Yocto custom recipe for building beaglebone black's kernel from github for chipsee LCD.
Hi Experts,
I was trying to build Linux for beaglebone black from official repository
I am able to fetch and run menuconfig but when i try to compile the kernel i get error.
Following is the content of the recipe file.
file name : linux-yocto-chipsee_3.14.bb
path: /home/ankur/yocto_daisy/poky/meta-ybdevelop/recipes-example/linux
inherit kernel
require recipes-kernel/linux/linux-yocto.inc
BRANCH = “3.14”
Override SRC_URI in a bbappend file to point at a different source
tree if you do not want to build from Linus’ tree.
SRC_URI = “git://github.com/beagleboard/linux.git;branch=${BRANCH};nocheckout=1;name=machine”
LINUX_VERSION ?= “3.14”
LINUX_VERSION_EXTENSION ?= “-custom”
Override SRCREV to point to a different commit in a bbappend file to
build a different release of the Linux kernel.
tag: v3.4 76e10d158efb6d4516018846f60c2ab5501900bc
SRCREV_machine=“76e10d158efb6d4516018846f60c2ab5501900bc”
PR = “r1”
PV = “${LINUX_VERSION}+git${SRCPV}”
Override COMPATIBLE_MACHINE to include your machine in a bbappend
file. Leaving it empty here ensures an early explicit build failure.
COMPATIBLE_MACHINE = “beaglebone”
File name :linux-yocto-chipsee_3.14.bbappend
File path : /home/ankur/yocto_daisy/poky/meta-ybdevelop/recipes-example/linux
defconfig path: /home/ankur/yocto_daisy/poky/meta-ybdevelop/recipes-example/linux/linux-yocto-chipsee_3.14
With above configuration i am able to fetch and open menuconfig for fetched linux kernel, command i used is as follows,
-----Below command works----
bitbake linux-yocto-chipsee -c menuconfig
But when i try to compile linux using below command it gives error,
-----Below command gives below errors----
bitbake linux-yocto-chipsee -c compile
/bin/sh: 1: arm-poky-linux-gnueabi-gcc: not found
make[4]: *** [scripts/mod/empty.o] Error 127
make[3]: *** [scripts/mod] Error 2
make[3]: *** Waiting for unfinished jobs…
SHIPPED scripts/genksyms/lex.lex.c
Generating include/generated/mach-types.h
SHIPPED scripts/genksyms/keywords.hash.c
SHIPPED scripts/genksyms/parse.tab.h
SHIPPED scripts/genksyms/parse.tab.c
HOSTCC scripts/genksyms/lex.lex.o
CC kernel/bounds.s
When i try to build using below command that time also it failed.
-----Below command gives below errors along with previous error—
bitbake linux-yocto-chipsee -c build
ERROR: Multiple .bb files are due to be built which each provide virtual/kernel (/home/ankur/yocto_daisy/poky/meta-ybdevelop/recipes-example/linux/linux-yocto-chipsee_3.14.bb /home/ankur/yocto_daisy/poky/meta/recipes-kernel/linux/linux-yocto_3.14.bb).
This usually means one provides something the other doesn’t and should.
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Function failed: do_compile (log file is located at /home/ankur/yocto_daisy/poky/build_fresh/tmp/work/beaglebone-poky-linux-gnueabi/linux-yocto-chipsee/3.14+gitAUTOINC+76e10d158e-r1/temp/log.do_compile.30878)
ERROR: Logfile of failure stored in: /home/ankur/yocto_daisy/poky/build_fresh/tmp/work/beaglebone-poky-linux-gnueabi/linux-yocto-chipsee/3.14+gitAUTOINC+76e10d158e-r1/temp/log.do_compile.30878
Bitbake layers for linux shows below output
bitbake-layers show-recipes ‘linux*’
Parsing recipes…done.
=== Available recipes matching linux*: ===
linux-dummy:
meta 1.0
linux-firmware:
meta 1:0.0+gitAUTOINC+600caefd83
linux-libc-headers:
meta 3.14
linux-yocto:
meta 3.14.4+gitAUTOINC+183622e809_0143c6ebb4
meta 3.10 (skipped)
meta 3.4 (skipped)
linux-yocto-chipsee:
meta-ybdevelop 3.14+gitAUTOINC+76e10d158e
linux-yocto-dev:
meta unknown (skipped)
linux-yocto-rt:
meta 3.10 (skipped)
meta 3.14 (skipped)
meta 3.4 (skipped)
linux-yocto-tiny:
meta 3.10 (skipped)
meta 3.14 (skipped)
meta 3.4 (skipped)
linuxdoc-tools-native:
meta 0.9.69
linuxptp:
meta-oe 1.4
Any help/pointer/hint/suggestions to complete this ?
Thank you,
Ankur
Hi Ankur,
have you got it to work?
How did you do?
Hi Michael,
I had updated details in below stackoverflow post,
Hope it will help you,
http://stackoverflow.com/questions/30723261/building-robert-nelsons-linux-kernel-into-yoctodaisy-for-beaglebone-black
Thank you,
Ankur
Hi Ankur,
i am new with Yocto can you explain in a little bit more detailed?
I commented in blue what i dindt understand.
Can you tell me before doing bitbake waht did you do?
Are you able to use USB/HDMI/SOUND on Chipsee Display?
I have the Capacitive Touch what sould i do different?
It runs on I2C.
Thank you,
Michael
Well for time being i downloaded the Yocto_daisy(1.6) toolchain and installed it in my PC. And compiled the Linux external to Yocto build. Here are steps.
I followed below steps in my virtualbox installed ubuntu.
  1. in Yocto_daisy build core-image-sato, using following command,
  2. bitbake core-image-sato This is the first thing you do?
  3. Prepare micro SD card with rootfile system, SPL & U-Boot, uImage, dtb, uEnv.txt. How do you prepare the SD card?
  4. Clone beaglebone black Linux using following command
    git clone --depth=1 https://github.com/beagleboard/linux
  5. Download yocto-1.6(daisy) toolchain from following link.
    http://downloads.yoctoproject.org/releases/yocto/yocto-1.6/toolchain/
    Based on your machine type download from either i686 or x86_64
    I downloaded following toochain.
    http://downloads.yoctoproject.org/releases/yocto/yocto-1.6/toolchain/i686/poky-eglibc-i686-core-image-sato-armv7a-vfp-neon-toolchain-1.6.sh
  6. Install toolchain by running download toolchain script. By default it installs into opt directory, I installed it in default path.
  7. In terminal traverse to the above downloaded Linux directory. and set toolchain environment by running following command,
    source /opt/poky/1.6/environment-setup-armv7a-vfp-neon-poky-linux-gnueabi
  8. Now configure kernel using following command,
make bb.org_defconfig
  1. and then build kernel using following command
    make uImage LOADADDR=0x80008000 -j4
  2. now we shall install the modules into local directory using following commands,
    mkdir bbb_modules
    export INSTALL_MOD_PATH=/home/ankur/linux/bbb_modules/
    make modules_install
  3. when kernel is built copy uImage(from /arch/arm/boot) and am335x-boneblack-bbb-exp-c.dtb(from /arch/arm/boot) to the BOOT partition of the micro SD card.
For FYI my uEnv.txt looks like this
Disable: HDMI
bootargs=console=ttyO1,115200n8 root=/dev/mmcblk0p2 rootfstype=ext4 rw rootwait;
bootcmd=mmc rescan ; mmc dev 0 ; fatload mmc 0 0x80007fc0 uImage ; fatload mmc 0 0x80F80000 am335x-boneblack-bbb-exp-c.dtb ; echo Ankur... ${bootcmd}; bootm 0x80007fc0 - 0x80F80000;
uenvcmd=boot;
11 . Now copy modules from local directory to the micro SD card, using following commands,
cp -a /home/ankur/linux/bbb_modules/lib /media/ankur/ROOT/
sync
  1. Eject the card put it into Beaglbone Black and power on the BBB+LCD.
I am yet to get the Touch calibration working for LCD but once I find it i will update the answer.
Another pending thing is build above kernel into Yocto build system. I will update the answer once i am done with that.
Hope this helps someone with the same issue.
