x0003
[ 0.000000] mux: Setting signal etk_d12.hsusb2_dir 0x0113 -> 0x010b
[ 0.000000] mux: Setting signal etk_d13.hsusb2_nxt 0x0113 -> 0x010b
[ 0.000000] mux: Setting signal etk_d14.hsusb2_data0 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal etk_d15.hsusb2_data1 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal mcspi1_cs3.hsusb2_data2 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal mcspi2_cs1.hsusb2_data3 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal mcspi2_simo.hsusb2_data4 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal mcspi2_somi.hsusb2_data5 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal mcspi2_cs0.hsusb2_data6 0x0113 ->
0x010b
[ 0.000000] mux: Setting signal mcspi2_clk.hsusb2_data7 0x0113 ->
0x010b
[ 0.000000] Found NAND on CS0
[ 0.000000] mux: Setting signal sdrc_cke0.sdrc_cke0 0x0118 ->
0x0000
[ 0.000000] mux: Setting signal sdrc_cke1.sdrc_cke1 0x0118 ->
0x0000
[ 0.000000] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver,
5 counters available
[ 0.000000] Switched to new clocking rate (Crystal/Core/MPU):
26.0/800/332 MHz
[ 0.000122] OMAP DMA hardware revision 5.0
[ 0.000396] omap-mcpdm omap-mcpdm: unable to get pdm_ck: -2
[ 0.000457] omap-mcpdm: probe of omap-mcpdm failed with error -2
[ 0.004058] bio: create slab <bio-0> at 0
[ 0.004852] SCSI subsystem initialized
[ 0.005584] usbcore: registered new interface driver usbfs
[ 0.005676] usbcore: registered new interface driver hub
[ 0.005859] usbcore: registered new device driver usb
[ 0.006134] i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600 kHz
[ 0.008422] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.008453] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.008850] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.009277] mux: Setting signal sdmmc1_clk.sdmmc1_clk 0x0018 ->
0x0118
[ 0.009368] mux: Setting signal sdmmc1_cmd.sdmmc1_cmd 0x0118 ->
0x0118
[ 0.009460] mux: Setting signal sdmmc1_dat0.sdmmc1_dat0 0x0118 ->
0x0118
[ 0.009521] mux: Setting signal sdmmc1_dat1.sdmmc1_dat1 0x0118 ->
0x0118
[ 0.009582] mux: Setting signal sdmmc1_dat2.sdmmc1_dat2 0x0118 ->
0x0118
[ 0.009643] mux: Setting signal sdmmc1_dat3.sdmmc1_dat3 0x0118 ->
0x0118
[ 0.009826] mux: Setting signal sdmmc2_clk.sdmmc2_clk 0x011c ->
0x0118
[ 0.009918] mux: Setting signal sdmmc2_cmd.sdmmc2_cmd 0x011c ->
0x0118
[ 0.009979] mux: Setting signal sdmmc2_dat0.sdmmc2_dat0 0x011c ->
0x0118
[ 0.010040] mux: Setting signal sdmmc2_dat1.sdmmc2_dat1 0x011c ->
0x0118
[ 0.010101] mux: Setting signal sdmmc2_dat2.sdmmc2_dat2 0x011c ->
0x0118
[ 0.010192] mux: Setting signal sdmmc2_dat3.sdmmc2_dat3 0x011c ->
0x0118
[ 0.011322] regulator: VUSB1V5: 1500 mV normal standby
[ 0.011596] regulator: VUSB1V8: 1800 mV normal standby
[ 0.011840] regulator: VUSB3V1: 3100 mV normal standby
[ 0.013061] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 0.013549] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal
standby
[ 0.013854] regulator: VDAC: 1800 mV normal standby
[ 0.014129] regulator: VPLL2: 1800 mV normal standby
[ 0.014495] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal
standby
[ 0.014709] i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz
[ 0.026397] i2c_omap i2c_omap.3: bus 3 rev4.0 at 100 kHz
[ 0.027069] Advanced Linux Sound Architecture Driver Version
1.0.23.
[ 0.027496] NetLabel: Initializing
[ 0.027526] NetLabel: domain hash size = 128
[ 0.027557] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.027618] NetLabel: unlabeled traffic allowed by default
[ 0.027679] Switching to clocksource 32k_counter
[ 0.043365] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 0.048126] musb_hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk
combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.048156] musb_hdrc: MHDRC RTL version 1.800
[ 0.048156] musb_hdrc: setup fifo_mode 5
[ 0.048187] musb_hdrc: 28/31 max ep, 8192/16384 memory
[ 0.048339] musb_hdrc musb_hdrc: USB OTG mode controller at
fa0ab000 using DMA, IRQ 92
[ 0.048645] NET: Registered protocol family 2
[ 0.048858] IP route cache hash table entries: 4096 (order: 2,
16384 bytes)
[ 0.049591] TCP established hash table entries: 16384 (order: 5,
131072 bytes)
[ 0.049896] TCP bind hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.050079] TCP: Hash tables configured (established 16384 bind
16384)
[ 0.050109] TCP reno registered
[ 0.050109] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.050170] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.050354] NET: Registered protocol family 1
[ 0.050720] RPC: Registered udp transport module.
[ 0.050781] RPC: Registered tcp transport module.
[ 0.050811] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 0.051086] Trying to unpack rootfs image as initramfs...
[ 0.359252] Freeing initrd memory: 4116K
[ 0.359954] PMU: registered new PMU device of type 0
[ 0.360046] dspbridge_init: 600000 bytes @ 82700000
[ 0.360473] audit: initializing netlink socket (disabled)
[ 0.360565] type=2000 audit(0.742:1): initialized
[ 0.473754] VFS: Disk quotas dquot_6.5.2
[ 0.474090] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 0.477813] fuse init (API version 7.14)
[ 0.479125] Btrfs loaded
[ 0.479187] msgmni has been set to 956
[ 0.480957] alg: No test for stdrng (krng)
[ 0.481414] Block layer SCSI generic (bsg) driver version 0.4
loaded (major 254)
[ 0.481445] io scheduler noop registered
[ 0.481475] io scheduler deadline registered
[ 0.481567] io scheduler cfq registered (default)
[ 0.543548] OMAP DSS rev 2.0
[ 0.543670] OMAP DISPC rev 3.0
[ 0.543701] OMAP VENC rev 2
[ 0.872314] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.954101] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 1.119659] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 1.285125] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 2.180175] console [ttyS2] enabled
[ 2.189086] brd: module loaded
[ 2.194854] loop: module loaded
[ 2.200378] omap2-nand driver initializing
[ 2.204772] No NAND device found.
[ 2.208312] No NAND device found.
[ 2.211791] OneNAND driver initializing
[ 2.216033] usbcore: registered new interface driver cdc_ether
[ 2.221954] usbcore: registered new interface driver rndis_host
[ 2.228424] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 2.235290] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 2.241271] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 1
[ 2.248870] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 2.270019] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 2.276428] hub 1-0:1.0: USB hub found
[ 2.280273] hub 1-0:1.0: 3 ports detected
[ 2.309173] Initializing USB Mass Storage driver...
[ 2.314208] usbcore: registered new interface driver usb-storage
[ 2.320281] USB Mass Storage support registered.
[ 2.325012] g_ether gadget: using random self ethernet address
[ 2.330902] g_ether gadget: using random host ethernet address
[ 2.337615] usb0: MAC ae:e5:08:6c:a2:63
[ 2.341522] usb0: HOST MAC 86:66:55:c3:05:99
[ 2.345886] g_ether gadget: Ethernet Gadget, version: Memorial Day
2008
[ 2.352569] g_ether gadget: g_ether ready
[ 2.356658] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 2.362121] musb_hdrc musb_hdrc: new USB bus registered, assigned
bus number 2
[ 2.369995] hub 2-0:1.0: USB hub found
[ 2.373840] hub 2-0:1.0: 1 port detected
[ 2.378234] mice: PS/2 mouse device common for all mice
[ 2.384277] input: twl4030_pwrbutton as /devices/platform/i2c_omap.
1/i2c-1/1-0049/twl4030_pwrbutton/input/input0
[ 2.395141] i2c /dev entries driver
[ 2.399719] device-mapper: uevent: version 1.0.3
[ 2.405242] device-mapper: ioctl: 4.17.0-ioctl (2010-03-05)
initialised: dm-devel@redhat.com
[ 2.414123] device-mapper: multipath: version 1.1.1 loaded
[ 2.419708] device-mapper: multipath round-robin: version 1.0.0
loaded
[ 2.426971] sdhci: Secure Digital Host Controller Interface driver
[ 2.433227] sdhci: Copyright(c) Pierre Ossman
[ 2.440887] mmci-omap-hs: probe of mmci-omap-hs.1 failed with error
-16
[ 2.447814] Registered led device: beagleboard::usr0
[ 2.447906] Registered led device: beagleboard::usr1
[ 2.450500] Registered led device: beagleboard::pmu_stat
[ 2.451141] No device for DAI tlv320aic23
[ 2.527740] No device for DAI omap-mcbsp-dai-0
[ 2.532287] No device for DAI omap-mcbsp-dai-1
[ 2.536804] No device for DAI omap-mcbsp-dai-2
[ 2.541259] No device for DAI omap-mcbsp-dai-3
[ 2.545776] No device for DAI omap-mcbsp-dai-4
[ 2.550262] No device for DAI omap-mcpdm
[ 2.554229] Not OMAP3 EVM!
[ 2.556976] Not OMAP3517 / AM3517 EVM!
[ 2.560791] OMAP3 Beagle/Devkit8000 SoC init
[ 2.565765] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 2.573883] ALSA device list:
[ 2.576965] #0: omap3beagle (twl4030)
[ 2.582092] TCP cubic registered
[ 2.586242] NET: Registered protocol family 10
[ 2.592102] lo: Disabled Privacy Extensions
[ 2.597900] NET: Registered protocol family 17
[ 2.602661] ThumbEE CPU extension supported.
[ 2.608459] Power Management for TI OMAP3.
[ 2.618438] Disabling unused clock "sr2_fck"
[ 2.618469] Disabling unused clock "sr1_fck"
[ 2.618469] Disabling unused clock "mcbsp4_fck"
[ 2.618499] Disabling unused clock "mcbsp3_fck"
[ 2.618499] Disabling unused clock "mcbsp2_fck"
[ 2.618530] Disabling unused clock "mcbsp4_ick"
[ 2.618530] Disabling unused clock "mcbsp3_ick"
[ 2.618530] Disabling unused clock "mcbsp2_ick"
[ 2.618560] Disabling unused clock "gpt2_ick"
[ 2.618560] Disabling unused clock "gpt3_ick"
[ 2.618591] Disabling unused clock "gpt4_ick"
[ 2.618591] Disabling unused clock "gpt5_ick"
[ 2.618621] Disabling unused clock "gpt6_ick"
[ 2.618621] Disabling unused clock "gpt7_ick"
[ 2.618652] Disabling unused clock "gpt8_ick"
[ 2.618652] Disabling unused clock "gpt9_ick"
[ 2.618682] Disabling unused clock "wdt3_ick"
[ 2.618682] Disabling unused clock "wdt3_fck"
[ 2.618682] Disabling unused clock "gpio2_dbck"
[ 2.618713] Disabling unused clock "gpio3_dbck"
[ 2.618713] Disabling unused clock "gpio4_dbck"
[ 2.618743] Disabling unused clock "gpio5_dbck"
[ 2.618743] Disabling unused clock "gpio6_dbck"
[ 2.618774] Disabling unused clock "gpt9_fck"
[ 2.618774] Disabling unused clock "gpt8_fck"
[ 2.618804] Disabling unused clock "gpt7_fck"
[ 2.618804] Disabling unused clock "gpt6_fck"
[ 2.618835] Disabling unused clock "gpt5_fck"
[ 2.618835] Disabling unused clock "gpt4_fck"
[ 2.618835] Disabling unused clock "gpt3_fck"
[ 2.618865] Disabling unused clock "gpt2_fck"
[ 2.618865] Disabling unused clock "gpt1_ick"
[ 2.618896] Disabling unused clock "wdt1_ick"
[ 2.618896] Disabling unused clock "wdt2_ick"
[ 2.618927] Disabling unused clock "wdt2_fck"
[ 2.618927] Disabling unused clock "gpio1_dbck"
[ 2.618957] Disabling unused clock "gpt1_fck"
[ 2.618957] Disabling unused clock "cam_ick"
[ 2.618988] Disabling unused clock "cam_mclk"
[ 2.619049] Disabling unused clock "des1_ick"
[ 2.619049] Disabling unused clock "sha11_ick"
[ 2.619049] Disabling unused clock "rng_ick"
[ 2.619079] Disabling unused clock "aes1_ick"
[ 2.619079] Disabling unused clock "ssi_ick"
[ 2.619110] Disabling unused clock "mailboxes_ick"
[ 2.619110] Disabling unused clock "mcbsp1_ick"
[ 2.619140] Disabling unused clock "mcbsp5_ick"
[ 2.619140] Disabling unused clock "gpt10_ick"
[ 2.619140] Disabling unused clock "gpt11_ick"
[ 2.619171] Disabling unused clock "mcspi3_ick"
[ 2.619171] Disabling unused clock "mcspi4_ick"
[ 2.619201] Disabling unused clock "hdq_ick"
[ 2.619201] Disabling unused clock "mspro_ick"
[ 2.619232] Disabling unused clock "des2_ick"
[ 2.619232] Disabling unused clock "sha12_ick"
[ 2.619262] Disabling unused clock "aes2_ick"
[ 2.619262] Disabling unused clock "icr_ick"
[ 2.619293] Disabling unused clock "pka_ick"
[ 2.619293] Disabling unused clock "ssi_ssr_fck"
[ 2.619293] Disabling unused clock "hdq_fck"
[ 2.619323] Disabling unused clock "mcspi3_fck"
[ 2.619323] Disabling unused clock "mcspi4_fck"
[ 2.619354] Disabling unused clock "mcbsp1_fck"
[ 2.619354] Disabling unused clock "mcbsp5_fck"
[ 2.619354] Disabling unused clock "mspro_fck"
[ 2.619384] Disabling unused clock "gpt11_fck"
[ 2.619384] Disabling unused clock "gpt10_fck"
[ 2.619415] Disabling unused clock "sad2d_ick"
[ 2.619445] Disabling unused clock "dpll4_m6x2_ck"
[ 2.619445] Disabling unused clock "dpll3_m3x2_ck"
[ 2.619476] Disabling unused clock "sys_clkout1"
[ 2.619476] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 3
[ 2.627990] registered taskstats version 1
[ 2.632354] fbcvt: 1280x720@60: CVT Name - .921M9-R
[ 2.657806] Console: switching to colour frame buffer device 160x45
[ 2.675659] regulator_init_complete: incomplete constraints,
leaving VDAC on
[ 2.683227] Freeing init memory: 260K
[ 2.700622] usb 1-2: new high speed USB device using ehci-omap and
address 2
[ 2.813842] udev: starting version 151
[ 2.854736] mmc0: host does not support reading read-only switch.
assuming write-enable.
[ 2.881134] hub 1-2:1.0: USB hub found
[ 2.940338] hub 1-2:1.0: 5 ports detected
[ 3.051483] mmc0: new SDHC card at address e624
[ 3.121337] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[ 3.145568] mmcblk0: p1 p2
[ 3.395507] usb 1-2.1: new high speed USB device using ehci-omap
and address 3
[ 4.112304] EXT4-fs (mmcblk0p2): INFO: recovery required on
readonly filesystem
[ 4.119964] EXT4-fs (mmcblk0p2): write access will be enabled
during recovery
[ 6.102996] EXT4-fs (mmcblk0p2): recovery complete
[ 6.116271] EXT4-fs (mmcblk0p2): mounted filesystem with ordered
data mode. Opts: (null)
[ 8.512878] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-
ro
[ 8.574523] udev: starting version 151
[ 9.173095] input: gpio-keys as /devices/platform/gpio-keys/input/
input1
[ 9.531829] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 9.532135] smsc95xx v1.0.4
[ 9.669555] smsc95xx 1-2.1:1.0: usb1: register 'smsc95xx' at usb-
ehci-omap.0-2.1, smsc95xx USB 2.0 Ethernet, 62:9d:e8:0c:3a:11
[ 9.669708] usbcore: registered new interface driver smsc95xx
[ 11.399993] Adding 51196k swap on /mnt/SWAP.swap. Priority:-1
extents:4 across:75772k SS
Xorg LOG:
X.Org X Server 1.7.6
Release Date: 2010-03-17
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.31-608-imx51 armv7l Ubuntu
Current Operating System: Linux omap 2.6.35.7-l6 #1 PREEMPT Tue Oct 19
18:18:41 UTC 2010 armv7l
Kernel command line: console=ttyS2,115200n8 console=tty0 root=/dev/
mmcblk0p2 rootwait ro vram=12MB omapfb.mode=dvi:1280x720MR-16@60
Build Date: 21 July 2010 01:46:12PM
xorg-server 2:1.7.6-2ubuntu7.3 (For technical support please see
http://www.ubuntu.com/support)
Current version of pixman: 0.16.4
  Before reporting problems, check http://wiki.x.org
  to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
  (++) from command line, (!!) notice, (II) informational,
  (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Nov 13 02:07:06 2010
(==) Using config directory: "/usr/lib/X11/xorg.conf.d"
(==) No Layout section. Using the first Screen section.
(==) No screen section available. Using defaults.
(**) |-->Screen "Default Screen Section" (0)
(**) | |-->Monitor "<default monitor>"
(==) No monitor specified for screen "Default Screen Section".
  Using a default monitor configuration.
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
  Entry deleted from font path.
(WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-
ttcidfont-conf.d/dirs/TrueType".
  (Run 'mkfontdir' on "/var/lib/defoma/x-ttcidfont-conf.d/dirs/
TrueType").
(==) FontPath set to:
  /usr/share/fonts/X11/misc,
  /usr/share/fonts/X11/100dpi/:unscaled,
  /usr/share/fonts/X11/75dpi/:unscaled,
  /usr/share/fonts/X11/Type1,
  /usr/share/fonts/X11/100dpi,
  /usr/share/fonts/X11/75dpi,
  built-ins
(==) ModulePath set to "/usr/lib/xorg/extra-modules,/usr/lib/xorg/
modules"
(II) The server relies on udev to provide the list of input devices.
  If no devices become available, reconfigure udev or disable
AutoAddDevices.
(II) Loader magic: 0x13c178
(II) Module ABI versions:
  X.Org ANSI C Emulation: 0.4
  X.Org Video Driver: 6.0
  X.Org XInput driver : 7.0
  X.Org Server Extension : 2.0
(--) using VT number 8
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
  compiled for 1.7.6, module version = 1.0.0
  Module class: X.Org Server Extension
  ABI class: X.Org Server Extension, version 2.0
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
  compiled for 1.7.6, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
  compiled for 1.7.6, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "omapfb"
(II) Loading /usr/lib/xorg/modules/drivers/omapfb_drv.so
(II) Module omapfb: vendor="X.Org Foundation"
  compiled for 1.7.6, module version = 0.1.1
  ABI class: X.Org Video Driver, version 6.0
(==) Matched omapfb as autoconfigured driver 0
(==) Assigned the driver to the xf86ConfigLayout
(II) Reloading /usr/lib/xorg/modules/drivers/omapfb_drv.so
(II) UnloadModule: "omapfb"
(II) Failed to load module "omapfb" (already loaded, 600000)
(II) omapfb: Driver for OMAP framebuffer (omapfb) and external LCD
controllers:
  omap1/2/3, S1D13745, HWA742
(WW) Falling back to old probe method for OMAPFB
(WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
(II) Running in FRAMEBUFFER Mode
(WW) Error opening /sys/devices/platform/omapfb/ctrl/name: No such
file or directory
(WW) Can't autodetect LCD controller, assuming internal
(II) LCD controller: internal
(II) omapfb(0): VideoRAM: 1800KiB (SDRAM)
(II) omapfb(0): Creating default Display subsection in Screen section
  "Default Screen Section" for depth/fbbpp 16/16
(--) omapfb(0): Depth 16, (==) framebuffer bpp 16
(==) omapfb(0): RGB weight 565
(==) omapfb(0): Default visual is TrueColor
(--) omapfb(0): Virtual size is 1280x720 (pitch 1280)
(**) omapfb(0): Built-in mode "current"
(==) omapfb(0): DPI set to (96, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
  ABI class: X.Org ANSI C Emulation, version 0.4
(==) omapfb(0): DPMS enabled
(II) omapfb(0): Video plane capabilities:
(II) omapfb(0): Video plane supports the following image formats:
(II) omapfb(0): XVideo extension initialized
(==) RandR enabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) AIGLX: Screen 0 is not DRI2 capable
(II) AIGLX: Screen 0 is not DRI capable
(II) AIGLX: Loaded and initialized /usr/lib/dri/swrast_dri.so
(II) GLX: Initialized DRISWRAST GL provider for screen 0
(II) XKB: generating xkmfile /var/lib/xkb/server-
B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
(II) config/udev: Adding input device gpio-keys (/dev/input/event1)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device twl4030_pwrbutton (/dev/input/
event0)
(**) twl4030_pwrbutton: Applying InputClass "evdev keyboard catchall"
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
  compiled for 1.7.6, module version = 2.3.2
  Module class: X.Org XInput Driver
  ABI class: X.Org XInput driver, version 7.0
(**) twl4030_pwrbutton: always reports core events
(**) twl4030_pwrbutton: Device: "/dev/input/event0"
(II) twl4030_pwrbutton: Found keys
(II) twl4030_pwrbutton: Configuring as keyboard
(II) XINPUT: Adding extended input device "twl4030_pwrbutton" (type:
KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "evdev"
(**) Option "xkb_layout" "us"
D378AD8F86E560F712A83EE36E4E5E92C595B9BD.xkm
(NI) OMAPFBSaveScreen: Dim backlight?
(II) twl4030_pwrbutton: Close
(II) UnloadModule: "evdev"
ddxSigGiveUp: Closing log
Strange..
What lcd model is it?
and can i have you put "omapfb.debug=y" in your bootargs, this will
make dss2 more verbose in dmesg...
LCD model is BENQ G2220HD.
Also I have tried to set the "omapfb.debug=y" in boot.cmd but it
doesn't work. Do I need to set up the SD card again by changing the
bootargs in setup_sdcard.sh?
-Sandip
Also I have created image using rootstock command
sudo ./rootstock --fqdn beagleboard --login ubuntu --password temppwd
--imagesize 2G \
--seed wget,nano,linux-firmware,wireless-tools,usbutils --dist lucid --
serial ttyS2 \
--components "main universe multiverse" \
--kernel-image http://rcn-ee.net/deb/lucid/v2.6.33.4-l3/linux-image-2.6.33.4-l3_1.0lucid_armel.deb
But the generated image is unable to bring up the network. So do you
have any idea what is the problem with that? Or is there any special
settings we need to do?
For demo image networks works on usb1 interface but in rootstock image
it's unable to detect the usb1.
-Sandip
--imagesize 2G \
serial ttyS2 \
Of all the kernel releases available, why did you choose that one?
Honesty, i'd really like to know...
That's correct and i know exactly, but i'd like to know your answer to
above first..
Yeap, you need to edit boot.cmd, then generate an boot.scr for u-boot to read:
Good overview here: http://elinux.org/BeagleBoardUbuntu#U-Boot_Boot_Scripts
Just note, the content that's on your boot.cmd is the latest, whereas
that page is alittle dated, but the mkimage command is still good..
Good news, I got a display. Can we use the openbox instead of xfce4?
Please find below the boot message with bootargs "omapfb.debug=y"
UTC 2010
cr=10c53c7f
instruction cache
0x100000
Total pages: 130048
1280x720MR-16@60 omapfb.debug=y fixrtc buddy=none mpurate=800
262144 bytes)
bytes)
want memory cgroups
highmem
CPUs=1, Nodes=1
early_init...
interrupts
[ 0.000000] Calibrating delay loop... 509.42 BogoMIPS (lpj=1990656)
0x011c
0x011c
0x010b
0x010b
0x010b
0x010b
0x010b
0x010b
0x010b
0x010b
0x010b
0x010b
0x010b
0x010b
0x010b
0x010b
0x010b
0x010b
0x0000
0x0000
26.0/800/332 MHz
[ 0.004882] SCSI subsystem initialized
0x0118
0x0118
0x0118
0x0118
0x0118
[ 0.009674] mux: Setting signal sdmmc1_dat3.sdmmc1_dat3 0x0118 ->
0x0118
[ 0.009857] mux: Setting signal sdmmc2_clk.sdmmc2_clk 0x011c ->
0x0118
0x0118
0x0118
0x0118
[ 0.010131] mux: Setting signal sdmmc2_dat2.sdmmc2_dat2 0x011c ->
0x0118
0x0118
[ 0.013580] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal
standby
[ 0.014160] regulator: VPLL2: 1800 mV normal standby
standby
[ 0.026519] i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz
[ 0.026672] i2c_omap i2c_omap.3: bus 3 rev4.0 at 100 kHz
[ 0.027343] Advanced Linux Sound Architecture Driver Version
1.0.23.
[ 0.027770] NetLabel: Initializing
[ 0.027801] NetLabel: domain hash size = 128
[ 0.027832] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.027893] NetLabel: unlabeled traffic allowed by default
[ 0.027954] Switching to clocksource 32k_counter
[ 0.043640] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 0.048400] musb_hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk
[ 0.048431] musb_hdrc: MHDRC RTL version 1.800
[ 0.048431] musb_hdrc: setup fifo_mode 5
[ 0.048461] musb_hdrc: 28/31 max ep, 8192/16384 memory
[ 0.048614] musb_hdrc musb_hdrc: USB OTG mode controller at
[ 0.048919] NET: Registered protocol family 2
[ 0.049163] IP route cache hash table entries: 4096 (order: 2,
16384 bytes)
[ 0.049865] TCP established hash table entries: 16384 (order: 5,
131072 bytes)
[ 0.050170] TCP bind hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.050354] TCP: Hash tables configured (established 16384 bind
16384)
[ 0.050384] TCP reno registered
[ 0.050415] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.050445] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.050659] NET: Registered protocol family 1
[ 0.051025] RPC: Registered udp transport module.
[ 0.051086] RPC: Registered tcp transport module.
[ 0.051116] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 0.051391] Trying to unpack rootfs image as initramfs...
[ 0.359497] Freeing initrd memory: 4116K
[ 0.360198] PMU: registered new PMU device of type 0
[ 0.360290] dspbridge_init: 600000 bytes @ 82700000
[ 0.360717] audit: initializing netlink socket (disabled)
[ 0.360809] type=2000 audit(0.734:1): initialized
[ 0.473968] VFS: Disk quotas dquot_6.5.2
[ 0.474273] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 0.477966] fuse init (API version 7.14)
[ 0.479278] Btrfs loaded
[ 0.479339] msgmni has been set to 956
[ 0.481079] alg: No test for stdrng (krng)
[ 0.481536] Block layer SCSI generic (bsg) driver version 0.4
loaded (major 254)
[ 0.481597] io scheduler noop registered
[ 0.481597] io scheduler deadline registered
[ 0.481689] io scheduler cfq registered (default)
[ 0.543853] OMAP DSS rev 2.0
[ 0.543945] OMAP DISPC rev 3.0
[ 0.544006] OMAP VENC rev 2
[ 0.872589] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.954467] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 1.120117] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 1.285736] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 2.182067] console [ttyS2] enabled
[ 2.190979] brd: module loaded
[ 2.196746] loop: module loaded
[ 2.202178] omap2-nand driver initializing
[ 2.206573] No NAND device found.
[ 2.210113] No NAND device found.
[ 2.213623] OneNAND driver initializing
[ 2.217834] usbcore: registered new interface driver cdc_ether
[ 2.223815] usbcore: registered new interface driver rndis_host
[ 2.230285] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 2.237121] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 2.243103] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 1
[ 2.250701] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 2.270294] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 2.276702] hub 1-0:1.0: USB hub found
[ 2.280578] hub 1-0:1.0: 3 ports detected
[ 2.309448] Initializing USB Mass Storage driver...
[ 2.314483] usbcore: registered new interface driver usb-storage
[ 2.320556] USB Mass Storage support registered.
[ 2.325286] g_ether gadget: using random self ethernet address
[ 2.331176] g_ether gadget: using random host ethernet address
[ 2.337860] usb0: MAC b2:da:54:b0:d5:83
[ 2.341796] usb0: HOST MAC e2:53:d5:46:3d:e2
[ 2.346130] g_ether gadget: Ethernet Gadget, version: Memorial Day
2008
[ 2.352844] g_ether gadget: g_ether ready
[ 2.356933] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 2.362365] musb_hdrc musb_hdrc: new USB bus registered, assigned
bus number 2
[ 2.370239] hub 2-0:1.0: USB hub found
[ 2.374084] hub 2-0:1.0: 1 port detected
[ 2.378509] mice: PS/2 mouse device common for all mice
[ 2.384552] input: twl4030_pwrbutton as /devices/platform/i2c_omap.
[ 2.395355] i2c /dev entries driver
[ 2.399963] device-mapper: uevent: version 1.0.3
[ 2.405487] device-mapper: ioctl: 4.17.0-ioctl (2010-03-05)
[ 2.414337] device-mapper: multipath: version 1.1.1 loaded
[ 2.419921] device-mapper: multipath round-robin: version 1.0.0
loaded
[ 2.427154] sdhci: Secure Digital Host Controller Interface driver
[ 2.433410] sdhci: Copyright(c) Pierre Ossman
[ 2.441070] mmci-omap-hs: probe of mmci-omap-hs.1 failed with error
-16
[ 2.447998] Registered led device: beagleboard::usr0
[ 2.448059] Registered led device: beagleboard::usr1
[ 2.450653] Registered led device: beagleboard::pmu_stat
[ 2.451293] No device for DAI tlv320aic23
[ 2.524414] No device for DAI omap-mcbsp-dai-0
[ 2.528961] No device for DAI omap-mcbsp-dai-1
[ 2.533447] No device for DAI omap-mcbsp-dai-2
[ 2.537933] No device for DAI omap-mcbsp-dai-3
[ 2.542419] No device for DAI omap-mcbsp-dai-4
[ 2.546936] No device for DAI omap-mcpdm
[ 2.550903] Not OMAP3 EVM!
[ 2.553649] Not OMAP3517 / AM3517 EVM!
[ 2.557434] OMAP3 Beagle/Devkit8000 SoC init
[ 2.562438] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 2.570556] ALSA device list:
[ 2.573577] #0: omap3beagle (twl4030)
[ 2.578765] TCP cubic registered
[ 2.582916] NET: Registered protocol family 10
[ 2.588714] lo: Disabled Privacy Extensions
[ 2.594573] NET: Registered protocol family 17
[ 2.599304] ThumbEE CPU extension supported.
[ 2.605072] Power Management for TI OMAP3.
[ 2.615112] Disabling unused clock "sr2_fck"
[ 2.615142] Disabling unused clock "sr1_fck"
[ 2.615173] Disabling unused clock "mcbsp4_fck"
[ 2.615173] Disabling unused clock "mcbsp3_fck"
[ 2.615203] Disabling unused clock "mcbsp2_fck"
[ 2.615203] Disabling unused clock "mcbsp4_ick"
[ 2.615234] Disabling unused clock "mcbsp3_ick"
[ 2.615234] Disabling unused clock "mcbsp2_ick"
[ 2.615264] Disabling unused clock "gpt2_ick"
[ 2.615264] Disabling unused clock "gpt3_ick"
[ 2.615295] Disabling unused clock "gpt4_ick"
[ 2.615295] Disabling unused clock "gpt5_ick"
[ 2.615295] Disabling unused clock "gpt6_ick"
[ 2.615325] Disabling unused clock "gpt7_ick"
[ 2.615325] Disabling unused clock "gpt8_ick"
[ 2.615356] Disabling unused clock "gpt9_ick"
[ 2.615356] Disabling unused clock "wdt3_ick"
[ 2.615386] Disabling unused clock "wdt3_fck"
[ 2.615386] Disabling unused clock "gpio2_dbck"
[ 2.615417] Disabling unused clock "gpio3_dbck"
[ 2.615417] Disabling unused clock "gpio4_dbck"
[ 2.615447] Disabling unused clock "gpio5_dbck"
[ 2.615447] Disabling unused clock "gpio6_dbck"
[ 2.615447] Disabling unused clock "gpt9_fck"
[ 2.615478] Disabling unused clock "gpt8_fck"
[ 2.615478] Disabling unused clock "gpt7_fck"
[ 2.615509] Disabling unused clock "gpt6_fck"
[ 2.615509] Disabling unused clock "gpt5_fck"
[ 2.615539] Disabling unused clock "gpt4_fck"
[ 2.615539] Disabling unused clock "gpt3_fck"
[ 2.615570] Disabling unused clock "gpt2_fck"
[ 2.615570] Disabling unused clock "gpt1_ick"
[ 2.615570] Disabling unused clock "wdt1_ick"
[ 2.615600] Disabling unused clock "wdt2_ick"
[ 2.615600] Disabling unused clock "wdt2_fck"
[ 2.615631] Disabling unused clock "gpio1_dbck"
[ 2.615631] Disabling unused clock "gpt1_fck"
[ 2.615661] Disabling unused clock "cam_ick"
[ 2.615692] Disabling unused clock "cam_mclk"
[ 2.615722] Disabling unused clock "des1_ick"
[ 2.615753] Disabling unused clock "sha11_ick"
[ 2.615753] Disabling unused clock "rng_ick"
[ 2.615753] Disabling unused clock "aes1_ick"
[ 2.615783] Disabling unused clock "ssi_ick"
[ 2.615783] Disabling unused clock "mailboxes_ick"
[ 2.615814] Disabling unused clock "mcbsp1_ick"
[ 2.615814] Disabling unused clock "mcbsp5_ick"
[ 2.615844] Disabling unused clock "gpt10_ick"
[ 2.615844] Disabling unused clock "gpt11_ick"
[ 2.615875] Disabling unused clock "mcspi3_ick"
[ 2.615875] Disabling unused clock "mcspi4_ick"
[ 2.615905] Disabling unused clock "hdq_ick"
[ 2.615905] Disabling unused clock "mspro_ick"
[ 2.615936] Disabling unused clock "des2_ick"
[ 2.615936] Disabling unused clock "sha12_ick"
[ 2.615936] Disabling unused clock "aes2_ick"
[ 2.615966] Disabling unused clock "icr_ick"
[ 2.615966] Disabling unused clock "pka_ick"
[ 2.615997] Disabling unused clock "ssi_ssr_fck"
[ 2.615997] Disabling unused clock "hdq_fck"
[ 2.616027] Disabling unused clock "mcspi3_fck"
[ 2.616027] Disabling unused clock "mcspi4_fck"
[ 2.616027] Disabling unused clock "mcbsp1_fck"
[ 2.616058] Disabling unused clock "mcbsp5_fck"
[ 2.616058] Disabling unused clock "mspro_fck"
[ 2.616088] Disabling unused clock "gpt11_fck"
[ 2.616088] Disabling unused clock "gpt10_fck"
[ 2.616119] Disabling unused clock "sad2d_ick"
[ 2.616119] Disabling unused clock "dpll4_m6x2_ck"
[ 2.616149] Disabling unused clock "dpll3_m3x2_ck"
[ 2.616180] Disabling unused clock "sys_clkout1"
[ 2.616180] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 3
[ 2.624664] registered taskstats version 1
[ 2.628875] OMAPFB: omapfb_init
[ 2.628967] OMAPFB: omapfb_probe
[ 2.628997] fbcvt: 1280x720@60: CVT Name - .921M9-R
[ 2.634002] OMAPFB: create 3 framebuffers
[ 2.634033] OMAPFB: fb_infos allocated
[ 2.634033] OMAPFB: allocating 1843200 bytes for fb 0
[ 2.645538] OMAPFB: allocated VRAM paddr 81a06000, vaddr e0a00000
[ 2.645568] OMAPFB: region0 phys 81a06000 virt e0a00000
size=1843200
[ 2.645568] OMAPFB: region1 phys 00000000 virt (null) size=0
[ 2.645599] OMAPFB: region2 phys 00000000 virt (null) size=0
[ 2.645599] OMAPFB: fbmems allocated
[ 2.645629] OMAPFB: check_fb_var 0
[ 2.645629] OMAPFB: max frame size 1843200, line size 2560
[ 2.645629] OMAPFB: xres = 1280, yres = 720, vxres = 1280, vyres =
720
[ 2.645660] OMAPFB: set_fb_fix
[ 2.645660] OMAPFB: fb_infos initialized
[ 2.646118] OMAPFB: set_par(0)
[ 2.646118] OMAPFB: set_fb_fix
[ 2.646148] OMAPFB: apply_changes, fb 0, ovl 0
[ 2.646148] OMAPFB: setup_overlay 0, posx 0, posy 0, outw 1280,
outh 720
[ 2.646148] OMAPFB: paddr 81a06000, vaddr e0a00000
[ 2.646392] OMAPFB: pan_display(0)
[ 2.646392] OMAPFB: setcmap
[ 2.654693] Console: switching to colour frame buffer device 160x45
[ 2.654724] OMAPFB: pan_display(0)
[ 2.654724] OMAPFB: setcmap
[ 2.662170] OMAPFB: setcmap
[ 2.669067] OMAPFB: framebuffers registered
[ 2.669067] OMAPFB: apply_changes, fb 0, ovl 0
[ 2.669097] OMAPFB: setup_overlay 0, posx 0, posy 0, outw 1280,
outh 720
[ 2.669097] OMAPFB: paddr 81a06000, vaddr e0a00000
[ 2.669128] OMAPFB: apply_changes, fb 1, ovl 1
[ 2.669128] OMAPFB: apply_changes, fb 2, ovl 2
[ 2.669128] OMAPFB: create sysfs for fbs
[ 2.669158] OMAPFB: create sysfs for fbs
[ 2.669250] OMAPFB: create_framebuffers done
[ 2.669433] OMAPFB: mgr->apply'ed
[ 2.672637] regulator_init_complete: incomplete constraints,
leaving VDAC on
[ 2.680206] Freeing init memory: 260K
[ 2.692321] usb 1-2: new high speed USB device using ehci-omap and
address 2
[ 2.813079] udev: starting version 151
[ 2.866333] hub 1-2:1.0: USB hub found
[ 2.872039] mmc0: host does not support reading read-only switch.
[ 2.930694] hub 1-2:1.0: 5 ports detected
[ 3.085388] mmc0: new SDHC card at address e624
[ 3.132049] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[ 3.145629] mmcblk0: p1 p2
[ 3.395721] usb 1-2.1: new high speed USB device using ehci-omap
and address 3
[ 3.661193] usb 1-2.2: new low speed USB device using ehci-omap and
address 4
[ 3.690704] OMAPFB: pan_display(0)
[ 3.690734] OMAPFB: setcmap
[ 3.880065] usb 1-2.4: new low speed USB device using ehci-omap and
address 5
[ 3.896728] usbcore: registered new interface driver hiddev
[ 3.917510] input: GASIA GASIA USB KB Pro as /devices/platform/ehci-
omap.0/usb1/1-2/1-2.2/1-2.2:1.0/input/input1
[ 3.953430] generic-usb 0003:0E8F:0021.0001: input,hidraw0: USB HID
v1.10 Keyboard [GASIA GASIA USB KB Pro] on usb-ehci-omap.0-2.2/input0
[ 3.986358] input: GASIA GASIA USB KB Pro as /devices/platform/ehci-
omap.0/usb1/1-2/1-2.2/1-2.2:1.1/input/input2
[ 4.013824] generic-usb 0003:0E8F:0021.0002: input,hidraw1: USB HID
v1.10 Device [GASIA GASIA USB KB Pro] on usb-ehci-omap.0-2.2/input1
[ 4.036743] usbcore: registered new interface driver usbhid
[ 4.051666] usbhid: USB HID core driver
[ 4.070800] input: USB+PS/2 Optical Mouse as /devices/platform/ehci-
omap.0/usb1/1-2/1-2.4/1-2.4:1.0/input/input3
[ 4.115447] generic-usb 0003:04F3:0230.0003: input,hidraw2: USB HID
v1.11 Mouse [USB+PS/2 Optical Mouse] on usb-ehci-omap.0-2.4/input0
[ 4.249084] OMAPFB: pan_display(0)
[ 4.249084] OMAPFB: setcmap
[ 4.249114] OMAPFB: setcmap
[ 4.408020] EXT4-fs (mmcblk0p2): mounted filesystem with ordered
[ 6.521118] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-
ro
[ 6.811553] udev: starting version 151
[ 7.327209] input: gpio-keys as /devices/platform/gpio-keys/input/
input4
[ 7.798156] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 7.882720] smsc95xx v1.0.4
[ 8.074218] smsc95xx 1-2.1:1.0: usb1: register 'smsc95xx' at usb-
ehci-omap.0-2.1, smsc95xx USB 2.0 Ethernet, c2:7f:12:4f:98:19
[ 8.074340] usbcore: registered new interface driver smsc95xx
[ 9.199218] Adding 51196k swap on /mnt/SWAP.swap. Priority:-1
extents:3 across:67580k SS
-Sandip
I got that link from the wiki so I used the same. And I did not check
for the another version. Do we have network support in another
version?
Yes, I have installed the openbox and it works without any problem.
Is there any way that we can get rid of the gdm and start xserver
directly from the rc.local without using the login window for openbox?
Because I have un-installed the gdm and xubuntu-gdm-themes and tried
to load the openbox directly. But it doesn't work.
Which wiki? it's about 6 months out of date and needs to be edited so
other users don't fall into the same issue.. I didn't start rolling in
xm fixes till 2.6.34
If you look at the images here:
http://elinux.org/BeagleBoardUbuntu#Demo_Image
I give the rootstock build instructions at the end of both sections..
Sorry, My mistake copy paste typo. I have sent you the rootstock
command with wrong version of kernel.
I have used the command from lucid only
sudo ./rootstock --fqdn omap --imagesize 2G --dist lucid --serial
ttyS2 \
--login ubuntu --password temppwd \
--seed aptitude,btrfs-tools,i2c-tools,nano,pastebinit,uboot-
envtools,uboot-mkimage,usbutils,wget,wireless-tools,wpasupplicant \
--script fixup.sh --components "main universe multiverse" \
--kernel-image http://rcn-ee.net/deb/lucid/v2.6.35.8-l7/linux-image-2.6.35.8-l7_1.0lucid_armel.deb
-Sandip
Hello Robert,
Is there any way to get rid of the login manager for GUI? Because I do
not need the login manager so.
-Sandip
using google, i'd search for: "gdm autologin"
