Yoctoproject sato image - Not booting from SD - serial debugging
I am trying to Beaglebone to work with Yoctoproject. I followed the instructions from https://www.yoctoproject.org/downloads/bsps/jethro20/beaglebone and copied sato-image to SD card. But the image won’t boot.
A Note on how I partitioned my SD:
sudo fdisk -lu /dev/sdb
Disk /dev/sdb: 15.5 GB, 15523119104 bytes
64 heads, 32 sectors/track, 14804 cylinders, total 30318592 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x000d842d
Device Boot Start End Blocks Id System
/dev/sdb1 * 2048 67583 32768 c W95 FAT32 (LBA)
/dev/sdb2 67584 30318591 15125504 83 Linux
I’m using PL2303 USB-TTL cable to debug.
O/P on the serial console :
U-Boot SPL 2016.01 (Feb 15 2016 - 19:53:09)
Trying to boot from MMC
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
U-Boot 2016.01 (Feb 15 2016 - 19:53:09 -0500)
Watchdog enabled
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
*** Error - No Valid Environment Area found
*** Warning - bad CRC, using default environment
cpsw, usb_ether
The problem is not with my board/SD card. I tried on a different set…same error pops.
Can some one please help me debug this? what are the possible reasons for ‘Error - No Valid Environment Area found’?
Thank you
Phani
u-boot 2016.01 is broken, this was fixed in git shortly after release..
http://git.denx.de/?p=u-boot.git;a=commit;h=7205442e621db54ea06c3bca2d793e1ae2214f9c
The patch fix that you pointed to, was made on ‘Thu, 10 Dec 2015’. O/p in my serial console says 'U-Boot 2016.01 (Feb 15 2016…
So, I believe that the patch must have been already applied. Please correct me if I’m wrong.
Phani
Correct you are wrong:
voodoo@hestia:/opt/github/u-boot$ git checkout
7205442e621db54ea06c3bca2d793e1ae2214f9c -b tmp
Switched to a new branch 'tmp'
voodoo@hestia:/opt/github/u-boot$ git describe
v2016.01-103-g7205442
7205442e621db54ea06c3bca2d793e1ae2214f9c was after v2016.01 was released
and shortly before v2016.03-rc1
coughhehcough
