0x400(arch1)
Hi all,
my kernel version is :
/opt/scripts/tools# ./version.sh
git:/opt/scripts/:[674bb55e34e94e3837f4f55790c7d1a52c9e149f]
eeprom:[A335BNLT00C02208SBB16124]
dogtag:[BeagleBoard.org Debian Buster LXQt Image 2020-08-25]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot SPL 2019.04-00002-gc9b3922522 (Aug 24 2020 - 16:42:18 -0500)]:[location: dd MBR]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2019.04-00002-gc9b3922522]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts]
UBOOT: Loaded Overlay:[AM335X-PRU-UIO-00A0]
UBOOT: Loaded Overlay:[BB-ADC-00A0.bb.org-overlays]
kernel:[4.19.94-ti-r50]
nodejs:[v10.24.0]
/boot/uEnv.txt Settings:
uboot_overlay_options:[disable_uboot_overlay_emmc=1]
uboot_overlay_options:[disable_uboot_overlay_video=1]
uboot_overlay_options:[disable_uboot_overlay_audio=1]
uboot_overlay_options:[disable_uboot_overlay_wireless=1]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-UIO-00A0.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-cape-overlays]:[4.14.20210821.0-0~buster+20210821]
pkg:[bb-customizations]:[1.20240119.0-0~buster+20240119]
pkg:[bb-usb-gadgets]:[1.20230414.0-0~buster+20230414]
pkg:[bb-wl18xx-firmware]:[1.20230414.0-0~buster+20230414]
pkg:[kmod]:[26-1]
pkg:[librobotcontrol]:[1.0.5-git20200715.0-0~buster+20200716]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~buster+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal input bluetooth netdev i2c gpio admin spi iio docker tisdk weston-launch xenomai cloud9ide pwm eqep remoteproc]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[14880114.028310] Modules linked in: pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc virtio virtio_ring uio_pruss usb_f_acm u_serial usb_f_ncm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio appletalk ax25 spidev
[14880114.067577] Modules linked in: pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc virtio virtio_ring uio_pruss usb_f_acm u_serial usb_f_ncm usb_f_mass_storage usb_f_rndis u_ether
[14880114.106846] Modules linked in: pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc virtio virtio_ring uio_pruss usb_f_acm u_serial usb_f_ncm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio appletalk ax25 spidev
[14880114.146114] Modules linked in: pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc virtio virtio_ring uio_pruss usb_f_acm u_serial usb_f_ncm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio appletalk ax25 spidev
[14880114.185383] Modules linked in: pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc virtio virtio_ring uio_pruss usb_f_acm u_serial usb_f_ncm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio appletalk ax25 spidev
[14880114.224655] Modules linked in: pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc virtio virtio_ring uio_pruss usb_f_acm u_serial usb_f_ncm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio appletalk ax25 spidev
[14880114.263926] Modules linked in: pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc virtio virtio_ring uio_pruss usb_f_acm u_serial usb_f_ncm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio appletalk ax25 spidev
[14880114.303196] Modules linked in: pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc virtio virtio_ring uio_pruss usb_f_acm u_serial usb_f_ncm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio appletalk ax25 spidev
[14880114.342467] Modules linked in: pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc virtio virtio_ring uio_pruss usb_f_acm u_serial usb_f_ncm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio appletalk ax25 spidev
And I am having everytime a flags:
[ +0.000008] BUG: Bad page state in process rs:main Q:Reg pfn:96ea3
[ +0.006556] page:dfc99eec count:0 mapcount:0 mapping:00000000 index:0x1
[ +0.006906] flags: 0x400(arch_1)
[ +0.003508] raw: 00000400 00000100 00000200 00000000 00000001 00000000 ffffffff 00000000
[ +0.008387] raw: 00000000
[ +0.002891] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ +0.006466] bad because of flags: 0x400(arch_1)
What could be the issue?
I am still having issue with my Kernel,
Is there anyone who may help??
version.txt (25,2 Ko)
dmesg.txt (123,9 Ko)
D
is your hart set on using such an old image ??
there is a 2023 image, can you try that and see if you get the same issues
Hi amf99,
thanks for your advise. Yes I know that is an old debian kernel I am using since years until I face those issues described in my files. I will need to install all modules for NI-USB visa and of course drivers for uio pruss. we are using this instead of remoteproc because we had already some api that could build and generate pattern and this was done with uio pruss.
I was hoping to solve this issue keeping the same kernel but you are maybe right to jumb to new image. is this image having Cloud9 installed?
I don’t have clue about what is going on with your board, this is all conjecture.
It appears the kernel is having an issue with memory rs:main. Since that is an old kernel I would suspect it has been running perfectly until this point. Hence, might be the ram has an issue. It might have some logs that have now filled up all the emmc??? If you can jump start it on SD card and mount emmc then look around and see if that is filled up. This is just a guess, not having the board and intimate knowledge of the code makes this difficult.
