Tomi,
Tim has patched your latest DSS2 2.6.29 git (master branch) to add
support for YUV rotation. It has been successfully tested on the coming
Touch Book, as well as the Beagleboard Rev B6 with the exception of the
bug mentioned below. You may want to review this patch and perhaps
integrate once we have fixed the problem below.
A couple of questions and comments:
1. dss.c has no way of knowing whether VRFB is being used or not --
this is a problem because you need to decide whether to call
calc_rotation_offset_vrfb(...) or calc_rotation_offset(...). Any
suggestions on how the rotation mode should be passed between dss.c and
omapfb-main.c?
2. If I try to rotate both plane 0 and plane 1 to either 90 degrees or
270 (doesn't matter which is which), as soon as you try to play a video
you get VID1_FIFO_UNDERFLOW error messages, so it seems that the
hardware seems to be struggling a little when you have two sets of
90/270 degree rotations. If one of the planes is 0/180 and the other
is 90/270, then everything is fine. Would changing the FIFO settings
somehow improve this or do you have any ideas about what else might make
it work better?
Thanks in advance,
Grégoire Gentil
vrfb-yuv-rotation.patch (5.92 KB)
