I had the same issue with mine. Based on this http://beagleboard.org/latest-images, the image that shipped with my board is the most current image. I didn’t have a serial cable handy so I didn’t check to see if that would shed any light on the matter. I ended up flashing the latest image onto a microSD card and bringing the board back to the stock image.
If possible, down the line, I’d much rather do the opkg upgrade route so perhaps someone else knows what’s going on.
Hmm, I had that DNS problem too, thought it was a fluke in my environment… Guess that’s one more thing to add to the steps!
And I saw that bonescript error too, it all cleared up on the next reboot I believe. I think it was trying to run some “bonescript.socket” service when the main bonescript service already takes care of it or something. Whatever it is, my “opkg upgrade” now does nothing (besides sit & pause for a while before returning to the shell prompt).
I just received my board and wanted to make sure it was up to date. I ran through the steps here to update because I found them ahead of time. I ran into the errors because the DNS was changed during the update so I corrected the file and started again. It seemed to go well. I substituted 3.8.10 for the force-overwrite command because that is what looked like it was being installed.
Yes, 3.8.10 had an unfortunate bug that disabled the eMMC, 3.8.11 fixes that.
I didn't complete the boot after a shutdown. It would hang. I downloaded what was marked as "the lastest image" off the site and installed it on a sd card but it boots to 3.8.3 which is older than what came with the board (3.8.6). Is there another link to a complete fresh latest install image available? I will try to do the update again from the sd card but am not sure if it will fail again. Also, what is the correct steps to reflash the emmc from the sd since I have it booted?
(it may be flashing automatically from sd, I see a couple of tar zxf Angstrom processes running and the led's look a little different so I will let it be). Would still like a good image of the shipped software instead of an older version.
