2.6.34-rc3 kernel on devkit8000, DSS2 issue, omapfb probe failing
I recently cloned linus-omap kernel and compiled uImage for devkit8000.
During loading uImage into the board, it boots fine, except nand and display.
I am facing an OmapDSS issue, the error messages from
kernel is below:
kernel version is 2.6.34-rc3-07875-geba0147-dirty
NR_IRQS:402
Clocking rate (Crystal/Core/MPU): 26.0/266/500 MHz
Reprogramming SDRC clock to 266000000 Hz
dpll3_m2_clk rate change failed: -22
GPMC revision 5.0
io scheduler cfq registered (default)
OMAP DSS rev 2.0
omapdss DPI error: can’t get VDDS_DSI regulator
omapdss CORE error: Failed to initialize dpi
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev
1
omapfb omapfb: no displays
omapfb omapfb: failed to setup omapfb
omapfb: probe of omapfb failed with error -22
regulator_init_complete: incomplete constraints, leaving VDVI on
regulator_init_complete: incomplete constraints, leaving VDAC on
twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC
(946684800)
eth0: link down
How to overcome this and get the display up and running.
Where were you downloaded the kernel source?
try http://gitorious.org/devkit8000
download source by:
git clone git://gitorious.org/devkit8000/devkit8000.git linux-dk
and update by:
cd linux-dk
git pull
I recommand use this uImage with U-Boot v2009.11.1
source from ftp://ftp.denx.de/pub/u-boot/
The latest version is 2010.03, but I didn’t tried whether it works or not.
p.s. the X-Loader (MLO) I used is 1.41 version one from DevKit8000 CD.
i downloaded the source from linux-omap-2.6 git tree
git clone git://[git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6.git](http://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6.git)
try git clone git://gitorious.org/devkit8000/devkit8000.git
it follows the linux-omap with the patches that will go upstream.
Thomas
I am now using git://gitorious/devkit8000/devkit8000.git
I am gettting these errors, when i provide omapdss_disp=tv omapfb.mode=tv:ntsc
my vram setting is 0.
omapfb omapfb: failed to allocate framebuffer
[ 670.690826] omapfb omapfb: failed to allocate fbmem
[ 670.695861] omapfb omapfb: failed to setup omapfb
[ 670.700622] omapfb: probe of omapfb failed with error -12
Also, strange things happen, when i provide vram=12M, it crashes…
I don’t know if it is a typo but it should be
omapdss.def_disp=tv omapfb.mode=tv:ntsc
Thomas
