“You can’t brick it”, that is what Gerald says (or was it someone else).
Well, here I am.
(I posted earlier on this issue, please ignore the post “BBB with Ubuntu: locked out, no SSH response” as it is outdated.)
SUMMARY: After being flashed with Ubuntu or Debian, BBB does not respond to Serial or SSH session from PuTTY.
Debian
Received a BBB Rev C from Adafruit, Debian pre-installed.
I’m doing everything via USB so far.
Log in with PuTTY serial; BBB displayed the message that it was running Debian indeed.
Ubuntu
Flash Ubuntu onto eMMC from uSD (scrupulously following the rules as explained on various sites).
Log in on Ubuntu (SSH 192.168.7.2) and set a root password.
Power down, power up, log in as root, OK.
Change /etc/network/interfaces to change from DHCP to Static IP. Left the USB-section untouched.
All of the above exactly as I did before on another BBB.
NOW IT GOES WRONG:
Power down, power up, start PuTTY as SSH 192.168.7.2. The window opens, steady cursor, no response.
PuTTY Serial, the window opens, steady cursor, no response.
The LEDs show normal behaviour: USR0=heartbeat, USR2 shows slight CPU activity.
BBB appears on my PC in Devices and Printers as “Gadget Serial (COM3)”.
With Explorer on my PC, I can inspect the eMMC and even open START.htm (Firefox starts, the “Getting started” page displays)
Debian again
Flash Debian onto eMMC.
Power down, power up, start PuTTY with SSH 192.168.7.2. The window opens, steady cursor, no response.
Angstrom
After this I managed to flash Angstrom successfully, but never did I succeed with repeating Ubuntu or Debian flashes.
Note a few things:
· I did install the extra drivers on the PC as the Getting Started page says.
· Flashing Angstrom takes 40 min. During the process, the LEDs flash erratically (so it seems, BBB knows better of course).
· Flashing Ubuntu takes <5 min. The LEDs show a neat running light that bounces forth and back.
· From previous experience, I expect Angstrom and Debian to appear when I make a Serial connection, whereas Ubuntu requires SSH on 192.168.7.2.
