I tried 6M, it is O.K. for more, no joy. Here is full log, ignore
dsplink error since the kernel is a new build.
[ 0.000000] Linux version 2.6.32 (gcc version 4.3.3 (GCC) ) #9
PREEMPT Sun May 8 22:03:58 BST 2011
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430/3530 ES3.1 (l2cache iva sgx neon isp 720m )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x100000
[ 0.000000] Reserving 14680064 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 32512
[ 0.000000] Kernel command line: mem=128M@0x80000000 psplash=false
console=ttyS2,115200n8 omapdss.vram=24M omapfb.mode=dvi:
1920x1080MR-24@30 omapfb.debug=y omapdss.def_disp=dvi root=/dev/
mmcblk0p2 rootfstype=t
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768
bytes)
[ 0.000000] Memory: 128MB = 128MB total
[ 0.000000] Memory: 108756KB available (5712K code, 623K data, 172K
init, 0K highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Calibrating delay loop... 505.22 BogoMIPS (lpj=1974272)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] tmpfs: No value for mount option 'mode'
[ 0.000000] devtmpfs: initialized
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] Unable to get DVI reset GPIO
[ 17.530883] OMAP DMA hardware revision 4.0
[ 17.537780] bio: create slab <bio-0> at 0
[ 17.539459] SCSI subsystem initialized
[ 17.541107] usbcore: registered new interface driver usbfs
[ 17.541259] usbcore: registered new interface driver hub
[ 17.541473] usbcore: registered new device driver usb
[ 17.541809] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 17.544799] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 17.544830] twl4030: power (irq 373) chaining IRQs 376..383
[ 17.545196] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 17.547027] regulator: VUSB1V5: 1500 mV normal standby
[ 17.547302] regulator: VUSB1V8: 1800 mV normal standby
[ 17.547637] regulator: VUSB3V1: 3100 mV normal standby
[ 17.549102] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 17.549652] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 17.549987] regulator: VDAC: 1800 mV normal standby
[ 17.550292] regulator: VPLL2: 1800 mV normal standby
[ 17.550628] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 17.551086] regulator: VAUX3: 1800 mV normal standby
[ 17.551513] regulator: VAUX4: 1800 mV normal standby
[ 17.562713] i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
[ 17.562988] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
[ 17.564788] cfg80211: Using static regulatory domain info
[ 17.564819] cfg80211: Regulatory domain: 00
[ 17.564819] (start_freq - end_freq @ bandwidth),
(max_antenna_gain, max_eirp)
[ 17.564849] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi,
2000 mBm)
[ 17.564880] (2457000 KHz - 2482000 KHz @ 20000 KHz), (600 mBi,
2000 mBm)
[ 17.564880] (2474000 KHz - 2494000 KHz @ 20000 KHz), (600 mBi,
2000 mBm)
[ 17.564910] (5170000 KHz - 5250000 KHz @ 40000 KHz), (600 mBi,
2000 mBm)
[ 17.564941] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi,
2000 mBm)
[ 17.565002] cfg80211: Calling CRDA to update world regulatory
domain
[ 17.565307] Switching to clocksource 32k_counter
[ 17.577972] musb_hdrc: version 6.0, musb-dma, host, debug=0
[ 17.581298] musb_hdrc: USB Host mode controller at fa0ab000 using
DMA, IRQ 92
[ 17.581329] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 17.581481] musb_hdrc musb_hdrc: new USB bus registered, assigned
bus number 1
[ 17.581665] usb usb1: New USB device found, idVendor=1d6b,
idProduct=0002
[ 17.581695] usb usb1: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 17.581695] usb usb1: Product: MUSB HDRC host driver
[ 17.581726] usb usb1: Manufacturer: Linux 2.6.32 musb-hcd
[ 17.581756] usb usb1: SerialNumber: musb_hdrc
[ 17.582550] hub 1-0:1.0: USB hub found
[ 17.582611] hub 1-0:1.0: 1 port detected
[ 17.583648] NET: Registered protocol family 2
[ 17.583923] IP route cache hash table entries: 1024 (order: 0, 4096
bytes)
[ 17.584594] TCP established hash table entries: 4096 (order: 3,
32768 bytes)
[ 17.584716] TCP bind hash table entries: 4096 (order: 2, 16384
bytes)
[ 17.584808] TCP: Hash tables configured (established 4096 bind
4096)
[ 17.584838] TCP reno registered
[ 17.584869] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 17.584899] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 17.585205] NET: Registered protocol family 1
[ 17.585754] RPC: Registered udp transport module.
[ 17.585784] RPC: Registered tcp transport module.
[ 17.585784] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 17.588409] VFS: Disk quotas dquot_6.5.2
[ 17.588531] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 17.589996] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 17.591033] NTFS driver 2.1.29 [Flags: R/W].
[ 17.591461] JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red
Hat, Inc.
[ 17.592498] msgmni has been set to 212
[ 17.598114] alg: No test for stdrng (krng)
[ 17.598480] Block layer SCSI generic (bsg) driver version 0.4
loaded (major 253)
[ 17.598510] io scheduler noop registered
[ 17.598510] io scheduler deadline registered
[ 17.598724] io scheduler cfq registered (default)
[ 17.599365] OMAP DSS rev 2.0
[ 17.599456] OMAP DISPC rev 3.0
[ 17.599517] OMAP VENC rev 2
[ 17.599914] OMAP DSI rev 1.0
[ 17.926361] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 17.948028] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 17.968902] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 17.989685] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 18.586029] console [ttyS2] enabled
[ 18.598815] brd: module loaded
[ 18.606475] loop: module loaded
[ 18.611785] omap2-nand driver initializing
[ 18.616302] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba
(Micron NAND 256MiB 1,8V 16-bit)
[ 18.626129] cmdlinepart partition parsing not available
[ 18.631469] Creating 5 MTD partitions on "omap2-nand":
[ 18.636688] 0x000000000000-0x000000080000 : "X-Loader"
[ 18.643341] 0x000000080000-0x000000260000 : "U-Boot"
[ 18.650146] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 18.656524] 0x000000280000-0x000000680000 : "Kernel"
[ 18.664215] 0x000000680000-0x000010000000 : "File System"
[ 18.777404] usbcore: registered new interface driver catc
[ 18.782836] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 18.788970] usbcore: registered new interface driver kaweth
[ 18.794616] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB
Ethernet driver
[ 18.802276] usbcore: registered new interface driver pegasus
[ 18.808013] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet
driver
[ 18.815032] usbcore: registered new interface driver rtl8150
[ 18.820861] usbcore: registered new interface driver asix
[ 18.826446] usbcore: registered new interface driver cdc_ether
[ 18.832458] usbcore: registered new interface driver dm9601
[ 18.838195] usbcore: registered new interface driver smsc95xx
[ 18.844116] usbcore: registered new interface driver gl620a
[ 18.849853] usbcore: registered new interface driver net1080
[ 18.855712] usbcore: registered new interface driver plusb
[ 18.861297] usbcore: registered new interface driver rndis_host
[ 18.867401] usbcore: registered new interface driver cdc_subset
[ 18.873504] usbcore: registered new interface driver zaurus
[ 18.879241] usbcore: registered new interface driver MOSCHIP usb-
ethernet driver
[ 18.886871] usbcore: registered new interface driver rndis_wlan
[ 18.892974] usbcore: registered new interface driver rt73usb
[ 18.898834] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 18.905731] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 18.911560] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 2
[ 18.919250] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 18.940551] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 18.946472] usb usb2: New USB device found, idVendor=1d6b,
idProduct=0002
[ 18.953369] usb usb2: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 18.960662] usb usb2: Product: OMAP-EHCI Host Controller
[ 18.966033] usb usb2: Manufacturer: Linux 2.6.32 ehci_hcd
[ 18.971466] usb usb2: SerialNumber: ehci-omap.0
[ 18.976867] hub 2-0:1.0: USB hub found
[ 18.980743] hub 2-0:1.0: 3 ports detected
[ 19.011474] usbcore: registered new interface driver cdc_wdm
[ 19.017181] Initializing USB Mass Storage driver...
[ 19.022338] usbcore: registered new interface driver usb-storage
[ 19.028442] USB Mass Storage support registered.
[ 19.033081] udc: OMAP UDC driver, version: 4 October 2004 (iso)
(dma)
[ 19.040283] mice: PS/2 mouse device common for all mice
[ 19.045989] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 19.053070] i2c /dev entries driver
[ 19.057983] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 19.064208] twl4030_wdt twl4030_wdt: Failed to register misc device
[ 19.070587] twl4030_wdt: probe of twl4030_wdt failed with error -16
[ 19.184173] mmci-omap-hs mmci-omap-hs.1: err -16 configuring card
detect
[ 19.191345] Registered led device: beagleboard::usr0
[ 19.196472] Registered led device: beagleboard::usr1
[ 19.202880] Registered led device: beagleboard::pmu_stat
[ 19.208618] Advanced Linux Sound Architecture Driver Version
1.0.21.
[ 19.298675] No device for DAI omap-mcbsp-dai-0
[ 19.303192] No device for DAI omap-mcbsp-dai-1
[ 19.307708] No device for DAI omap-mcbsp-dai-2
[ 19.312194] No device for DAI omap-mcbsp-dai-3
[ 19.316680] No device for DAI omap-mcbsp-dai-4
[ 19.321166] OMAP3 Beagle SoC init
[ 19.326354] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 19.339752] ALSA device list:
[ 19.342742] #0: omap3beagle (twl4030)
[ 19.346740] oprofile: using arm/armv7
[ 19.350769] TCP cubic registered
[ 19.354034] NET: Registered protocol family 17
[ 19.358612] NET: Registered protocol family 15
[ 19.363220] lib80211: common routines for IEEE802.11 drivers
[ 19.368927] ThumbEE CPU extension supported.
[ 19.373291] Power Management for TI OMAP3.
[ 19.377899] usb 2-2: new high speed USB device using ehci-omap and
address 2
[ 19.385467] SmartReflex driver initialized
[ 19.400695] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 1
[ 19.409423] registered taskstats version 1
[ 19.415130] fbcvt: Refresh rate not CVT standard
[ 19.419860] fbcvt: 60Hz refresh rate advised for reduced blanking
[ 19.426055] fbcvt: 1920x1080@30: CVT Name - Not a CVT standard -
2.073 Mega Pixel Image
[ 19.426055]
[ 19.514068] regulator_init_complete: incomplete constraints,
leaving VAUX3 on
[ 19.521667] regulator_init_complete: incomplete constraints,
leaving VDAC on
[ 19.529998] twl_rtc twl_rtc: setting system clock to 2000-01-01
10:45:46 UTC (946723546)
[ 19.538604] Waiting for root device /dev/mmcblk0p2...
[ 19.590667] usb 2-2: New USB device found, idVendor=05e3,
idProduct=0608
[ 19.597473] usb 2-2: New USB device strings: Mfr=0, Product=1,
SerialNumber=0
[ 19.604705] usb 2-2: Product: USB2.0 Hub
[ 19.609802] hub 2-2:1.0: USB hub found
[ 19.614044] hub 2-2:1.0: 4 ports detected
[ 19.870483] mmc0: new high speed SD card at address 1234
[ 19.876434] mmcblk0: mmc0:1234 SA02G 1.83 GiB
[ 19.881408] mmcblk0: p1 p2
[ 19.910064] usb 2-2.1: new high speed USB device using ehci-omap
and address 3
[ 20.206848] usb 2-2.1: New USB device found, idVendor=050d,
idProduct=705a
[ 20.213775] usb 2-2.1: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 20.221160] usb 2-2.1: Product: Belkin 54g USB Network Adapter
[ 20.227172] usb 2-2.1: Manufacturer: Belkin
[ 20.499511] Registered led device: rt73usb-phy0::radio
[ 20.505035] Registered led device: rt73usb-phy0::assoc
[ 20.510314] Registered led device: rt73usb-phy0::quality
[ 20.598175] usb 2-2.4: new high speed USB device using ehci-omap
and address 4
[ 20.724639] usb 2-2.4: New USB device found, idVendor=090c,
idProduct=1000
[ 20.731628] usb 2-2.4: New USB device strings: Mfr=1, Product=2,
SerialNumber=3
[ 20.739074] usb 2-2.4: Product: Flash Disk
[ 20.743194] usb 2-2.4: Manufacturer: USB
[ 20.747192] usb 2-2.4: SerialNumber: FBA0911260044810
[ 20.753906] scsi0 : usb-storage 2-2.4:1.0
[ 23.983276] EXT3-fs (mmcblk0p2): warning: maximal mount count
reached, running e2fsck is recommended
[ 23.992584] kjournald starting. Commit interval 5 seconds
[ 24.386657] EXT3-fs (mmcblk0p2): using internal journal
[ 24.391937] EXT3-fs (mmcblk0p2): recovery complete
[ 24.801544] EXT3-fs (mmcblk0p2): mounted filesystem with writeback
data mode
[ 24.808776] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 24.818389] devtmpfs: mounted
[ 24.821472] Freeing init memory: 172K
INIT: version 2.86 booting
Boot splashscreen disabled
Please wait: booting...
Starting udev
[ 25.754638] scsi 0:0:0:0: Direct-Access USB Flash
Disk 1100 PQ: 0 ANSI: 0 CCS
[ 25.766510] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 25.773925] sd 0:0:0:0: [sda] 3915776 512-byte logical blocks:
(2.00 GB/1.86 GiB)
[ 25.790954] sd 0:0:0:0: [sda] Write Protect is off
[ 25.800201] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 25.807983] udev: starting version 151
[ 25.819793] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 25.826110] sda: sda1
[ 25.860015] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 25.886138] sd 0:0:0:0: [sda] Attached SCSI disk
Activating swap
Remounting root file system...
[ 31.231750] FAT: invalid media value (0xb9)
[ 31.235992] VFS: Can't find a valid FAT filesystem on dev sda.
[ 32.079437] quiet_error: 80 callbacks suppressed
Caching udev devnodes
Populating dev cache
udevadm settle - timeout of 8 seconds reached, the event queue
contains:
/sys/devices/platform/ehci-omap.0/usb2/2-2/2-2.4/2-2.4:1.0/host0/
target0:0:0/0:0:0:0/block/sda (446)
target0:0:0/0:0:0:0/block/sda/sda1 (447)
/sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:1234/block/
mmcblk0/mmcblk0p1 (480)
mmcblk0/mmcblk0p2 (481)
Loading modules: ipv6 [ 36.413024] NET: Registered protocol family
10
Mounting local filesystems...
Populating volatile Filesystems.
ALSA: Restoring mixer settings...
Loading kernel modules for gstreamer-ti...
Running /usr/share/ti/gst/omap3530/loadmodules.sh[ 37.181365] CMEMK
module: built on Jan 12 2011 at 22:04:42
[ 37.190643] Reference Linux version 2.6.32
[ 37.194976] File /home/tang/Projects/OE/build/tmp/work/
beagleboard-angstrom-linux-gnueabi/ti-linuxutils-1_2_25_02_08-r98d/
linuxutils_2_25_02_08/packages/ti/sdo/linuxutils/cmem/src/module/
cmemk.c
[ 37.227386] allocated heap buffer 0xca000000 of size 0x3098000
[ 37.239471] cmemk initialized
[ 37.275817] dsplinkk: disagrees about version of symbol filp_close
[ 37.282165] dsplinkk: Unknown symbol filp_close
FATAL: Error inserting dsplinkk (/lib/modules/2.6.32/kernel/drivers/
dsp/dsplinkk.ko): Unknown symbol in module, or unknown parameter (see
dmesg)
[ 37.305694] dsplinkk: disagrees about version of symbol filp_close
[ 37.312042] dsplinkk: Unknown symbol filp_close
WARNING: Error inserting dsplinkk (/lib/modules/2.6.32/kernel/drivers/
dsp/dsplinkk.ko): Unknown [ 37.324493] lpm_omap3530: Unknown symbol
IPS_notify
symbol in module, or unknown par[ 37.331970] lpm_omap3530: Unknown
symbol IPS_register
ameter (see dmesg)
[ 37.339630] lpm_omap3530: Unknown symbol IPS_unregister
[ 37.346710] lpm_omap3530: Unknown symbol LDRV_PROC_setState
[ 37.354644] lpm_omap3530: Unknown symbol LDRV_PROC_getState
[ 37.360839] lpm_omap3530: Unknown symbol PMGR_PROC_getSymbolAddress
FATAL: Error inserting lpm_omap3530 (/lib/modules/2.6.32/kernel/
drivers/dsp/lpm_omap3530.ko): Unknown symbol in module, or unknown
parameter (see dmesg)
[ 37.386627] SDMAK module: built on Jan 12 2011 at 22:04:45
[ 37.392181] Reference Linux version 2.6.32
[ 37.396545] File /home/tang/Projects/OE/build/tmp/work/
linuxutils_2_25_02_08/packages/ti/sdo/linuxutils/sdma/src/module/
sdmak.c
done
Configuring network interfaces... WPA: Configuring Interface
[ 37.793670] rt73usb 2-2.1:1.0: firmware: requesting rt73.bin
[ 37.921112] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 41.226654] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 51.286071] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 51.293060] cfg80211: Calling CRDA for country: NL
udhcpc (v1.13.2) started
run-parts: /etc/udhcpc.d/00avahi-autoipd exited with code 1
Sending discover...
[ 53.884887] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Sending discover...
Sending discover...
Sending select for 192.168.2.2...
Lease of 192.168.2.2 obtained, lease time 268435455
adding dns 192.168.2.1
ifconfig: SIOCGIFFLAGS: No such device
eth0 No such device
usb0 No such device
done.
Starting portmap daemon: portmap.
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
System time was Sat Jan 1 10:46:28 UTC 2000.
Setting the System Clock using the Hardware Clock as reference...
System Clock set. System local time is now Sat Jan 1 10:46:28 UTC
2000.
INIT: Entering runlevel: 3
Starting Dropbear SSH server: dropbear.
Starting advanced power management daemon: No APM support in kernel
(failed.)
Starting syslogd/klogd: done
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
...fail!
